Old 11-20-2012, 11:23 AM   #1
empower-auto
Kouki-Monster
empower-auto's Avatar
Anyone using a 4-pt harness with stock seats?
How is it? Easy install? Which are you using?
I'm looking for something for light track duty in a 4-point. I have looked at the new Takata Drift type which are nice and ASM .. and also the standard Sparco 4-point.
I would LIKE to mount them without a harness bar which seems do-able with this car.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 11-20-2012, 11:51 AM   #2
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
http://www.ft86club.com/forums/showthread.php?t=19424
I haven't installed mine yet, but I will be removing the plate for the driver side child seat restraint and using a longer bolt to attach to the rear luggage shelf for the rear attachment, lap belt attachments are typical, doubling up on the 3 point belt and latch points.
Mine is a schroth Rallye 4-point.
Sccabrz192 is offline   Reply With Quote
Old 11-20-2012, 12:37 PM   #3
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
if you're doing light track duty then just have a little more confidence in your OEM restraint system
there is absolutely nothing wrong with a car that meets 2013 safety specs
if you find you're sliding around get a CGLOCK or just brace with your foot
The Following User Says Thank You to 7thgear For This Useful Post:
Superhatch (11-20-2012)
Old 11-20-2012, 12:38 PM   #4
empower-auto
Kouki-Monster
Bracing with your foot is not much good when you use it so much.
Honestly I'm looking for harness suggestions, not alternatives.
Rich Anderson
EMPOWER AUTO
Old 11-20-2012, 12:47 PM   #5
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
I'm pretty sure the correct solution is a harness bar or stock restraint. Getting an extended length 4 point means the belt has a chance to stretch in an accident if not perfectly adjusted, or you'll submarine underneath the belt harness.
If you are really concerned with safety then get a 5 point and a harness bar, otherwise just use your standard 3 point seat belt.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 11-20-2012, 01:06 PM   #6
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
the fact that you're asking about using a 4 point with the OEM seats just tells me that you are poorly informed about car safety in general
i gather you're a race photographer? I would stop trying to imitate the mistakes of others and start educating yourself on what's actually safe on a track for personal use.
Also just out of curiousity, how many Battle Endless or CSCS events have you been to as opposed to the Solosprint/Ontario Time Attack ones?
Old 11-20-2012, 01:14 PM   #7
Aznsky
Drives: Nissan 350Z (sold) 13' Whiteout FRS
Originally Posted by Superhatch View Post
If you are really concerned with safety then get a 5 point and a roll bar, otherwise just use your standard 3 point seat belt.
^Corrected
I'm not a big fan of harness bars. Reason is that the intent of the harness is to keep you strapped in place, and in the chance that you roll the car over, your head is basically stuck in place and the roof will crush your head first. With the oem 3 point style, it allows the body to bend sideways and away from the roof.
Now the chances of rolling a car over in autox is very slim, so a harness bar and 4 pt should be ok. But if the car is going to any sort of track, I'd highly recommend either the stock 3 point with a CG lock (and yes your left foot will get really tired from supporting you, I've had mine even cramp on really hot days) or a correct 5 point with a custom rollbar.
Just my opinion.
Aznsky is offline   Reply With Quote
The Following 9 Users Say Thank You to Aznsky For This Useful Post:
AZP Installs (01-30-2015), Dave-ROR (11-21-2012), ddeflyer (02-04-2015), DjDATZ (04-29-2015), FT-86 SpeedFactory (11-30-2012), G-Man (04-14-2015), mike2100 (11-28-2012), Racecomp Engineering (11-21-2012), Superhatch (11-20-2012)
Old 11-20-2012, 01:25 PM   #8
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
here is what FIA has to say about 4 points
scroll down to section 6.1 through 6.3
http://argent.fia.com/web/fia-public.nsf/DA58BF07DFFA863FC1257690003E34B6/$FILE/253%20%2810-11%29-161209.pdf
Old 11-20-2012, 08:01 PM   #9
my name is joe
I'm pretty sure the correct solution is a roll bar or stock restraint. Getting an extended length 4 point means the belt has a chance to stretch in an accident if not perfectly adjusted, or you'll submarine underneath the belt harness.
If you are really concerned with safety then get a 5 point and a rollbar, otherwise just use your standard 3 point seat belt.
Fixed
If you're concerned about safety you will not use a harness bar. One flip onto the roof that will cave in and goes snap of your neck because you were strapped in and couldn't move. Now if you had a roll bar it's a different story. Do it all the way or do none at all. CG lock will help you a lot. I've seen guys with stock belts out out better times than guys all kitted out.
my name is joe is offline   Reply With Quote
The Following 3 Users Say Thank You to my name is joe For This Useful Post:
AZP Installs (01-30-2015), Racecomp Engineering (11-21-2012), Superhatch (11-20-2012)
Old 11-20-2012, 08:55 PM   #10
celica73
I put a Schroth Rally 4 in my BRZ. Not too hard to install. I mounted the lap belt to rear mounts on the seat sliders. Intentional or not, there is a little notch in the sliders that allows the tab for the harness to slot in rather than actually sandwiching between the rail and the floor pan.
For the shoulder straps I used the anchors for the rear seat belt. The lap belt on on the inside, and the lower mount for the retractible mount on the outside.
Removing the side plastic bit is the hardest part. There is also a "gotcha" with the rear seat bottom. Remove the front bolt, then push down really hard in the rear and pull out. There is a tab that holds the rear seat bottom in place (it will pivot up and down on the tab).
If my belts weren't 10+ years old, I'd run them on track without hesitation. As it is, I probably will use them only for autocross.
Old 11-21-2012, 01:08 AM   #11
whataboutbob
AutoX-10/10ths every run
CGLock in use here.
Build thread:Here
Old 11-21-2012, 01:44 AM   #12
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
anybody mount here for 4 point?
Surok is offline   Reply With Quote
The Following User Says Thank You to Surok For This Useful Post:
ronnBOi720 (11-01-2013)
Old 11-21-2012, 02:23 AM   #13
fatoni
4 points are a waste of time and money. they arent safer than either a 3 or 5 pt harness. the issue here is submarining. if you dont allow your torso to move forward in a crash, your body is going to go under the seatbelt unless you have a 5 or 6 pt.
Old 11-21-2012, 02:43 PM   #14
Originally Posted by my name is joe View Post
Fixed
Originally Posted by Aznsky View Post
^Corrected
Just my opinion.
I agree with these guys. The "in-between" solution (harness bar with 4 points) is not a solution. Keep it stock or get a roll-bar with proper harnesses.
- Andrew
Harness Bar diirk Tracking / Autocross / HPDE / Drifting 38 07-21-2017 01:15 PM
wiring harness so26 Electronics | Audio | NAV | Infotainment 5 10-30-2013 03:19 AM
Race Harness with stock seats Sccabrz192 Tracking / Autocross / HPDE / Drifting 20 04-06-2013 03:25 PM
WTT: My FRS seats for your BRZ Premium Seats Hanakuso Interior Parts (Incl. Lighting) 17 03-04-2013 01:37 PM
Wiring harness sastexan Electronics | Audio | NAV | Infotainment 0 06-16-2012 11:41 PM
