Old 11-16-2012, 10:09 AM   #2227
JohnS_Rosamond
Drives: Mazda MX5
While I am not an engineer, my '06 4Runner also has the Automatic transmission "bump" in it. when creeping forwards from a dead stop, you may feel some kind of driveline lash. I can't explain it, but since I don't see a whole bunch of complaints on it over at the 4Runner site, I don't think that you have much to worry about.
JohnS_Rosamond is offline   Reply With Quote
Old 11-16-2012, 11:05 AM   #2228
Craig
Craig's Avatar
Drives: Asphalt FRS
I feel like the problems only going to get worse if I ignore it, it also sounds like some other members have ended up losing their car over it so I'm a little concerned. At the same time until it happens more frequently I'm not sure there's much I can do.
Craig is offline   Reply With Quote
Old 11-16-2012, 06:08 PM   #2229
Rob_g
Drives: 2010 4Runner Trail
There are actually many complaints about that and it's a well known issue. The axle yoke is 'sticking' when it telescopes due to axle wrap when braking. It happens on the 4Runner, FJ and other Toyota prado based vehicles. Incidentely, it seems Toyota finally released a TSB for this after many years of people complaining. If you lubricate the joint real well, this usually alleviates it for a while.
I can say with certainty as having had both an FJ and 4Runners, what I experienced was not the same issue. When I got the drivetrain 'bump' in my FR-S, it was happening every time I let my foot off the brake and then again when I put it back on. If this 'bump' is caused by a sticking axle yoke, it's probably only going to happen each time you stop and depending how hard you apply the brakes. This only happened once to my FR-S though so I have no idea what it was or if it was ever going to happen again.
Rob
Rob_g is offline   Reply With Quote
Old 11-16-2012, 07:28 PM   #2230
alexmotrix
rookie drifter
Drives: 1987 ae86, 1985 celica gts
Got ECU replaced this week, CEL had turned off by itself before it get replaced, car still run as great as before CEL, I can call it solved, for now...
alexmotrix is offline   Reply With Quote
Old 11-16-2012, 08:49 PM   #2231
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
So I started my car leaving a friend's house and it seemed to struggle a little bit; when it turned over it seemed to come to life a little less willingly than it usually does. It took the same amount of time to turn over, but started a bit weakly. Then, pulling into my garage, foot still on the clutch, the RPMs dipped way down and then shot up pretty high, before dipping way down again and shooting back up. I put the car in neutral and took my foot off the clutch and it seemed to idle OK. Do these symptoms sound like the CEL/Idle issue?
Subie is offline   Reply With Quote
Old 11-17-2012, 12:32 AM   #2232
Joesuede
Drives: Argento FR-S
Send a message via AIM to Joesuede
bad day
my car was idling strangely early today, i was on neutral, n it stalled, turn it back on, drove into a parking lot, n my CEL went on a few minutes after.
Hope it gets fix.. =l
Joesuede is offline   Reply With Quote
The Following User Says Thank You to Joesuede For This Useful Post:
eurospeed (11-19-2012)
Old 11-17-2012, 02:23 AM   #2233
zerodark
zerodark's Avatar
Drives: 2015 Series.Blue (WRB Pearl)
So my BRZ Limited (manual) is a shade over 1950 miles.. recently I have noticed that she seems to labor a little harder than usual at idle (no AC|car in neutral|foot off the everything but the brake).
Thus far I have seen no CEL (knock on wood) and I don't get the violent shaking as described by some owners, but at times it definitely feels like the engine is laboring during idle. She idles at about 650 rpms and even during the rough idling the tachometer needle never jumped (as it has for other owners). However, today was the first time I saw the tachometer move about 100 rpms under the same conditions.
Are these early signs of bad thing to come possibly?
zerodark is offline   Reply With Quote
Old 11-17-2012, 06:29 AM   #2234
SpeedmasterBRZ
Drives: Pearl BRZ Limited
Update:
The car was returned to me on 11/09. Weather here in Utah hasnt played nice for me to be able to drive much, but, what I have has been back to normal. No CEL or rpm idle fluctuations.
Will post if this changes.
Fix was new ECU and flash.
SpeedmasterBRZ is offline   Reply With Quote
The Following User Says Thank You to SpeedmasterBRZ For This Useful Post:
Old 11-17-2012, 07:47 AM   #2235
BRZnut
Drives: BRZ DGM Limited
Possible.. is your Vin in the range of those that have had the problem?
Old 11-17-2012, 11:53 AM   #2236
Little_Red_FR-S
Drives: 2013 Firestorm FR-S
CEL/tractions lights came on yesterday,so I took it to the dealer. Add me to the list at 2400 miles!
Little_Red_FR-S is offline   Reply With Quote
The Following User Says Thank You to Little_Red_FR-S For This Useful Post:
Old 11-17-2012, 12:32 PM   #2237
Yruyur
Yruyur's Avatar
So we have a great list going on. Have we gotten with all the other FRS brz forums to combine efforts?
Sent from my flux capacitor using Taptalk
Old 11-17-2012, 01:50 PM   #2238
zerodark
zerodark's Avatar
Yes.. 6020XX
Old 11-17-2012, 05:47 PM   #2239
AX FRS
Drives: Silver FR-S
cel sl poor idle etc etc
Same problem as all others.
Going to take it to dealership on Monday.
I've read thru all XXX pages of this and can't find the TSB. Anyone got a link to it?
I'd like to be prepared to do battle. Also any other DFW Texas owners with a recommendation for a good dealer? Lewisville Toyota is where I was going to take it.
Thanks
Jim H.
DFW Texas
AX FRS is offline   Reply With Quote
The Following User Says Thank You to AX FRS For This Useful Post:
Old 11-18-2012, 11:08 AM   #2240
jesperswe
Drives: GT86
There is no official TSB of it. Subaru had one out but it got removed again.
jesperswe is offline   Reply With Quote
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 06:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 10:00 AM
