Old 09-03-2011, 12:03 AM   #1
CyberFormula
CyberFormula's Avatar
Drives: gti, nsx, integra type r,porsche911
towing capacity?
Was thinking about this alot.
I like to have a Tiny trailer to hold a set of track wheels/tires and tools (big enough to hold 8 wheels/tires, and perhaps a motorcycle as this same trailer will be used for motorcycle track days too even if FRS won't be towing it on those days).
Was wondering if anybody would think this car could make it.
Yes I know we dont' know about this vehicles towing capacity.
But i was curious if there are examples of low power/sports cars that tow their own trailers ...rather than use a truck/suv.
CyberFormula is offline   Reply With Quote
Old 09-03-2011, 12:16 AM   #2
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
Some time ago I asked a somewhat similar question and one forum member pointed me this page of towing a small trailer for tires and track gears.
http://www.mainstreet-data.com/trailer/index.htm
So even if by spec Miata was not suppose to tow anything, there are people who are doing that. They probably did it with class 1 or less trailer hitch.
I think this was embedded in the great debate of trunk or hatch.
Want.FR-S is offline   Reply With Quote
Old 09-03-2011, 12:27 AM   #3
CyberFormula
Thanks for the info.
It just doesn't make sense to buy a whole other TRUCK/SUV which I'll have to pay insurance/gas on only to be used for towing.
I found this picture...its a good size trailer...for a bike and I can see myself strapping on tires on it for the FRS.
Still searching for something smaller than that trailer though in the picture.
s14 spec similar to frs?
Old 09-03-2011, 12:47 AM   #4
fatoni
its not just a power game. you need to spring strength or travel to bear the load. a spec miata might be able go get a little more than a stock miata because the springrate is 4x higher and not designed to ride on the bumpstops under normal conditions
Old 09-03-2011, 05:19 AM   #5
[es vi: eks]
Drives: Subaru Legacy
Trailer hitch would be handy...
I would only use a trailer, Twice or 3 times a year if that?
I dont want another vehicle just for a trailer hitch.
I'm sick of these mother f***ing earthquakes on these mother f***ing plains.
[es vi: eks] is offline   Reply With Quote
Old 09-03-2011, 05:25 AM   #6
ToyotaObsession
ToyotaObsession's Avatar
Drives: 2008 XRunner
You probably wouldn't be able to tow more than 500-750 pounds including the trailer. Then there's mounting it, and clearance issues.
I did see a 370Z with a damn hitch molded into the middle of the bumper. Very odd.
“From the beginning, the concept was to put the driver back in the driver’s seat, and to eliminate computers as much as possible today. Powerful sports cars use a lot of computer technology so that anyone can drive and handle them. We decided not to go down that road.” - Tetsuya Tada
ToyotaObsession is offline   Reply With Quote
The Following User Says Thank You to ToyotaObsession For This Useful Post:
strat61caster (08-20-2013)
Old 09-03-2011, 10:50 AM   #7
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
A hitch will be made I'm sure and I'll install one just like on my other cars for hauling tires, mountain bikes, etc
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 09-03-2011, 12:14 PM   #8
Allch Chcar
Drives: N/A
The Standard tow ratings that I see for cars is 1000lbs max.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 09-03-2011, 12:59 PM   #9
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
One of the reason I want to buy this car is because I can put the race tires in the back and I don't need a trailer. Otherwise I'll just get a Miata for track.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 09-03-2011, 07:47 PM   #10
CyberFormula
I think 1000lb towing is good enough for 8 rims+ tires
Probably going to be 17lb rims x8 = 138lbs
138lbs + (weight of 8 tires) + plus the trailer hitch= ?
When I want to tow the motorcycle and tires, I'll be using the Subaru instead.
Now...to find a trailer that meets that need...
I only found trailex.com
I'm looking at the Utility Trailers.
The Following User Says Thank You to CyberFormula For This Useful Post:
JMon85 (05-12-2017)
Old 09-05-2011, 12:16 AM   #11
iff2mastamatt
Feeling Iffy?
iff2mastamatt's Avatar
Drives: it like I stole it
My FT won't need to worry about having anything hanging off it's but.
iff2mastamatt is offline   Reply With Quote
Old 09-05-2011, 05:16 AM   #12
Type[R]+
Type[R]+'s Avatar
Drives: Lexus IS-F
We get them straight from toyota (genuine) here for our small cars like Corolla and Rukus (scion dB?), so FT86 should be no different.
Type[R]+ is offline   Reply With Quote
Old 09-07-2011, 10:57 AM   #13
no_name
no_name's Avatar
Drives: 2005 Hyundai Accent
The Impreza/Legacy platform is great for towing, so if the FRS is in fact based on that platform then towing some tires or a bike should be fine. It will be the weight of the trailer that you'll have to watch out for. If you plan on towing often, you might want to install a temp gauge for your transmission oil, or a full oil cooler system. And you can usually tow more weight if your trailer has built in brakes.
Also, I LOVE that Forrester towing the 86.
no_name is offline   Reply With Quote
Old 09-07-2011, 11:27 AM   #14
oneday
Opinionated
oneday's Avatar
Drives: Something Red
While that might look cool...the Forester towing an AE86 is really cutting it close for being not-so-smart...2400lb towing capacity; 1800lb car + 1200lb trailer.
That said, towing a small trailer with tires and wheels on it will be no problem for the FR-S.
Most of the cars I drive have nets for windows.
oneday is offline   Reply With Quote
