Old 11-26-2012, 09:04 AM   #43
Racecomp Engineering
That noise was 100% related to the whiteline top mounts used by a few customers. Whiteline had a batch of defective top mounts that unfortunately made it out to customers. But NO noise with the springs and no need to run the top mounts either. We offer the dealer option front camber bolt to pair with our springs.
- andrew
Mikepage (11-26-2012)
Old 11-26-2012, 09:19 AM   #44
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Thanks Andrew,
If i understand, you give a dealer camber bold with the set of your springs? Or the OEM bolt already installed on the car can do the job? Just want to know if i need to buy something at the dealer.
Mikepage is offline   Reply With Quote
Old 11-26-2012, 01:08 PM   #45
We offer the OEM dealer option camber bolts for an extra 10 bucks to be included in the package with the springs.
It's just an option, not a requirement, but it helps get a little extra negative camber for better handling. Without the bolts you will not have any issues with tire wear or anything.
- Andrew
Old 11-26-2012, 01:25 PM   #46
Mikepage
Mikepage's Avatar
Ok good to know, thanks again Andrew. You give a good support.
The Following User Says Thank You to Mikepage For This Useful Post:
Racecomp Engineering (11-26-2012)
Old 11-27-2012, 02:19 PM   #47
Mikepage
Mikepage's Avatar
Question again, with the racecomp spring compare to the hotchkis springs, hotchkis say they have setup the springs rate to have a neutral setup, no oversteer and no understeer, what's about your spring? Because i know, you used a different springs rate.
Can you clarify this a little bit? Do you know if you have keep the oversteer feeling? I ask this because i want to keep this without starting to install the sway bar kit.
Thanks.
Old 11-30-2012, 12:19 PM   #48
Hotchkis
Hotchkis's Avatar
Mike,
Just to clarify, a neutral handling car doesn't mean no oversteer or understeer. What it gives you is a car that doesn't inherently do either. Want some oversteer? Trail brake into a corner to keep the weight transfered forward and you get oversteer. Get on the gas too much too early and you will see some understeer. What a neutral handling car gives you is the choice of how the car handles.
Hotchkis is offline   Reply With Quote
The Following User Says Thank You to Hotchkis For This Useful Post:
Mikepage (11-30-2012)
Old 11-30-2012, 12:45 PM   #49
Mikepage
Mikepage's Avatar
You have a very good point, we always learn on this forum.
I will consider this if i buy coil springs.
Thanks!
Old 11-30-2012, 01:18 PM   #50
ICantAffordAnLFA
ICantAffordAnLFA's Avatar
Drives: Brz, Legacy
Just taken delivery of my STI springs
Shame the CE28s don't arrive till the new year
Trackday ride with built motor
Mods: Going, Stopping, Handling
Parts: CP, Pauter, Sprintex, Ecutek, Milltek, STI, Rays, Defi, Essex AP Racing, Bilstein, Whiteline, Perrin, RacerX
ICantAffordAnLFA is offline   Reply With Quote
Old 11-30-2012, 01:42 PM   #51
Mikepage
Mikepage's Avatar
You have buy the STI spring for the BRZ?
Old 11-30-2012, 02:22 PM   #52
ICantAffordAnLFA
Drives: Brz, Legacy
Originally Posted by Mikepage View Post
You wait to buy the STI spring for the BRZ?
Couldn't get them until beginning of November in Japan; at my door 10 days later.
Maybe Switchlanez got a set from the first batch?
Old 11-30-2012, 02:42 PM   #53
Mikepage
Mikepage's Avatar
What is the cost and the spec for the STI springs?
Old 01-04-2013, 09:53 AM   #54
Mikepage
Mikepage's Avatar
Bump for a good thread.
Old 01-04-2013, 07:22 PM   #55
ayau
Drives: Some rust bucket
You can order the STI springs from japanparts.com.
Since STI doesn't sell dampers for the BRZ yet, one can assume that the STI springs were made for the OEM dampers. Considering the springs only drop the car by about 0.6", I'm guessing the springs are similar to the OEM springs in terms of stiffness.
I haven't been able to find the rates for them. Furthermore, they're not listed on STI's website. Personally, I don't think they're anything special if they don't list the spring rates.
http://www.sti.jp/parts/catalogue/brz_zc6/2.html
Replacing Struts and Installing Coil Springs DarrenDriven DIY (Do-It-Yourself) Guides 195 04-26-2017 04:15 PM
Adjustable shocks+ springs vs Coilovers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 06-08-2013 03:59 PM
What shocks _F-R-S_ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-31-2012 02:18 PM
Drop Springs rather than Coil Overs??? Kuneff Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-31-2012 10:16 AM
Matching shocks with springs Ben_G Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 07-22-2012 09:32 PM
