#15 |
Site Moderator
Drives: Stuff
Many here (including myself) have done that with no change in toe. Just loosen the bottom bolt a little bit, don't remove it.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#17 |
Site Moderator
Drives: Stuff
When I did them I removed the nut off the stock top one, slightly loosened the bottom to allow movement (with force), remove top bolt, replace top bolt, push the top of the knuckle/hub carrier in to get maximum negative camber, snug bottom nut which will then hold the knuckle where it is, tighten top bolt, torque both.
Between that and the whiteline com-c tophats I'm at -2.2 on both sides up front, so I'm getting about -1.2 out of the crash bolts if the Com-C's are providing -1.0 as designed..
-Dave
#18 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
Ok, I think I'm done with questions for today. Thanks for the personalized help! I knew there was a reason I loved this forum.
#19 |
Drives: none yet
i used hawk hps on my s-10 having seen good reviews on the s10 forum from members and while I was breaking the pads in, the pedal kept going to the floor on the last 2 braking applications. I was wondering if I had air in it so I bled it and it kept going to the floor. I thought it could be the old rubber lines(which surely doesn't help).
I was going through this site on brakes and saw a lot of guys had the same issues with the hps. works great on the street and stops more than the stock brakes ever did, but I hate the VERY mushy feeling the brakes have now. I very much do not recommend them front or rear especially if you're going to track it. By the 10th application, as per hawk's break-in procedure, the pads were smoking pretty bad IMO. that would be equal to maybe one or two lap of a race track i believe. street friendly? yes, drag strip? yes, road course, never, ever. |
#21 | |
Drives: 4Runner
After your first event, then consider changing out your brake fluid or pads and maybe crash bolts. SS Lines are unnecesary at this point. For my third event I ran crash bolts and StopTech pads and changed out the diff oil. Still running the stock fluid but am planning to change that out soon. Also just an FYI, for tire pressure start around 36° hot or 32° cold.
diirk
waiting on a Neptune Premium MT |
#22 |
Lap time enthusiast
@diirk
Thanks for the advice! The main reason I'm doing fluid and pads is more for safety than performance. I want to avoid fade and boiling fluid because of the potential catastrophe it could be. The camber bolts I want because I already did AutoX completely stock. |
#23 |
Drives: 4Runner
Makes sense. And considering you have some experience, it makes even more sense.
I just think folks overstate the need to change fluid and pads. I had no brake fade from the first two days. And I was on a pretty fast track.
diirk
#24 |
Kouki-Monster
Where can a guy snag these bolts? Are the whiteline ones the same idea?
Rich Anderson
EMPOWER AUTO |
#25 | |
Site Moderator
Drives: Stuff
You can buy them from any Subaru or Toyota/Scion dealership but in my experience (and based on what others have posted here that I've seen) they are cheaper at Subaru dealerships.
-Dave
| The Following User Says Thank You to Dave-ROR For This Useful Post: | PMok (12-01-2012) |
#26 |
Codename: Stitch
Thanks to all you guys for your input on this. I too am headed to the track in a few weeks and thanks to the useful info on here, here are the mods I have decided to pour my money into:
- Front XP8 Brake Pads - Motul RBF660 fluid - Goodridge speedbleeders - Berk catless test pipe (yeah not necessary but WANT )- new suction cup camera mount - front crash bolts
