Old 11-12-2012, 10:44 PM   #15
nashsnazzy
Drives: 2013 Scion FR-S White Out
Never heard of the boommat stuff, thx for pointing that out. I'm not sure I'll go this route anymore vs components. Should I go this route, one of the issues is I never hear any feedback about 3.5" speakers. The JBLs are probably as good as any other but I can't help but wonder about JL, Hertz, Rainbow, and last but not least Infinity with their rotating tweeter and external tweeter x-over.
nashsnazzy is offline   Reply With Quote
Old 11-12-2012, 11:04 PM   #16
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Im running a 6.5" Hertz Mille component woofer in the door, with Focal PolyKevlar 4" mid and 1" tweeter in the dash. Took a very small amount of trimming to fit the 4" speakers in the dash. Im also not running any crossovers, just using the factory wiring so I have the same signal going to my current speakers as I did the factory speakers.
Eventually I might add a 4 channel amp to the system and will add crossovers when I do that but I am very happy with how it sounds now and would rather leave it as it is then add extra wiring and amps if I dont really need them.
Flat Black VW is offline   Reply With Quote
Old 11-12-2012, 11:09 PM   #17
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I'm sure they are all decent from those brands i would just make sure its a soft dome tweeter and being able to angle it would be nice. I'm considering getting rid of my sub and doing a 2 way up front with a really beefy 6.5"-8" in the doors and a wideband 3" in the dash. There is another guy working on something similar so i'm waiting to see how big of speaker he can get in the doors.
Old 11-13-2012, 09:59 AM   #18
PatrickSAN
Drives: SWP GR 5DR
You can fit an 8" with with right mounting adapter. 6.5" speakers look downright puny in there.
If you google speaker adapters forthe FR-S/BRZ there are some custom-made ones out there that can be made to fit an 8" woofer.
PatrickSAN is offline   Reply With Quote
Old 11-13-2012, 11:54 AM   #19
JoeBoxer
JoeBoxer's Avatar
That would be nice, thinking about a JL ZR800 but i'm sure there are some others too i need to look at.
Old 11-13-2012, 01:23 PM   #20
PatrickSAN
Drives: SWP GR 5DR
3 3/8" mounting depth might be a little deep, even with a 3/4" deep adapter. You might be able to fit a 1" deep adapter in behind the panel without interference, but I can't say for sure.
According to a google search, a 0.75 inch spacer fits perfectly yielding a total of 3.375 inches of available depth.
Old 11-13-2012, 01:33 PM   #21
JoeBoxer
JoeBoxer's Avatar
3 3/8" and 3.375" are the same thing right? I have found some others too gonna be my next project to research.
Old 11-14-2012, 09:25 AM   #22
PatrickSAN
Drives: SWP GR 5DR
Yeah, I started typing my reply from memory, then jumped on google to search for the actual answer, then forgot to edit my initial statement.
Old 11-14-2012, 02:12 PM   #23
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
I'm planning on running a complete Hertz Mille Component system. the 3" mid will be in the factory location with A pillar mounted tweets (below the airbag) which come with x-overs, active 6.5" woofers in the door run off a five channel amp single shallow 12 in the trunk. P99RS head unit. should be rocking.
FreshFRS is offline   Reply With Quote
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
"Carbon Fiber" dash piece mbh1101 Cosmetic Modification (Interior/Exterior/Lighting) 13 09-07-2012 08:16 AM
Shutting off your "key-in-with-door-open" beeper -- it's very easy avusblue Cosmetic Modification (Interior/Exterior/Lighting) 2 08-13-2012 05:29 PM
Steering wheel/dash "rattle?" upon heavy acceleration? brett_g Issues | Warranty | Recalls / TSB 2 08-04-2012 04:52 AM
Any thoughts on my "mini" engineering and business plan.? KidWonder Off-Topic Lounge [WARNING: NO POLITICS] 24 12-29-2011 01:16 PM
