Old 11-26-2012, 11:51 PM   #1
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Racecomp Tarmac II Clubsport coilover
Saw these pop up on my newsfeed today, i'm sure Myles or one of the guys will give us some more info soon but i think they are available for pre-order.
Old 11-27-2012, 10:10 AM   #2
miwialex
Drives: 2013 Whiteout FRS
yea i saw this as well. might have to give them a call today . . .
miwialex is offline   Reply With Quote
Old 11-27-2012, 12:56 PM   #3
mike2100
mike2100's Avatar
Drives: 23 BRZ
I forget - what's the target market for these? Mostly street with a little track time or mostly track oriented?
btw it doesn't look like you could possibly design in much more travel than that! <3
mike2100 is offline   Reply With Quote
Old 11-27-2012, 12:59 PM   #4
Hanakuso
I'm also interested in the differences between these and the normal KW V3
Hanakuso is offline   Reply With Quote
Old 11-27-2012, 01:06 PM   #5
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Subscribed. I'm very interested in these. On Facebook it was mentioned that they'd cost about the same as the KW V3s.
Grimlock is offline   Reply With Quote
Old 11-27-2012, 01:53 PM   #6
spitz
spitz's Avatar
Drives: '13 SWP BRZ-L
Subscribed as well!
spitz is offline   Reply With Quote
Old 11-27-2012, 04:25 PM   #7
Racecomp Engineering
More aggressive and shifting the range upward some to accommodate firmer rates yet still able to use the softer rates ( still firmer than the standard v3) for street use. so standard will be 400/400 but capable of 600/600 which after testing with 500/500's will be in order for those using slicks, Hoosiers, or running time attack. As well we can do custom rates offset for your needs ( 400/450 etc)
Myles
Old 11-27-2012, 04:42 PM   #8
JoeBoxer
JoeBoxer's Avatar
They look great too, i know function > form but still am surprised at why so many coilovers use such strange colors i guess it's a marketing thing.
Old 11-27-2012, 05:18 PM   #9
Calum
That Guy
Drives: 2013 asphalt FRS MT
So how do these compare to the JRZ coil overs you guys were offering?
Old 11-28-2012, 12:01 AM   #10
Several ways to skin a cat. Price point alone is VERY different. These are an offering in the 2k range while the JRZ are over almost 4k.
Monotube versus twintube. The JRZ is basically a race shock for the street and allows you to adjust nitrogen levels internally. The T2 is more of a Clubsport level shock for track day, time attack and autocrossing yet has a strong warranty and can take some serious abuse at the same time.
2 VERY different approaches to damping.
The T2's offer a lifetime warranty and are stainless steel and wont rust. The T2's are a 2 way shock while the RS-1 is a single adjustable. Yet one could run a LOW spring rate and yet raise the gas pressure in the RS-1 and have massive amounts of "platform" for cornering yet SERIOUS comfort for wives/back issues/new borns/nasty NYC-Detroit like roads.
So the bottom line is each of these serves a particular end user.
I love both. Both are major confidence inspiring dampers that wont disappoint.
Myles
Old 11-28-2012, 11:28 AM   #11
miwialex
just talked to you guys yesterday about pre ordering a set, I can't wait!
Old 11-28-2012, 11:32 AM   #12
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Is there front and rear camber adjustment on these?
Old 11-28-2012, 01:49 PM   #13
meeks
slide to unlock
meeks's Avatar
Drives: 2013 FR-S Raven Black
Myles
nice! will you have a pre-order thread soon (i apologize if there is one already)
been waiting for this
meeks is offline   Reply With Quote
Old 11-28-2012, 02:01 PM   #14
JoeBoxer
JoeBoxer's Avatar
No, i'm sure they will offer some really awesome forged plates to go with them though for the front
rear you will have to use lower control arms or whiteline camber bushings
The RaceComp Engineering BRZ "Clubsport" Build Racecomp Engineering Member's Car Journals 100 12-18-2014 02:18 PM
Street/Clubsport brake pads for your BRZ and FR-S HP Autowerks Brakes, Suspension, Chassis 4 02-20-2013 01:34 PM
Street/Clubsport brake pads for your BRZ and FR-S HP Autowerks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 10-15-2012 07:03 PM
Racecomp Engineering coilover sales: JRZ RS1 and KW V3 Racecomp Engineering Brakes, Suspension, Chassis 29 09-17-2012 10:46 AM
Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 12:24 PM
