Old 11-20-2012, 10:24 PM   #15
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
No I haven't and thanks for the tip. A buddy of mine said his dad couldn't get a bolt of his ac compressor years ago and had to buy something that removes rounded/stripped bolts. I wonder if this is what he was talking about because he is going to bring them over.
Anyways I will want a set for myself. I'll check amazon
Originally Posted by RallySport Direct View Post
Glad to see that some people still do things the right way. Have you tried using an extractor like these?
I picked up a cheap set from a parts store a couple years ago and there have been a couple times that I thought I was going to be drilling bolts, and these worked great.
-Zach
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 11-20-2012, 10:25 PM   #16
ngabdala
BTW, do I have to go through my dealership or Subaru for the bolt or can they be found at hardware stores?
Old 11-20-2012, 11:07 PM   #17
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
You could use hardware store bolts, just make sure you get the same grade of bolt, or higher and you should be fine. But if the dealer has it in stock, and it is not too expensive, I prefer that over going to a couple different hardware stores searching through bins of bolts to find the right one. Either way, good luck and let us know how it turns out.
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
The Following User Says Thank You to RallySport Direct For This Useful Post:
ngabdala (11-20-2012)
Old 11-21-2012, 07:37 AM   #18
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Thanks,
Rick
Agree. I had to buy an exhaust bolt, and while it was expensive at 4.50, it was worth the piece of mind having the designed bolt in place. I tried at the hardware store and found "similar" bolts, but for what? to save $2... not worth it :happy0180:
Old 11-21-2012, 07:43 AM   #19
xjohnx
Grip>Slip
xjohnx's Avatar
-Zach
used these to remove wheel locks from my STi when the previous owner had lost the key. worked great.
Old 11-21-2012, 08:04 AM   #20
Sportsguy83
Drives: Limited BRZ
Wow! Pretty safe those wheel locks huh?? (NOT bashing your particular wheel locks, just wheel locks in general including the ones on my car )
Crawford Performance Air Oil Separator install xn7485 DIY (Do-It-Yourself) Guides 10 09-25-2013 08:58 PM
Crawford Air / Oil Separator - 13+ BRZ/FRS/GT-86 ngabdala Engine, Exhaust, Bolt-Ons 11 06-10-2013 09:22 PM
