#29 | |
The Answer
Drives: Mazda 2
EDIT: So, is GM the only company doing pushrods engines for cars now? |
#30 | |
Drives: Car
And Chrysler in the new HEMI (5.7-6.1-6.4) and 8.4L Viper V10. Last edited by LSxJunkie; 11-23-2012 at 06:45 PM. |
#31 |
Drives: Nevermorange FRS
I think the only thing GM has done recently that was "bold" was fly their private jets down to their meeting with congress to ask them for their bailout. That was pretty bold if you ask me.
Edit: that was a lowblow, I'll admit. These pictures Zcan posted of the comparisons of V8's was terrific. That's excellent argument for pushrods if I've ever seen one. Last edited by rice_classic; 11-23-2012 at 06:14 PM. |
#32 |
That Guy
Drives: 2013 asphalt FRS MT
I always figured GM kept the push rod in their flagship for the same reason Porsche keeps rear engines their flagship. It gives their customers that warm fuzzy feeling.
#33 | |
Kuruma Otaku
A side by side if the LT1 and whatever the DOHC version is called would be interesting. Back in the day that made 4 valves look like they dominated OHVs.
Because titanium. |
#34 |
Drives: SWP BRZ LTD
wow this thread. GM makes some amazing pushrod engines and if you look at how much these engines have improved over the years it makes the "selling outdated tech" argument invalid.
There is a good argument to made that dohc engines will get better fuel economy in theory, but as far as NA hp per the weight and total size of the engine GM's pushrod v8's are pretty damn good. |
#35 | |
Drives: '06 AM V8V Coupe
#36 | |
Drives: '23 BRZ
For the same engine *mass*, you can have a much much larger-displacement OHV engine, as DOHC adds a lot of mass (and physical size). |
#37 | |
Drives: '23 BRZ
The bigger, heavier, less aerodynamic Camaro SS gets better mileage than the smaller, lighter, more aerodynamic M3 with the same power. Buicks used to get amazing mileage for big/heavy luxury cars with OHV V6s. Mileage went down when they went DOHC. Last edited by ZDan; 11-24-2012 at 09:55 AM. |
#38 |
Drives: '13 BRZ in WRB--let's mod!!!
Me...
I'm very partial to my old DOHC LT5. My motor is an ex-World Challenge built w/ slightly higher duration cams & 368ci (vs stock 350 sitting in the garage). It pulls like a freight train to the 7550rpm cutoff. Most cars I've had started laying down while approaching redline--not this one... I have to watch the tach like a hawk, or I'll smack the limiter because it's still @ peak HP. I've had several C5 & C6 Z06s & they've all been sold & my old ZR is still standing after 18yrs... It is much larger/heavier than the LSX & new LT variants coming out in the C7, no doubt; but nothing sounds like that WOT pull to redline like an LT5
#39 | |
Kuruma Otaku
The only area where single intake valves out perform dual is at flow at 0.25D lift rate (when the valve head is theoretically no longer an obstruction) with the same port area. Basically for the same un obstructed flow area, a single large port will outflow 2 smaller ports with the same combined area as the big single. This comes from turbulence between the two air streams, and ends up with around 90-95% of the single. However, there are a few catches. First is that the 2v will need more cam lift to reach the same .25D since the valve is much larger. This means it takes slightly longer to reach max flow, is harder on the valvetrain, and can compromise compression. Second is the 4V heads dominate at low lift since in that situation, when the valve is still the primary obstruction, it is lift x valve circumference that is the flow area, rather than port (minus stem). This gives 4V much better midrange for the same max power. It sounds strange, but there are few modern situations where we can directly compare them on motors of the same displacement. Third is combustion chamber shape. The layout of a pent-roof 4V allows better flame propagation/efficient burn from the same compression ratio, which means either more power or less fuel. So in short the OHV's advantages are not from 2V heads, but from its cost and packaging.
Because titanium. |
#40 | |||
Drives: '23 BRZ
For V-engines of the same cylinder count, 2v OHV will generally be comparable to or superior to 4v DOHC in terms of power/engine size (external dimensional engine size, not displacement), power/engine weight, and fuel economy for the same power levels. Quote:
For fixed displacement, no doubt DOHC 4v pentroof is the way to go. But if you're not displacement limited... |
#41 | |
Kuruma Otaku
Here's a good example of why GM clinging to OHV has a bad rep. Vortec 4.3L V6, 190hp @ 4500 rpm, 260 lb-ft @ 3400 rpm. Compare with Toyota's 5VZ-FE of the same era. 3.4L V6, 190 hp @ 4800 rpm, 220 lb-ft @ 3600 rpm. There was no need for Toyota to go bigger to meet their requirements. If they matched the displacement it would be an embarrassment for GM. Now GM can talk about the packaging advantages all they want, but in this example it is complete bullshit. Because GM just showed how cheap and lazy they were, and made that motor by chopping two cylinders off of their small block V8. Which ended up with a 90° V6. Not exactly compact... So there is a lot more than just OHV = smaller motor to consider. Kind of like the solid axle = suck argument.
Because titanium. |
#42 |
Lower frictional losses? If you make a 2 valve OHC engine, you'll have less frictional losses. The extra valves are useful though :P
I'm not convinced there's less friction. Pushrods add a lot of mass to the valvetrain, and the valvetrain is one of the largest sources of friction power in the engine. What is the practical rev limit of an OHV motor? I imagine even with titanium pushrods, titanium lifters, titanium valves, the limit is a lot lower because of the mass. DOHC motors with normal steel valves can hit 15000rpm on motorbikes, they just have very stiff springs in there. Over 200hp/L might possibly make up for less displacement per unit mass. This is obviously an extreme case, but I bet at the same reliability levels, OHV can tolerate much less revs. |
| 100 hp/l NA engines | einzlr | Other Vehicles & General Automotive Discussions | 95 | 11-15-2012 07:55 PM |
| What other engines fit our transmissions | 1strwdcar | Engine, Exhaust, Transmission | 36 | 08-02-2012 04:45 PM |
| So you think you know engines? | Ryephile | Other Vehicles & General Automotive Discussions | 43 | 02-04-2012 03:49 AM |
| different engines for different domestic markets?! | Abflug | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 10-02-2011 08:04 PM |
| Subaru engines' weights | Allch Chcar | Other Vehicles & General Automotive Discussions | 19 | 04-30-2011 12:10 AM |
