#505 | |
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
#506 |
Conedancer
Drives: 2013 Subaru BRZ SWP
Well, Starting to gather some more things for the winter.
-LCA Bushings -Rear Lateral links -Crossmember bushings -Engine and Tranny mounts Holding off on a Tune and Exhaust components til more become available to be able to have a better choice. I am not saying that whats available right now is not good. I am just not convinced they are the best for my application until more stuff becomes available.. Working on a 2nd set of rims and tires but waiting til after SEMA to find out whats available.. It looks as though theres alot of folks jumping into the STX Fray. which is good. I hope its at least competitive. ![]() Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#507 |
i'm sorry, what?
Drives: Canada
i'm finding that the local autocrosses put me in between gears,
i'm thinking of running 16X8/9 with a downsized tire so i can use 2nd with better efficiency your thoughts?
#508 |
Drives: 2021 Supra / 2022 Tundra
This is what I did with the CSP miata, ran 13's with a short tire so I could use 2nd on smaller local lots.
TomR
#509 | |
Drives: 2024 GR86/ 2015 FRS
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts |
#510 |
STX build in progress!
Drives: Whiteout FRS. Just Gorgeous!
Two scenarios I see here. If all you are going to run is local and you know you need the gear advantage, go for it. If you will be running any National level events I would stick with the 17's or if you afford both sets of race based wheels and tires go for that. If you are doing National level stuff I can promise you will want all of second gear and possibly have to consider a third gear shift vs. Banging the rev limiter in second every once in awhile.
#511 |
Spend the same money on a tune and get more mph in 1st gear? Harder on the engine (in theory), but probably just as fast - and a lot more fun around town.
#512 |
smaller wheels
#513 |
Conedancer
Update: added Hoodstruts and did the Grounding mod today..
#514 |
Drives: 4Runner
Can you define the grounding mod please?
diirk
waiting on a Neptune Premium MT |
#515 |
Conedancer
Grounding mod just ensures there is enough Grounding over stock and makes for it cleaner with less interference so all the electronics Work to their potential..including the ECU.. Its and old school mod...But it doesn't hurt..$2.50 Neg Battery cables from Wally world does the trick..and the come in various lengths..
![]() Bill
| The Following User Says Thank You to Scooby South For This Useful Post: | diirk (11-20-2012) |
#516 | |
Drives: 4Runner
diirk
#517 |
Conedancer
Front Shock towers to the engine...and one from the neg battery term to the Shock tower... you can see the cable in the pic under neath the strut mounting bolt..
![]() Bill
| Subaru/Scion warranty and autocross | Ribface | Tracking / Autocross / HPDE / Drifting | 55 | 06-17-2015 08:30 PM |
| Will you Autocross your 86? | Ribface | Tracking / Autocross / HPDE / Drifting | 131 | 06-22-2012 05:48 PM |
| Which autocross class? | jpdarty7 | Tracking / Autocross / HPDE / Drifting | 66 | 06-21-2012 05:53 PM |
| FR-S at a CA Autocross | oneday | Scion FR-S / Toyota 86 GT86 General Forum | 57 | 03-26-2012 03:38 PM |
