#29 | |
Drives: golf
I think you should wait the few months we have left and find out exactly what the FT will be. Then make your decision. |
#30 |
Drives: FR-S, Exige S, Miata
Yes, definitely. I won't do anything until December. I guess my question is based on the assumption that everything they say about the 86 is true.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield '95 Miata (Montego Blue) |
#31 |
-Proud of Brzerhood-
Drives: '17 BRZ CWP LMT.
They're something about fixing up classics and older cares. I figure if I can't afford a new car or I decide to wait for something eke I wouldn't mind getting and older car to restore like a Z31 or an old Supra
"The BRZ Section's fine wine" -Zgrinch |
#32 | |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
#33 | ||
Drives: '93 FD3S
http://www.lotustalk.com/forums/f94/...53k-mi-104307/ http://www.lotustalk.com/forums/f94/...-cheap-103890/ http://www.lotustalk.com/forums/f94/...c-area-103218/ http://www.lotustalk.com/forums/f94/...ngeles-103053/ All under 60,xxx and 29,xxx$ Quote:
On the topic of managing or avoiding previous owners abuse: Is it possible to look for indications of abuse through standard checks? compression test leakdown test pulling turbochargers for abnormal amounts of shaft play etc What do you guys think? Last edited by tree fingers; 08-18-2011 at 12:30 PM. |
#34 |
I used to have an Elise and traded it in for my current Exige S. Yes, the prices for used Lotus actually went up a bit. I recall last year there were a few 2005 Elise selling below $23K with low miles. Lotus is actually a good used car to buy. People either track it or keep it as a garage queen with very low miles and take extremely good care of it. The car takes a huge depreciation hit the first few years but I think the price is now stable. It might actually go up a bit because of the fact that they don't make Elise/Exige any more and the new direction that Lotus is going with upscale cars to compete with Ferrari and Lambo.
#35 | |
Glorious BRZ Master Race
Drives: Subaru Libird
Test drive other cars of the same make/model/year in near perfect condition (usually priced higher with lower mileage). Familiarize yourself with where power comes and drops in the entire rev range and feel of the transmission and suspension. This gives you a standard to test against. Check for consistent spacing between body panels and compare spacing on left vs. right body panels. Look along edges/crevices for signs of paint work, non-factory paint defects (dust, craters), or inconsistent texture or lack of factory orange peel texture on panels. Put the car on a lift and check suspension for welds/breaks/recently replaced parts. Have a shop do a full laser alignment inspection and confirm everything can be aligned back to factory spec. Make sure they check more than camber, caster, toe; measure steering axis inclination (not directly adjustable) and calculate included angle (not directly measureable) among other things. If the secondary, more involved measurements are off, then most likely something has been bent.
#36 |
Praise Helix!
In the end you just have to compare vehicles and get what you want. You'll almost always get a better value from a used vehicle because you aren't taking the new car depreciation hit, so it's almost an unfair comparison. By the time the Toyota/Scion/Subaru is out you'll probably be able to pick up a base 370z or 2011 Mustang GT for mid-low 20s, since I've seen them as low as 25-26k already. The first gen Genesis Coupe will probably drop its value some when the new model hits too. And if you don't care about weight, you can already get a first gen CTS-V for under 20k. Add a few grand for an aftermarket warranty if you're afraid of something breaking, and you're set till 100k.
I've owned two brand new cars though, and there is a really good feeling associated with having a brand new vehicle.
#37 | |
Softparker
Drives: 2002 Mazda Miata
#38 | ||
hashiryu
Drives: Mk4 Supra
![]() UZ > JZ. |
#39 |
Delights in pure handling
Drives: Zoom Zoom
#40 |
Site Moderator
Drives: ichi 86 Project
True... but isn't UZ only comes in AT tranny (iirc)?
#41 |
Drives: N/A
:| What are you suggesting?
Edit: Why do I always get put on the second page? |
#42 | |
Site Moderator
Drives: Stuff
996s are great deals if you pick wisely (or if you keep 12k around in case you need to replace the motor). Of course you can look for wear/abuse, that should be done with all used cars.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| Toyota Celica name possible for European/Asian market | madaadda | Scion FR-S / Toyota 86 GT86 General Forum | 109 | 11-02-2011 01:46 PM |
| after market parts | serchmarc | Scion FR-S / Toyota 86 GT86 General Forum | 90 | 05-31-2011 08:18 PM |
| What do you look for when buying a sports car? | Diar | Other Vehicles & General Automotive Discussions | 43 | 09-28-2010 08:50 AM |
| President/COO Toyota Motor Sales USA confirms FT-86 coming to North America market! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2010 08:15 PM |
