Old 12-05-2012, 11:11 AM   #1
AsianStyle
AsianStyle's Avatar
Drives: Whiteout FR-S MT
Durability of cast wheels
I'm interested in a couple of wheels for my daily driven FR-S, but concerned about durability of light weight cast wheels. The top 3 wheels I'm considering are:
17x8 Wedssport TC105n - Flow Form Cast
17x8 OZ Alleggerita HLT - Flow form Cast
17x8 OZ Ultraleggra - Cast
Can anyone give some insight on how these wheels fair when used on a daily driver. How do they stand to pot holes and chips on the finish?
Thanks in advance.
AsianStyle is offline   Reply With Quote
Old 12-05-2012, 11:15 AM   #2
diirk
diirk's Avatar
Drives: 4Runner
All three are a good quality wheel. I wouldn't expect any issues with whatever you choose.
I believe the WedSports are the lightest of the bunch. Running around 15 lbs.
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 12-05-2012, 12:02 PM   #3
empower-auto
Kouki-Monster
empower-auto's Avatar
I've never even wrecked a cheapo cast wheel, much less a quality one. I've had MSR, Tenzo, some weird JDM brands .. never an issue.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 12-05-2012, 12:29 PM   #4
raz0rbladez909
I'm here for the beer
raz0rbladez909's Avatar
Drives: 2013 Scion FRS, 1971 Datsun 240z
You'll be fine with cast wheels, they aren't super delicate like people make them out to be. The brands you have listed are from well known manufacturers and certainly know a thing or two about producing a good quality wheel.
raz0rbladez909 is offline   Reply With Quote
Old 12-05-2012, 12:39 PM   #5
ST185RC
Drives: White Out FR-S
Unless you're going sideways all day long or are burning out your tires all day long, or turbo your car to ridiculous numbers, all three of those cast wheels are perfectly fine. Had a set of superleggeras and i only bent the lip slightly because of a raised manhole cover while they were repaving.
Want a strong set of cast 5x100s from OZ? get Chronos or Gravel. Old school rally wheels in white with red lettering. Made heavy for heavy use.
ST185RC is offline   Reply With Quote
Old 12-05-2012, 12:43 PM   #6
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Our 18" Weds are really light for "cast" Def a good wheel
JDLAutoDesign is offline   Reply With Quote
Old 12-05-2012, 01:04 PM   #7
AsianStyle
AsianStyle's Avatar
Thanks for all the responses!
Now I have one more question. I know the TC105n won't allow you to install a hub centric ring and a center cap together. So, if you have to choose one or the other which would you pick and why?
Also, the OZs listed, do they allow you to install both ring and cap?
Old 12-05-2012, 01:30 PM   #8
OrbitalEllipses
Drives: Attitude
Hubcentric ring. It's more important to get the wheel centered on the hub than the aesthetics of a center cap; though I often wonder about salt/corrosion and the axle-nut. Regardless, the wheel not being centered on the hub is NOT good. OZ wheels I've seen usually let you use the ring and cap; I find it odd that the Weds don't let you do this and while not that important it makes me want them less. Really my problem with the Weds is the availability; popular sizes seem to be stocked well but I waited ~4 months for 17x8 +42 TC105N before cancelling. 18x8 +42 is also a special order (just like my order for the 17x8 +42), so I'm not sure I'll be buying them.
One thing to note about durability is that cast wheels tend to bend whereas forged wheels tend to crack.
Old 12-05-2012, 02:57 PM   #9
n2oinferno
Praise Helix!
n2oinferno's Avatar
Hmm, that makes me wonder if someone out there with a 3D printer could custom make wheel caps for wheels that aren't fit to run both.
Old 12-05-2012, 03:34 PM   #10
AsianStyle
AsianStyle's Avatar
Aesthetically I prefer the the TC105n, but my biggest concern is with rust and debris getting on the axle nut if I leave it un-capped.
Does anyone have any experience with the TC105n mounted with the center caps? Since they are mounted from the inside of the wheel I wonder if they behave like a hub centric ring.
Old 12-05-2012, 06:47 PM   #11
OrbitalEllipses
Drives: Attitude
They're good looking wheels, I'm just not happy with the availability of "less popular" sizes. The Alleggerita HLT is a good looking wheel as well (and available in gold!), but the offset's too high for my taste in 8" wide flavor.
The only way the center cap (if mounted from the inside like you say it is) could act as a hubcentric ring would be if the center cap had a machined 56.1mm area to slip over the hub.
Old 12-05-2012, 06:58 PM   #12
DarkSunrise
DarkSunrise's Avatar
I see a lot of bent Ultraleggeras. Seeing as how they're so light and gravity cast, it makes me question how durable they are.
Personally I'd go with one of the flow-form cast wheels. They're light, but should be relatively strong for their weight.
Old 12-05-2012, 09:32 PM   #13
bpracer
Drives: Asphalt FR-S
I think you got that backwards from my experience.
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
The Following 2 Users Say Thank You to bpracer For This Useful Post:
Dimman (12-06-2012), JoeBoxer (12-06-2012)
Old 12-06-2012, 05:10 PM   #14
Drift Motion
Drives: Subaru Legacy GT
Just remember this
Flow Form > Low-Pressure > Gravity
From that list, I'd go with the Weds. Stay away from cheapo reps, most uses gravity cast...
Drift Motion is offline   Reply With Quote
FA20 OEM pistons, are they Forged or Cast ? adprokid Engine, Exhaust, Transmission 54 10-11-2014 05:51 PM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 10:08 PM
FR-S A/T strength/durability? 07stealth350z Scion FR-S / Toyota 86 GT86 General Forum 1 06-18-2012 12:58 PM
Car Cast W/Adam Corolla review Gaen BRZ Photos, Videos, Wallpapers, Gallery Forum 4 06-03-2012 04:02 AM
Any Disney Cast Members here? MF_DEUCE Off-Topic Lounge [WARNING: NO POLITICS] 9 11-18-2011 01:48 AM
