Old 11-30-2012, 04:01 PM   #1
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
Has anyone install a light weight flywheel?
Just asking if other members of this forum have installed a light weight flywheel and if so what are your thoughts. I am installing my flywheel on Tuesday and want to know what to expect out of this mod. I will be using factory clutch.
http://www.evolution-industries.com/dyn2.aspx
20valvewynn83 is offline   Reply With Quote
Old 11-30-2012, 04:05 PM   #2
CSG David
CSG David's Avatar
The CSG BRZ doesn't have a lightweight flywheel yet. However, on my personal S2000, I have the Exedy OE Replacement clutch kit and a Toda flywheel. The stock AP2 flywheel is 22lbs and the Toda flywheel is 8.4lbs. You will expect to have better engine response when you rev match and the engine will sound a little livelier. It is an overall better driving experience.
Old 11-30-2012, 04:07 PM   #3
MTCRX
MTCRX's Avatar
Drives: Whiteout FRS- autocross ready
I haven't put one on these cars, so I don't know the level of difficulty. But I did put one on a 1.5L Honda engine and love it. The engine revs so much faster and easier, it really took a lot of the response lag out of the engine. The car became much quicker at autocross. I put a heavier duty clutch and pressure plate in while I was there since it does take time to get everything apart. Dissasembly of pieces to get at the transmission and clutch are the biggest time sinks in the project. Make sure you remember where everything goes to reassemble it.
Let us know how it goes, what you encounter along the way, and how it behaves later.
MTCRX is offline   Reply With Quote
Old 11-30-2012, 04:10 PM   #4
20valvewynn83
Yeah I grasp the concept but I guess I'm looking to see how the FRS takes the flywheel. I understand the revs come quick but during daily driving how is it
Old 11-30-2012, 04:14 PM   #5
20valvewynn83
I'm sure I will remember how it all goes back as I do work for Toyota as a tech. It should only take a few hours to complete. I will give an update on Tuesday if all goes well
Old 11-30-2012, 04:20 PM   #6
wparsons
wparsons's Avatar
I've heard some Subaru's don't idle properly, and can throw codes if the mass is reduced too much.
flickr
Old 11-30-2012, 05:42 PM   #7
20valvewynn83
Interesting do you remember where you found this info. I would like to know weights
Old 11-30-2012, 05:45 PM   #8
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
I'm trying for a search.. I read the same with a fly wheel and pulley it was throwing codes.. I'll see if I can find the info.. I am pretty sure it was a isolated case.. But don't remember much of it
Gixxersixxerman is offline   Reply With Quote
Old 11-30-2012, 08:54 PM   #9
20valvewynn83
Nobody has this mod yet (on an FRS)
Old 12-01-2012, 12:31 AM   #10
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
That was a problem that happened with the 02-05 WRX.. When you combined the LW pulley with the LW flywheel.. the car would rev so fast and engine speed would drop so rapidly that the ecu thought the car was misfiring and thus it would pull timing and freak out.
It was a fairly rare occurrence.
Ranatsu is offline   Reply With Quote
Old 12-01-2012, 12:35 AM   #11
20valvewynn83
Was this only happening with an extremely light flywheel or it didn't matter?
Old 12-01-2012, 12:41 AM   #12
Ranatsu
Cone basher
Usually the lightest flywheels on the WRX I think were less than 10 lbs, combined with a ~1 lbs crank pulley..
I personally knew people who ran that setup and never had the issue.. It was pretty rare, but as you know only the people with problems say anything. Not the hundreds that don't have problems.
I've never heard of anyone with a newer Subaru on the 32 bit ecu or canbus ecu have any such problem.
I would do it and not look back if it were me. In fact eventually I will have the lightened crank, lightened flywheel, and carbon fiber driveshaft.
Old 12-01-2012, 12:57 AM   #13
20valvewynn83
Damn 10lbs is too light for me I think my flywheel is about 12-16lbs. I have the crank pulley so I'm sure my revs will go quick enough and like you said I'm sure I will have a lighten driveshaft as well. Now you got me thinking I will get a check engine light but its all good ill just have to save up for a tune
Old 12-01-2012, 01:05 AM   #14
Ranatsu
Cone basher
I doubt you will get a cel from it.. Like i said it was very rare. I wouldn't worry about it at all.
Light weight flywheel and crank pulley? wootwoot Engine, Exhaust, Transmission 133 06-23-2015 01:04 PM
Light Weight Fly Wheel denverizzles Engine, Exhaust, Transmission 13 12-03-2012 02:28 PM
Light Weight Seats sw20kosh Tracking / Autocross / HPDE / Drifting 23 11-06-2012 11:15 PM
Sard light weight flywheel Turdinator Engine, Exhaust, Transmission 4 10-30-2012 08:53 PM
