Old 11-26-2012, 06:45 PM   #421
CSG David
CSG David's Avatar
The Essex AP Racing BBK is pretty ridiculous. I don't think the brake pads were even bedded in properly on a heavy braking track. I must give props to Essex for developing such a monster brake kit that actually works quite well with the factory braking system.
The Following User Says Thank You to CSG David For This Useful Post:
SubieNate (11-26-2012)
Old 11-26-2012, 07:58 PM   #422
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
They are making C300 and S100's for OEM rear fitment, but I don't believe that they have been released yet. At least I don't have mine yet Hopefully they'll come in this week or first half of next week and I'll just pick them up at Essex next week.
The S100s for the rear are out. I have them in my car as we speak.
mines13 is offline   Reply With Quote
Old 11-27-2012, 08:50 AM   #423
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Jeff or anyone else, are you expecting anymore AP Racing pads for this kit or the OEM rear? I've been reading up and it seems there is a AP Racing H200. It's less aggressive then the C300 and cheaper. I'm just not sure what to match up the rear with the C300, other then the upcoming C300 rear pads
The AP Racing S100 pads in the OEM rear shape are here and shipping. The AP Racing C300 pads are in transit and should ship before the end of the week. I know we held a couple of the orders that had both compounds, to consolidate the shipments.
Finally, the front AP Racing S100's for the Sprint System are also due in tomorrow or Wednesday.
So if you any of the AP Racing pads on back order, you should have them next week. Thanks for your patience!
As for the H200 compound, we pulled that one from the lineup to simplify things. My recommendation would be to run the Ferodo DS2500 if you're looking for a light duty race / autoX pad. The other option would be the CL Brakes RC5+. Those are both excellent choices. They will squeal a bit on the street, but they are livable IMO.
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
The Following 2 Users Say Thank You to JRitt For This Useful Post:
Hanakuso (11-27-2012), mines13 (11-27-2012)
Old 11-27-2012, 12:48 PM   #424
Hanakuso
I got up to step #7 and realized I misplaced my 10mm hex socket so i'll finish it up tonight. Instructions are extremely easy to read and understand. One small question, how much torque should I apply for the pad retention bolt? I'm guessing it's not too important but thought I should ask.
They look so pretty I don't want to use them
Hanakuso is offline   Reply With Quote
Old 11-27-2012, 12:50 PM   #425
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Thinking about getting those front and rear when it's time for brakes or i feel the need to upgrade, how is the noise on the street?
Old 11-27-2012, 12:58 PM   #426
Hanakuso
I believe Dave-ROR has them. I dont recall him mentioning anything about any noise tho
Old 11-27-2012, 01:26 PM   #427
mines13
mines13's Avatar
The 300s are LOUD. I have the 100s for the front on the way, it is pretty bad on the street. That said, the brake kit fits and feels amazing. With the 100 in the front I have little doubt it will be excellent for aggressive daily use with quick pad swaps for track days.
The Following User Says Thank You to mines13 For This Useful Post:
JoeBoxer (11-27-2012)
Old 11-27-2012, 01:55 PM   #428
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
11 lbs-ft (14.9nm)
Bleeders are 12.5 lbs-ft per AP Racing.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Old 11-27-2012, 01:58 PM   #429
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
The S100 makes noise also, but they are livable. The C300s are NOT livable on the street. C300 = frieght train brakes, S100 = a lot less, but still low speed squeal. The S100s are still an agressive street/light duty track pad. Jeff likely has other options for a completely silent street pad, he offered for me to try something else but I don't mind the noise from the S100s.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-27-2012, 01:58 PM   #430
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
This is accurate
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-27-2012, 02:12 PM   #431
Hanakuso
Jeff gave me a great deal on the Hawk HPS to hold me over till the S100 come in stock. I'm guessing they will be dead silent since I know a few people that run these on other cars and they don't make noise. Although I'm not planning on using the grease
Old 11-28-2012, 02:14 PM   #432
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
So I rebled brakes last night and while not thinking I torqued the bleeder bolts to 20.8ftlbs instead of 12.5. Oops, oh well nothing broke I bet they won't leak
I was torqueing some other bolts and just forgot to change the damn torque wrench setting.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-28-2012, 03:20 PM   #433
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
BTW, the OEM wheels will clear with 10mm spacers.. it's fairly close, maybe 2mm clearance but it works for my needs (flat tire is the only time I'll be using the OEM wheels).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
MSTiFK8R (11-28-2012)
Old 11-28-2012, 03:33 PM   #434
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
@JRitt - I'm not sure if this has been covered here, but what is your opinion on using calipers with no dust boots on the street? Obviously the temperature and use extremes seen would be much less, but on the flip side there is likely going to be much longer periods of time between inspections/bleeds/etc. than on a track only car.
Thanks,
Nathan
SubieNate is offline   Reply With Quote
BC Racing Coilovers with Free Stainless Steel Brake Lines!!! Dustin@Dynosty Brakes, Suspension, Chassis 21 01-08-2013 10:34 AM
SS Racing Brake Line K1 Motor Works Brakes, Suspension, Chassis 5 06-29-2012 02:36 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
