Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 11-16-2012, 04:19 AM   #1
v3rgil
Drives: Toyota 86 Black (Standard)
Coil-overs \ Spring kit ?????
Coil-overs pro's and cons:
pro's: self adjustable ride height, toe and camber.
cons: you constantly need to adjust, as lock-nut comes loose and suddenly your left sits lower than your right (real pain in the ass) and every time you adjust you need to have wheel alignment done...........
Spring kit:
pro's: buy the height you want, and it stays that way
Cons: not adjustable (not really a con if you think about it)
for those that do want to lower there 86,
importparts.co.za sell a very nice set of H&R springs that offer a 30mm drop
that sits nice and gives you that sporty look and you wont even notice a change in ride comfort for R2300 http://www.importparts.co.za/catalog...ucts_id=164118
apparently Koenic also has a similar offer on the H&R spring kit.
v3rgil is offline   Reply With Quote
The Following User Says Thank You to v3rgil For This Useful Post:
Gp1666 (11-16-2012)
Old 11-16-2012, 07:11 AM   #2
Gp1666
Gp1666's Avatar
Drives: Toyota 86 std Dark Grey metallic
are there big differences in different brand of springs? im still rather new to this soo...
Gp1666 is offline   Reply With Quote
Old 11-16-2012, 07:16 AM   #3
Vic_RSA
The voice of reason...
Vic_RSA's Avatar
Drives: 2012 Toyota 86 6MT Standard
@v3rgil - why did you have to show me that website?! ;-) Some nice stuff! Already shopping for Gearknobs...
Vic_RSA is offline   Reply With Quote
Old 11-16-2012, 07:29 AM   #4
Crewzern
Crewzern's Avatar
Drives: 86
Yes...Koni, Eibach H&R are all excellent springs .....Koenic/nforce (dont think they make for 86) imo are no.
Crewzern is offline   Reply With Quote
Old 11-16-2012, 07:56 AM   #5
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
You'll blow your stock struts faster with just springs. It's the nature of the beast.
Rayme is offline   Reply With Quote
Old 11-16-2012, 08:16 AM   #6
v3rgil
They do have very nice stuff, don't they?????
Old 11-16-2012, 08:21 AM   #7
v3rgil
very much so, had eibach and TiEN at 45mm on my MR2, and there was quite a deference in the hardness of the ride,
I am told that the H&R @ 30mm are our best bet..... but some people are just all about brands no matter the ride
Old 11-16-2012, 08:23 AM   #8
gmookher
any non oe spring kit=not matched to oe dampers =potential shortened shock life
coilover=matched coil and damper=ideal setup
that said, both I and Jeff@perrin are rocking the h&r supersport coils which drop quite a bit but have some progression feel to them, they are so far so good on my ride, bunch of miles and track time too. Something I've been testing.
my theory is that with h&r you cut the oe bumpstops rather than replace them like with some other brands. this may be affording extra protection. I suspect the blown oe shocks are from bottom out/high rebound forces.
they drop a little more rear than they do front works great with the wl rear cross bushes. still, nothing like a matched set, ie, stock is great, or coilover if you want lower/stiffer
spring kit fine as a temp solution.
Old 11-16-2012, 08:24 AM   #9
v3rgil
on any other car i would say that very true, but the 86 comes with a descent suspension, so if you not planning on getting airborne or hitting every pothole you find, they should last a lifetime on 30mm drop.....
Old 11-16-2012, 08:27 AM   #10
v3rgil
thanks for the info, well said!!!!!
Are Ksport coil overs any good? Accurate Race Shop Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 10-22-2012 03:36 AM
Drop Springs rather than Coil Overs??? Kuneff Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-31-2012 10:16 AM
Coil Install + alignment in Bay Area? BlaineWasHere Southern California 21 08-27-2012 12:10 AM
XYZ Coil overs??? Juanito08 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-31-2012 09:12 PM
T1R Coil-over suspension AJ PwR Brakes, Suspension, Chassis 33 05-29-2012 10:07 PM
