Old 11-12-2012, 06:54 PM   #85
sierra
Drives: Skoda Yeti DSG diesel 4x4
Originally Posted by HunterGreene View Post
Right, but then you have to rev-match on the upshifts as well, no? I would figure the gear oil warms up pretty quickly, at least it has in my experience.
Yes but you do it without touching the throttle. You rev match by allowing the appropriate amount of time in neutral, with the clutch out, for the revs to fall to the correct rpm for the next gear. Then shove the clutch in and put it into that gear.
It's hard to believe it will reap any benefits on a car like this but I do it on some down shifts just for fun, using the throttle of course.
If the clutch ever fails, as in loss of fluid or a broken cable, double clutching is how you get home or to a garage. Start it in 1st and slip it into neutral just before you stop and turn it off, ready to restart.
You have to get it perfect with no clutch operation but it's better than leaving it or getting it towed.
sierra is offline   Reply With Quote
Old 11-12-2012, 11:36 PM   #86
White Shadow
Drives: 12,000 miles per year
Well, I've read quite a few complaints that the gearbox is notchy in cold weather. Second gear is usually the biggest complaint. How long it stays notchy probably depends on how fast the gear oil warms up.
White Shadow is offline   Reply With Quote
Old 12-01-2012, 03:01 PM   #87
alexp1189
Drives: Scion FRS
Originally Posted by TMayes86 View Post
Second gear feels off to me. It is the only one though. I had the dealer look at it and they came up with some excuse, needless to say I will be keeping an eye on it.
i have the exact same problem. I absolutely love my FR-S however, I will never be completely satisfied until this issue is fixed. I live in Montreal aka we have very cold winters and it is nearly impossible for me to down shift from 3rd to 2nd...i have to force it in which cannot be good...ive brought it to the dealer 3 different times and im sick of their excuses! everytime they say dont worry its running beautifully or ur on warranty so no need to worry if anything every happens its covered...id rather fix this before something happens!
alexp1189 is offline   Reply With Quote
Old 12-02-2012, 07:21 PM   #88
RazBRZ
Cones are bad
RazBRZ's Avatar
Drives: 2013 BRZ Premium
I found my problem was I was to tense in anticipation of it grinding and I was making the problem worse. I found that using 2 fingers and letting it do most of the work is very smooth. The first couple shifts are you need to be careful though.
On a seprate note. Is it just me or does the Flywheel/clutch make a rediculous amount of noise when your revs are low I.E. rolling a stop sign?
RazBRZ is offline   Reply With Quote
Old 12-03-2012, 12:03 AM   #89
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Are you in gear?
chulooz is offline   Reply With Quote
Old 12-03-2012, 01:20 AM   #90
RazBRZ
Cones are bad
RazBRZ's Avatar
Yep. I usually leave it in second. Could it be because the transmission is right below me so I can hear things better and I've heard Subaru's a notoriously loud. I just think it sounds odd
Old 12-03-2012, 01:27 AM   #91
sierra
Clutch or gearbox noise?
The gearbox is Lexus, they are notoriously quiet.
Old 12-03-2012, 10:25 AM   #92
chulooz
Registered you sir
chulooz's Avatar
Next question: Is this your first manual?
Because wtf are you doing leaving it in gear? No wonder
Old 12-03-2012, 10:30 AM   #93
OrbitalEllipses
Drives: Attitude
I'd assume because it's a bitch to downshift to first (which you shouldn't do until you're stopped anyway) and creeping in 2nd during traffic is way easier. It doesn't sound or feel pleasant though.
Old 12-03-2012, 10:38 AM   #94
chulooz
Registered you sir
chulooz's Avatar
He is talking about rolling to a stop sign, thank gosh he isnt trying to force first. Just take it out of gear if you want the chatter to stop, if it doesnt sound healthy it probably isnt.
At least you are getting the part of letting the shifter do the work for you, though it sounds like grinds have already been made.
Old 12-03-2012, 11:55 AM   #95
jesperswe
Drives: GT86
I always keep mine in second gear when im about to stop, right before the stop i press the clutch pedal and then put into 1st gear when standing still
jesperswe is offline   Reply With Quote
Old 12-03-2012, 01:47 PM   #96
HunterGreene
Hail Magnet
HunterGreene's Avatar
^same here.
Old 12-03-2012, 03:15 PM   #97
OrbitalEllipses
Drives: Attitude
*shrug* That's what warranty is for.
Old 12-03-2012, 06:12 PM   #98
sierra
Where did this fallacy come from? Of course you can change into 1st gear while it's moving, it's just another gear and happens to be the lowest one.
Where is the mechanical logic that you have to be stopped to select it?
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 07:07 PM
A problem with new rules in SCCA/NASA regarding FIA seats CyberFormula Other Vehicles & General Automotive Discussions 3 11-09-2011 09:13 AM
Help me track down my braking problem :( #87 Other Vehicles & General Automotive Discussions 32 09-26-2011 12:49 PM
