Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > New England
New England MA, ME, NH, RI, VT
View Poll Results: Which winter tires/rim option did you choose? Also indicate which tire size.
Winter tires on OEM Rims 18 26.09%
Winter tires on Alloy rims with TPMS 4 5.80%
Winter tires on Alloy rims without TPMS 16 23.19%
Winter tires on steel rims with TPMS 1 1.45%
Winter tires on steet rims without TPMS 25 36.23%
Purchased 215/45/17 (OEM) winter tires 15 21.74%
Purchased 205/55/16 winter tires 21 30.43%
Purchase other sized winter tires. 4 5.80%
Multiple Choice Poll. Voters: 69. You may not vote on this poll
Old 12-03-2012, 05:16 PM   #43
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Can anyone confirm the factory relearn procedure for these cars?
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 12-04-2012, 12:45 AM   #44
NRGBalanced
NRGBalanced's Avatar
Drives: '13 Subaru BRZ Limited WRB
As far as I know, "learning" new sensors isn't possible. The new sensor IDs have to be written to the ECU (body control unit?) via Techstream or a tool like the ATEQ Quickset or VT30 through the OBDII port. The sensors are constantly broadcasting but the car will never look for another set of IDs that are not in the computer.
NRGBalanced is offline   Reply With Quote
Old 12-05-2012, 06:28 PM   #45
BR Zenith
Drives: 2013 LR BRZ Limited
I put Blizzak WS-70's on the stock rims with TPMS. Haven't been able to test in ice or snow yet though.
BR Zenith is offline   Reply With Quote
Old 12-08-2012, 03:48 PM   #46
davesrave
davesrave's Avatar
Drives: 2014 Boxster S; 2015 Macan S
Originally Posted by davesrave View Post
Report #1: Drove home from work with the TPMS light on. The car was parked next to the sensors for a couple of hours before I went out. When I started it, the TPMS light was out! Drove about 7 miles, out for 2+ hours, drove the return trip home and the TPMS light is still out. Still not convinced this is going to be the long term scenario because I don't understand how this system works.
report #2: Dove to the airport, light came on in about 20 miles. 4 days later, returned home, car sat overnight and the next day the light was off. I am now convinced it is sensing the TPMS in the tires stacked next to it. Could the energy source be the tire pressure?
davesrave is offline   Reply With Quote
Old 12-08-2012, 03:52 PM   #47
cnk
Drives: '13 DGM BRZ Limited
The sensors have batteries in them. That's why they will eventually need to be replaced. Tire pressure has nothing to do with the power for the sensors. It is only the parameter that the sensors monitor.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
Old 12-08-2012, 04:15 PM   #48
davesrave
davesrave's Avatar
[QUOTE=cnk;597862]The sensors have batteries in them. That's why they will eventually need to be replaced. Tire pressure has nothing to do with the power for the sensors. It is only the parameter that the sensors monitor.
Thanks. I found a Toyota Rav 4 TPMS description that seems to fit: http://rav4world.com/pdf/2006/tirepres.pdf
Some of the info:
This transmitter operates with a lithium battery, which lasts approx. 10 years.
If the lithium battery is depleted, replace the entire tire pressure warning valve and transmitter assembly.
If the battery voltage drops, the tire pressure warning antenna and receiver stores the DTC (Diagnostic Trouble Code) in its memory.
If the voltage drops even further and the transmitter stops working, it stores the DTC in memory and illuminates the tire pressure warning light to alert the driver.
Each transmitter has a built-in semiconductor to directly measure the tire pressure.
15 inch rims for winter? CBR600RR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 08-12-2023 05:42 PM
Fitment of Winter Tires on Stock Rims: X-Ice 3 215/55/17 hyper4mance Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 10-23-2017 12:17 AM
Winter Rims RandomHero Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-05-2012 09:06 PM
FS (Toronto) 17" Forged Rims, StarSpecs, Winter Tires, Rota bdon22 Wheels and Tires 17 10-29-2012 09:33 PM
Winter Tires and 17" Rims?? stalon320 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-03-2012 09:33 AM
