Old 08-14-2012, 03:38 PM   #29
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Originally Posted by pyro530 View Post
I'm pretty sure I know what you're talking about because mine does the same thing and I'm pretty sure I know where the sound is coming from.
It's from the reverse lockout ring/mechanical..
Any idea how to fix?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 08-14-2012, 04:42 PM   #30
Yruyur
Yruyur's Avatar
It's been about a month and a half and I had this issue as well as the plastic pattern falling off. Toyota replaced the knob, the original knob was threaded too far down at the factory so they opened a ticket with Toyota. The rattle they attempted to address by putting grease on a part below the boot that slides on the shaft. The mechanic says there is too much play in that part and opened a ticket with Toyota. Mine still rattles.
Sent from my PH44100 using Tapatalk 2
The Following User Says Thank You to Yruyur For This Useful Post:
rice_classic (08-15-2012)
Old 08-14-2012, 04:53 PM   #31
pyro530
Drives: Ultramarine FR-S 6MT
I do not. I actually like the sound, so I will not be looking into it.
As far as I'm concerned, it's pretty standard on a transmission with reverse lockout. :happy0180:
Current: FR-S Ultramarine 6MT - Took delivery 05/30/2012 - Now for sale here
1995 M3 Coupe MT - the "Bavarian Bumblebee"
Past: 1994 Integra - Sold | 2005 Dodge SRT-4 - Totaled by Hail | 1997 Acura 2.2 CL slowmobile - Sold | 1991 BMW E30 - Sold | 1991 Acura Integra GS - Wrecked | 1971 Chevy C-10 shortbed stepside - Sold | 1973 Camaro Z-28 Clone - Stolen
pyro530 is offline   Reply With Quote
Old 08-14-2012, 04:55 PM   #32
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
Thanks for the info.
Hanzo is offline   Reply With Quote
Old 08-21-2012, 02:28 PM   #33
ultra
Curious cat.
ultra's Avatar
Updates or more info?
Old 08-30-2012, 04:32 PM   #34
travace
travace's Avatar
Drives: Scion FR-S
yea add me to the list of people who have this rattle. exactly as described. right at 4k rpm and going up. more noticeable in 2nd and 4th gear for me. sometimes it dont rattle tho but more often then not it rattles.
travace is offline   Reply With Quote
Old 08-30-2012, 04:43 PM   #35
SkullWorks
Drives: SSM LT MT BRZ
mine rattles but I found it to be the trim piece attached to the bottom of the oem knob (its a little stamped metal finisher that cavers the edge of the leather) I found that placing my finger against the base of the know stops the noise.
I put an extra hair tie around mine since I have long hair and they usually end up stored there anyway....
I have noticed the same noise in another FRS...but it doesn't help the people that claimed to have the rattle with knob removed.....
Old 09-03-2012, 08:11 PM   #36
_F-R-S_
Drives: 13 whiteout scion frs
I Get this noise when i accelerate like im in to high of a gear. but im not
_F-R-S_ is offline   Reply With Quote
Old 09-03-2012, 08:44 PM   #37
Brzce
Brzce's Avatar
Drives: WRBP BRZ Limited - Manual
Originally Posted by ATL BRZ View Post
My stock knob never rattled, but the Flossy knob that I just installed yesterday not only rattled, but the custom engraving wasnt lined up correctly when the knob was completely tight. I fixed the rattle and the alignment by removing the knob and wrapping the shifter threads with some plumbers tape and then pushing a rubber washer from an old garden hose sprayer that I don't use down into the bottom of the knob. No more rattles, no accidental spinning, and its perfectly aligned now!
Has anyone tried this fix on the stock knob?
Airaid 511-307 Intake - installed 08sept12
Brzce is offline   Reply With Quote
Old 09-04-2012, 01:19 PM   #38
Vino
3stars & a sun
Drives: FRS
Mine i have this rattle sound when i put in neutral while im cruising and getting ready to stop, did some of your guys has this problem ? Ill post a vids so u can hear it
Vino is offline   Reply With Quote
Old 11-16-2012, 09:50 AM   #39
ROBOSTIG
Drives: 2013 Firestorm Red FR-S MT
Mine is rattling as well. Taking it to dealer today with a list.
ROBOSTIG is offline   Reply With Quote
Old 11-18-2012, 10:00 AM   #40
nix
nix's Avatar
Drives: AVO BRZ
Hmm I have owned and driven a lottt of different cars with reverse locks and none had this rattle.
It's a resonant frequency from the gearbox, hope they can fix it.
nix is offline   Reply With Quote
Old 11-21-2012, 12:31 PM   #41
nix
nix's Avatar
Drives: AVO BRZ
I was messing around with it today and it's definitely the gap between the reverse collar and stick that's causing it. If you take the knob off and hold the collar up and push one side against the stick it fixes it. Leaving the knob on and holding it up makes it about 3/4 better.
Old 12-20-2012, 04:58 AM   #42
nix
nix's Avatar
Drives: AVO BRZ
Anyone else fixed it yet? My dealership has given up on it, I might take the whole lot to pieces and see what I can try.
Flywheel Rattle? CB762 Issues | Warranty | Recalls / TSB 119 11-16-2016 11:09 PM
Vibrating shifter fix! Superhatch Issues | Warranty | Recalls / TSB 51 06-05-2016 11:56 PM
Flimsy shifter chessplaya2010 Issues | Warranty | Recalls / TSB 1 07-31-2012 02:21 PM
A/C Rattle? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 08:46 PM
FR-S Shifter Video xravexboix FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 04-21-2012 09:20 PM
