Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
12-03-2012, 11:21 PM | #15 |
prefer crush
12-04-2012, 06:16 AM | #17 |
Developer,
Thanks for the time you took and the info you posted on the washers. No doubt these washers can be sourced from somewhere other then the dealer for something less then the cost of my first born child. |
The Following User Says Thank You to Daless2 For This Useful Post: | developer (12-04-2012) |
12-04-2012, 07:26 AM | #18 |
I Love custom Turbo kits
Drives: Limited BRZ
Holy Crap... Tell me how you did it... my first born child was like 10,000 times more expensive!!!
12-04-2012, 09:32 AM | #19 |
Drives: 4Runner
It was my understanding that the Transmission fill/drain washers were actually different sizes? Is this not the case?
diirk
waiting on a Neptune Premium MT |
12-04-2012, 11:16 AM | #20 |
Drives: BRZ Limited
12-04-2012, 11:27 AM | #21 | |
Drives: 4Runner
Was the tranny washer steel or aluminum?
diirk
12-04-2012, 11:30 AM | #22 |
Drives: BRZ Limited
I would feel pretty secure reusing the flat transmission washers at least once, if they are in good shape. I would check the surface of the washer and make sure there are no defects. They are also pretty soft so I would put them on a flat surface and make sure they aren't severely deformed.
12-04-2012, 11:49 AM | #23 |
Drives: BRZ Limited
12-07-2012, 10:27 AM | #24 |
Drives: LP DSP / CSP '13 BRZ
Thank you for the information
You can get "generic" crush washers at any auto parts store for less than a $1 each I just didn't know the size the buy. I ended up flipping and reusing the diff ones with no leaks so far. The next change I'll get new washers. |
12-08-2012, 12:18 AM | #25 |
Drives: BRZ Limited
You bet, I am really enjoying the fluid change. My transmission change to Pentosin II made a huge difference in shifting.
06-19-2013, 11:11 AM | #26 |
Life to short to be slow!
Drives: Toyota GT86
Subscribed!!! I will change trans & Diff oil for motul 300 this weekend that is if I can find some in Puerto Rico. I will try to reuse everything.
Also I will be changing the Brake oil for motul RBF600 any chance anyone know where to buy a pump to drain the old oil? |
06-19-2013, 01:06 PM | #27 | |
Drives: Limited BRZ
Amazon has some hand and air pumps to drain the fluid.
The Following User Says Thank You to Sportsguy83 For This Useful Post: | kombatlion (06-19-2013) |
06-19-2013, 03:49 PM | #28 | |
Drives: Toyota GT86
The Following User Says Thank You to kombatlion For This Useful Post: | Sportsguy83 (06-19-2013) |
Similar Threads | ||||
Washer Mod? | 636 | Engine, Exhaust, Transmission | 64 | 02-20-2018 04:08 PM |
Pressure Washer $60 at super store | Aznek | CANADA | 6 | 09-10-2012 11:08 AM |
Engine oil drain plug washer | BMWDavid | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 06-28-2012 11:28 AM |
front washer? | Filipino Royale | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-21-2012 02:06 PM |
Man Crush A Friend's Car With A 100-ft Axe | ichitaka05 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 01-19-2012 03:31 PM |
