Northwest AK, ID, OR, WA
Old 11-26-2012, 01:05 AM   #15
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Originally Posted by seven View Post
I wouldn't spend the money on those, but if you have them laying around, then why not? haha
Still... I'd buy some good pads for the Brembos (same brands as I said)...
Keep in mind larger rotors/calipers just mean you can stop more consistantly (because they dissipate heat better) not shorter necessarily.
The pads are what keeps you stopping shorter, the lines keep good feel and won't stretch, the fluid stops you from boiling and losing the ability to use the brakes.
Basically, with experience with my two Corvettes, I've never upgraded rotor size or caliper... just pads, lines, and fluid, never had a problem with braking even when up against guys with BBKs on track days. You can have all the size in the world as far as brakes go, but shitty oem pads will always be shitty.
Again, after doing brakes... get some tires to utilize the stopping power you have.
If it were me, I'd do pads/lines/fluid (and your BBK since you have it), RCE yellows for the look, and then some sticky wheels/tires (keep in mind they need to fit over those Brembos).
Run the car like that, add sway bays to dial it in... then decide if you need more, if you do, start shopping for coilovers.
Hmm... very good advice. I may have to take you up on it. I appreciate it. I haven't looked at it in that perspective.
Chen is offline   Reply With Quote
Old 11-26-2012, 01:11 AM   #16
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
It'll be useful if you do any racing of any sort. I've been a track rat for years now. I was an instructor in the Northeast/Philly area before I've moved here. Basically, I've been there so I figure I should offer the advice as someone who has bought stuff out of order and ended up not enjoying the car for a time period as much as I might have if I did it right.
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
Old 11-26-2012, 01:18 AM   #17
Chen
Regional Moderator
Chen's Avatar
I have tracked a little bit w/ this car. but w/ this weather. it hasn't permitted it. But I may do it a little bit more w/ break/coil upgrades. Again. Depending on the weather. I may have to store the car until after the icey season.
Old 11-26-2012, 02:39 AM   #18
seven
Tells it like it is
seven's Avatar
Yeah, snow/ice/cold weather in general is a drag
Old 11-27-2012, 12:26 AM   #19
31katys
31katys's Avatar
Drives: whiteout mt fr-s
I went with coils first. They are cheaper than wheels and a quick way to get rid of the awful gap.
31katys is offline   Reply With Quote
Old 11-29-2012, 11:58 AM   #20
NickFRS
Drives: 2013 Asphalt FRS
I did wheels/tire first. Cant wait to install coils after my car is back from the shop.
NickFRS is offline   Reply With Quote
Old 11-29-2012, 06:53 PM   #21
[[|==86==|]]
[[|==86==|]]'s Avatar
Drives: Hakosuka
Driver MOD... Sorry that wasn't any help. Not sure what your end goal is but I'd say, get some decent springs/RCE then you may have some $$ left for some wheels/tires. RCE's tend to hold some value so when you're ready/have some more $$ saved up, sell the springs and get the KW's.
[[|==86==|]] is offline   Reply With Quote
Old 12-02-2012, 11:40 PM   #22
Timtamtt
Timtamtt's Avatar
Wheels and tires first. Cause if you get coilovers you will have to adjust twice. If you get wheels first then coilovers later you will be 4x4 for a little while but saves you the hassle of readjusting to new wheels and alignment moneys
Timtamtt is offline   Reply With Quote
Old 12-03-2012, 12:12 AM   #23
Chen
Regional Moderator
Chen's Avatar
I keep going back and forth!
Old 12-03-2012, 12:49 AM   #24
EN2_Squirrel
EN2_Squirrel's Avatar
i did coils first. do tires first.
EN2_Squirrel is offline   Reply With Quote
Old 12-03-2012, 01:18 AM   #25
Chen
Regional Moderator
Chen's Avatar
Why's that?
Old 12-03-2012, 01:32 AM   #26
Otterbrawten
Drives: Firestorm FR-S
I would go for the coils because you want to see the wheels after you have the coils in place since that's how it will be in the long run. I am debating coils, exhaust or wheels... Good luck making your decision.
Otterbrawten is offline   Reply With Quote
Old 12-03-2012, 01:50 AM   #27
Chen
Regional Moderator
Chen's Avatar
In your shoes I ended up going with exhaust first. But with all the help from what people here have said. I think I'm going with coils first mainly because I can't find. Set of tires/wheels that stick out to me.
Old 12-03-2012, 01:59 AM   #28
brianlo622
brianlo622's Avatar
Drives: 2013 FR-S, raven
Do you know what size/offset wheels you are going to get? is you goal getting lighter wheels (and a square setup) for track duties? Or is it going to be built into a show/street car?
These are some of the factors to determine whether you want to get wheels first or coilovers first. The reason behind this is because some aggressive fitment wheels (hate to use the word hellaflush but it applies here) require aftermarket suspension in order to provide enough inner clearance for fitment. These wheels will not work with the stock shocks and springs, as the stock shock assembly is fatter than aftermarket coilovers, and the wheels will hit the spring perch.
悪魔のハチロク
2013 Scion FR-S, Raven
Current Mods: TRD Full Body Kit | TRD JDM Exhaust | SQ Audio by Simplicity in Sound
Stance Coilovers & LCA | TE37SL18x9.5PressedGraphite
brianlo622 is offline   Reply With Quote
WTB: brz/frs rims/tires Socal $500-600? stocktc1 Wheels and Tires 3 11-16-2012 06:43 AM
Newbie with tires/rims ... HELP mashal Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-09-2012 04:32 PM
WTB: OEM Stock rims and tires HATED1 Wheels and Tires 4 08-29-2012 02:23 PM
rims and tires frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-25-2012 02:24 AM
Looking for rims + tires randomweather Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 06-07-2012 12:17 AM
