#155 |
Drives: 2013 FR-S Hot Lava
Anyone here have the 16" steelies from Tirerack?
Are they hubcentric? Any problems fitting on our cars or good to go?
Live to drive another day
#156 | |
Drives: Asphalt fr-s 6mt
#157 | |
Drives: '13 SWP Sport-Tech (Limited)
http://www.costco.ca/wcsstore/Costco.../100018256.pdf |
#158 | |
Drives: FR-S Firestorm 6MT
So X40867 is the part # you need in a 16".
#159 |
Already ordered them weeks ago. X40867T's. Just over $100 with Taxes for the 4 of them. No cost to ship. Not bad considering all 4 weighed like 100 pounds.
With wheels, tires, installation, everything, cost me under $1000 for Michelin X-Ice Xi3's. Everything from/done at Costco. |
| The Following User Says Thank You to Enemies For This Useful Post: | spikey_dogg (11-26-2012) |
#160 |
Canadian
Drives: Frieda: Firestorm/MT (11/28/2012)
I got the X40867s and the dealership is telling me the 205/55/16 tires I also bought won't mount on the rims. The same tires mount on their other 16" rims without issue apparently.
Just a heads up. I am returning the rims. |
#161 |
Drives: Scion FRS Ht Lva(AT)
Did they bother to tell you whey wouldn't mount on the rims?
#162 |
Canadian
My sales guy explained it vaguely and honestly I didn't really understand what he meant. I don't have a clue how you get the rubber around the steel but they mentioned hitting the max PSI before they might damage/blow out the tire... Apparently one of the steelies was "scuffed" in the attempt and was sent to the body shop to be repaired. My guess is that it was actually somehow size related and it was bent/mangled somehow. They said if Costco won't take it back (unlikely) then they'll buy the damaged one off me.
They are apparently going to give me 16" alloys for $70 each instead (less than $30/wheel upgrade cost after I return the steelies), and I'll be done with the hassle for a good few years. |
#163 | |
Drives: Subaru BRZ Limited
#164 | |
#165 |
Mounted 205/55/16s on 16" hub centric steelies no problem.
#166 |
Same here.
#167 | |
Canadian
I am pretty sure they are being honest - they told me about the scuff and that it was sent to their body shop, and said they'd buy the one off me if I couldn't return it. |
#168 |
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
Yes I bought the 16" from tirerack and installed last weekend (right before it snowed in the adirondacks, perfect timing) and they installed no problem.
| The Following User Says Thank You to Rossman For This Useful Post: | whtchocla7e (11-28-2012) |
| FS: 245/40/18 Michelin Pilot Alpin PA3 Snow Tires | Chuynh207 | Wheels and Tires | 3 | 11-06-2012 01:19 PM |
| snow tires | debs0712 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 10-18-2012 12:58 PM |
| what tires will you be using this winter for snow? | denverizzles | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 08-01-2012 11:20 PM |
| How effective are snow tires? | theredtape | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 06-18-2012 07:49 PM |
| Snow tires? | smbrm | CANADA | 12 | 05-27-2012 01:20 AM |
