Old 09-04-2011, 09:47 PM   #15
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
Originally Posted by #87 View Post
The calipers in the rear were Honda replacement parts. The caliper appear to function properly: slide pins lubricated and slide easily, hand brake functions properly, piston turns back in with minimal effort.
The caliper I bought today was from autozone and looks the same as the one I took off (same markings,, numbers on it).
I originally had brake problems because I never changed the fluid. When I replaced all the brake parts I bleed the whole system and put in ATE Super Blue fluid. I have bleed the system 2 times in past 18 months.
I am going to replace the other caliper and bleed the whole thing again tomorrow.
My location is NY. I hope this doesn't happen again in another year.
holy fuck you used ATE Super Blue fluid? ...that MIGHT just be your problem there. Super Blue is a DOT5+ fluid. Which means it has a higher boiling point, and the pressure is not suitable for extended use on a street car.
A lot of people say its ok for a street car, but iv seen plenty of brake failure of Daily driven cars due to that fluid.
Its not a bad fluid by all means, its awesome. But its use on regular street where you don't get up to good temps in the brake lines may cause wear.
I wonder if even your calipers are broken at all with that fluid still inline. I suggest bleed the brakes and switch to a DOT3/DOT4 fluid, and not a racing fluid.
But if you believe that the fluid is not the cause, then ignore my post.
WingsofWar is offline   Reply With Quote
Old 09-04-2011, 09:56 PM   #16
#87
I usually post drunk
#87's Avatar
I have the caliper I took off today. Before I return it for core would I see anything of benefit by pulling out the piston and seeing what it looks like?
Is there any reason why the rear calipers would go bad from the fluid but not the fronts?
#87 is offline   Reply With Quote
Old 09-04-2011, 10:01 PM   #17
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Brake bias makes you work the front brakes more, which loads it up and generates a bit more heat than the rears.
My guess, If it really is indeed the fluid, your not getting good pressure in the rears because your not reaching optimal fluid temps from load. AKA your fronts brakes doing more work than they should.
Having unequal pressure for a long time could damage those rear calipers...
Old 09-04-2011, 10:28 PM   #18
#87
#87's Avatar
Hmm, that is interesting, I didn't know fluid could cause these problems. The bottle says DOT4 and that it meets/exceeds/compatible with DOT3/4.
What is a good high temp street fluid then?
Old 09-04-2011, 10:41 PM   #19
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
DOT4 is rated at 446Degrees F, which is really more than you need on a street car especially an Accord Sedan with factory calipers.
Your ATE Super Blue is rated at 536Degrees F, which makes your brakes run too cold for daily use.
ATE Super Blue Racing Brake fluid is actually not officially DOT rated, but have similar qualities of DOT4 being a high temp and a polyethylene glycol base. The reason why it says compatible is because you can mix it with other brake fluids, ie; if you have DOT3 fluid in your system and your running low, you can add ATE Super Blue and it will slighty raise the boiling point but not degrade the quality of the fluid.
So any over the counter DOT4 brake fluid at the store should suffice, and give you good performance.
Old 09-04-2011, 11:02 PM   #20
#87
#87's Avatar
I guess I didn't know that Brake fluid had a minimum operating range as all the fluids only list maximum temps (well minimum boiling).
I will get this tomorrow then. http://www.autozone.com/autozone/acc...entifier=21051
Thanks for the help, at least I learn this now and not on the brz/frs
Old 09-04-2011, 11:52 PM   #21
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Yeah, DOT3 is good enough for DD car
Old 09-05-2011, 02:02 AM   #22
4agze
4agze's Avatar
Drives: Toyota Corolla SR5
Had same problem in my g20 sticky rear brakes changed pads, rotors, calipers turned out it was my brake master cylinder
4agze is offline   Reply With Quote
Old 09-05-2011, 07:17 PM   #23
Neutral_Eyes
Softparker
Neutral_Eyes's Avatar
Drives: 2002 Mazda Miata
I alternate between ATE Super Blue and Typ 200 and haven't had any problems with them on the street.
Neutral_Eyes is offline   Reply With Quote
Old 09-09-2011, 03:55 PM   #24
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
BTW, this is completely wrong. Fluid can boil at x temp, it's a hydraulic fluid that flows perfectly fine at ambiant temp.
I've used ATE Super Blue and Typ200 for almost 12 years, hundreds of thousands of miles, and a lot of Motul too. They are perfectly fine for street use and great for the track too.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 09-09-2011, 04:45 PM   #25
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Cool! iv known some people that have used high boiling brake fluid ATE also for several years with no problems. While others i have seen had braking issues because of the fluids. The cars varied from 1986 Honda accord to 2005 ford escort, and many others. And the problems have gone away for many of those cars by switching to a lower grade fluid ak DOT3/DOT4 standard.
You could be completely right that the fluid is not the problem, and that all brake calipers works at any normal hydraulic temp. And i am completely wrong. But from my personal experiences It does make me question the validity and application of that fluid in certain situations or for right conditions.
I can only give advice to others that iv seen and witnessed to do good, and not give harm to anyone. If its wrong, then no harm done.
Old 09-09-2011, 04:55 PM   #26
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Between myself and the other 50-60 track guys I talk to often, no one has ever had any issues like that. I usually change to super blue within 1,000 miles on all of my cars (because that's about how long I own them before tracking them the first time). So just on two of my current cars that's about 275,000 miles of super blue usage
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 09-09-2011, 05:51 PM   #27
Random_Art
professional smartass
Random_Art's Avatar
Drives: 16 speed mountain bike...
ok... here's a question. What's the best procedure for changing out the brake fluid? Draining the master cylinder and refilling it with fluid of choice and then opening up the valves on the calipers to push through the new fluid?
Goodbye Celica, you served me well.
http://artsofrandomness.blogspot.com/
Random_Art is offline   Reply With Quote
Old 09-09-2011, 06:05 PM   #28
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I never drain the MC res first, out of laziness. I just bleed it through the system.. again being lazy. Or use a vacula :P
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 07:07 PM
$109 Track Day@WillowSprings-Big Track-August 13-14 in Socal Louie Southern California 1 07-26-2011 04:34 AM
$125 track day at Willow Springs-Big Willow Track-February 5th in SoCal Louie Southern California 3 01-07-2011 10:26 AM
FT-86 to debut new GPS-track day technology for use on track and GT5! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 17 01-30-2010 11:30 AM
How much do you like heel-toeing or left foot braking? USMCMike Other Vehicles & General Automotive Discussions 20 01-15-2010 04:20 PM
