| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: BRZ DGM Limited
Does the ride quality change with time??
My BRZ handles like a dream, but this is the first sports car I've had with low profile tires/sport suspension. I find the suspension slightly harsh (can feel every road imperfection, which we have alot of in NJ).Tires set at 36 psi.
Only have 100 miles on the car and wondering if those with more miles have noticed any less "harshness" with time?? No flames please...like "you should have gotten a minivan instead" ! |
#2 |
Drives: FRS
Not gonna change anytime soon unless you find softer springs. The car is made to handle.
#3 |
The Answer
Drives: Mazda 2
Technically it will get softer with time as everything wears down, bushings, shocks, the chassis, etc...
Will you be able to feel it? Maybe in 100 000 miles lol |
#4 |
Drives: '89 911, '06 GTI, '13 BRZ
My BRZ was pretty "bouncy" over certain types of road bumps at first. Over the next several hundred miles it settled down. I think the BRZ has an amazing mix of suspension tuning. It has that buttoned down feel that BMW's used to have, never soft but never crashy.
This car continues to amaze me. Now at 5,750 miles and just enjoying the heck out of it on every drive.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe 2006 VW GTI/DSG 2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten 2014 Nissan Murano SV |
#5 | |
The more I drive it, the more I want to drive it again! |
#6 | |
Drives: 2013 SWP Subaru BRZ Premium
#7 | |
Drives: 2013 WRB BRZ
#8 |
Drives: Supercharged Golf Cart
My RSX-S started showing signs of suspension wear at 50k. By 80k you definitely wanted to replace the struts to have the original feeling maintained. If you don't replace them then you get a bouncy ride.
I imagine the same applies to this or any sporty car with a tight suspension. |
#9 |
Drives: 2013 SWP BRZ
Tire choice has a lot to do with the feel as well. I recent put on the some General winter tires and the sidewalls have a lot of flex which you can feel in the handling of the car. The car is a little more willing to get sideways on dry, cold pavement. Put that's the sacrifice I'm willing to make for moderate snow capability.
#10 |
Drives: Mazda MX5
Tire pressure and sidewall section height (as well as tyre type) will influence how soft or harsh the ride is - as well as teh suspension. I can't remember what the section height is, but for example if you have a 205/45R-17 then a 205/50R-17 might ride a little softer, but it may affect the handling also depending on how strong the sidewall is. BRZ has slightly softer shocks in the rear more stiff in the front. When they need replacing you may want to put the OEM FR-S shocks in the front as they are valved a little softer. However, anything you do to change the ride will also affect how the car handles. If you wanted a softer ride to fit the local roads, perhaps the BRZ wasn't the best fit. I drive a Miata and I feel like the BRZ is a little softer riding (but that may hanve more to do with overall chassis size and weight).
#11 |
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Some adjustable dampers, like Bilstein or Koni, with the stock springs may be more comfortable. I find the stock setup pretty good though.
#12 | |
Drives: Over the hill WRX
#13 | |
#14 |
Member of the year - 2016
Drives: Scion FRS
Minivans ride like shit.
Go back to school, get a good job and buy a Rolls Royce. Your welcome. Ditch the family while your at it, waste of money.
| Gas Quality | Bonburner | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 37 | 03-04-2013 08:55 PM |
| ISIS Catback quality? | lbroskee | Engine, Exhaust, Transmission | 19 | 12-03-2012 11:25 PM |
| Time for the second oil change yet? | ProTekk | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 11-16-2012 03:13 PM |
| Lowest quality spring? | Synack | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 07-26-2012 12:00 PM |
