#15 |
Bear in mind all our mpgs will go down now as we get in to the winter blend gas.
#16 |
aside from the fact that i think its stupid do just drive around in 4th on the freeway. this is the magic of these slow, low powered car. in my new 1.6 miata i get 28 no matter how i drive.
#17 |
Toyota Freak
Drives: Whiteout FRS
im averaging 18 - 19.
LOL
#18 |
Drives: Scion FRS A/T raven
26.8mpg avg
I am currently avg 26.8MPG due to hills on my routes.
But my habit has changed. I feel more confident when passing slower peeps on the freeway. I make it a point to drive at or slower than the speed limit on populated streets to be seen in my fantastic ride. Especially when cruising home on Pacific Coast Highway during sunset. I get a lot of stares and twisted necks. Even more when I put my Raven FRS through the touchless car wash before heading home. |
#19 |
Drives: '97 RSP JZZ30 GT-T
When I was breaking the car in i used to hammer it to 3.5k rpm then stop. Now I hammer it to 7.5k rpm
Germans>Japanese>Italians>Americans. Unless its a Corvette. |
#20 |
Shift Down
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
i drive the same. i came out of a 95 E36 M3 which was straight mechanical diff and trans. lol no tcs no vsc so i just turn all that nonsense off and drive like i normal would my foot is my tcs. gotta know how to use the throttle with the FR layout. a lot have said i like to leave it on to get used ot how it drives.. well itll be a llloottt different when you turn it off and start trying to drive the way you normally would if spirited drives are your thing.
i say learn the car with the crap off once you get good at that and want to leave it on youl know exactly how the car is going to handle. :-) thats just me though i live on the touge.
#21 |
Wayward Member
Drives: Hot Lava 86
Can't say I've noticed a change in my driving habits. I actually might drive the FR-S harder than I have cars before it, though I was pretty tough on my Mazda. The only difference is the FR-S seems thirsty for the abuse, the 626 kind of groaned about it. It worked well enough, but it was a pretty loud car and hit the higher RPM's on any hill.
That being said, the last two fill ups for my FR-S averaged 26-27 MPG. The computer is saying it's averaging 27.
#22 |
Not sure how this is bad? I don't abuse the car by dumping the clutch, constantly bouncing the red line limiter. I am how ever enjoying the car much more as it begs to be revved.
#23 | |
#24 | |
Drives: Raven M/T FR-S
#25 |
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
Each mile you travel at freeway speeds in 4th gear is causing much more wear on your engine components than mine will endure when I travel a mile in 6th gear. Wear in itself is not necessarily bad. However when you willingly cause excessive wear I consider that abuse.
#26 |
Drives: Ultramarine FR-S 6MT
Guys, let me tell you about my little habit... I must say, it's spiraling out of control. It's an addiction now....
![]() I just can't help myself!! |
| The Following User Says Thank You to Ingen For This Useful Post: | 86BRZ (11-23-2012) |
#27 |
Drives: 2018 Camry XSE V6
Haha! Every now and then I feel the desire to put it into VSC Sport and sport shifting. I'll see how that changes with winter approaching.
#28 | |
You'll just go with TC off and goof off until you're blue in the face in a parking lot
| The Following User Says Thank You to Ingen For This Useful Post: | Demandred7 (11-18-2012) |
| Changing the Horn? | mechaghost | Cosmetic Modification (Interior/Exterior/Lighting) | 21 | 10-27-2016 12:27 AM |
| Correlation between CEL issue and break-in habits | switchlanez | Issues | Warranty | Recalls / TSB | 8 | 10-17-2012 10:40 AM |
| Changing Premium to Limited? | zygrene | BRZ First-Gen (2012+) — General Topics | 32 | 10-09-2012 11:58 AM |
| Changing from 1st to 2nd gear noise | bazi | Engine, Exhaust, Transmission | 0 | 09-23-2012 04:17 PM |
| changing the side vents? | Tylub | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 08-31-2012 08:20 AM |
