Old 11-13-2012, 11:11 PM   #1
ric342
FR-S driver
ric342's Avatar
Drives: ULTRAMARINE Scion FR-S
brake recall?
i took my car today to the toyota in oxnard and they found out that one of the calipers in the rear was indeed leaking and that there was a malfunctioning switch or wire that sends a signal to the rear brakes and tells them when to do there job. Has anyone had this issue as well, please let me know and weather I should take any legal because the brakes failed.
ric342 is offline
Old 11-13-2012, 11:14 PM   #2
dsgerbc
Drives: BRZ(sold), STI
Pics of damage?
No brake recall that I'm aware of.
dsgerbc is offline
The Following User Says Thank You to dsgerbc For This Useful Post:
20valvewynn83 (11-13-2012)
Old 11-13-2012, 11:17 PM   #3
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
what kind of damage? did this cause you to have an accident or cause brake fluid to leak onto the paint?
Flat Black VW is offline
Old 11-13-2012, 11:29 PM   #4
ric342
FR-S driver
ric342's Avatar
The car was leaking mad brake fluid and i belive that it caused the Accident.it damaged the rear quarter panel which needed to be replaced, the entire right rear wheel suspension needed to be replaced. Im thinking about contacting a lawyer what do you guys think
ric342 is offline
Old 11-14-2012, 12:09 AM   #5
dsgerbc
Still need pics to make a recommendation.
Leaking brake fluid would probably mean rear brakes work less than needed, which could help explain front damage. Rear quarter panel damage = you spun. I doubt there is a reasonable story where rear brake leak = higher rear brake pressure and a lock-up. Unless your brakes locked up somehow before starting the car but you decided to drive anyway.
dsgerbc is offline
The Following 2 Users Say Thank You to dsgerbc For This Useful Post:
goke186 (11-14-2012), Jeff Lange (11-23-2012)
Old 11-14-2012, 12:45 AM   #6
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
You can try..but Toyota is a multi-billion dollar company..good luck
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline
The Following User Says Thank You to czar07 For This Useful Post:
Old 11-14-2012, 01:12 AM   #7
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
you slammed the brake and the car did brake but you slammed into a wall because the car braked?
Rayme is offline
Old 11-14-2012, 02:11 AM   #8
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
a manfunctioning switch/wire wont cause a caliper to leak
JP is offline
Old 11-14-2012, 02:27 AM   #9
Le86
Drives: Asphalt FR-S
You story does not add up at all.
10/01/2012 FR-S down for P0019 code. Received vehicle back from dealership with a new ECU 10/30/2012
Le86 is offline
The Following 3 Users Say Thank You to Le86 For This Useful Post:
Bristecom (11-14-2012), czar07 (11-14-2012), Jeff Lange (11-23-2012)
Old 11-14-2012, 08:21 AM   #10
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
Why, were you or someone else injured? How much were the damages?
whaap is offline
Old 11-14-2012, 08:28 AM   #11
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Fully functional the rear breaks don't do muh work anyways. I've had glazed rear brakes which really barely function and that's never resulted in anything close to an accident.
What exactly happened and what proof do you ave that the condition existed PRIOR to the wreck.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Dave-ROR is offline
Old 11-14-2012, 10:10 AM   #12
travace
travace's Avatar
Drives: Scion FR-S
i took my car today to the toyota in oxnard and they found out that one of the calipers in the rear was indeed leaking and that there was a malfunctioning switch or wire that sends a signal to the rear brakes and tells them when to do there job. Has anyone had this issue as well, please let me know and weather I should take any legal actions because it caused lots of damage to the car when the brakes failed.
ok is there some sort of backstory here? you act like you were in a accident but never actually say so. tell us what happened.
travace is offline
Old 11-14-2012, 10:30 AM   #13
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
He's trying to build a case against Toyota but knows it won't fly if no one else has the problem.
If I'm wrong then I apologize to the OP
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline
Old 11-14-2012, 10:40 AM   #14
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
He posted another thread about his accident. He claims a 25mph turn, hit the brakes, no ABS activation, spins, crash.
Sounds like someone driving outside of their skill level, but... :shrug:
Doesn't sound like non functional rear brakes would cause that type of accident, and 25mph around a 90 degree turn with no brakes is easily handled... so his accident story didn't add up either.
He's young and, IMO, trying to blame someone else for his mistake, but you never know...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Dave-ROR is offline
The Following 4 Users Say Thank You to Dave-ROR For This Useful Post:
Gixxersixxerman (11-14-2012), Rayme (11-14-2012), travace (11-14-2012), zohare (11-22-2012)
TSB / Recall Sigh-on-Rice Issues | Warranty | Recalls / TSB 390 09-11-2023 12:24 PM
Recall I think so!!!! RWD-boxer Issues | Warranty | Recalls / TSB 16 10-07-2012 10:39 AM
FRS recall? totally Issues | Warranty | Recalls / TSB 8 08-30-2012 12:01 AM
Recall! already earthsscum BRZ First-Gen (2012+) — General Topics 1 06-07-2012 07:00 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
