#2171 |
Drives: BRZ DGM Limited
So is it safe to say that ECU 812 is the true fix?? Any easy way to see what ECU you have other than looking right at it? (ie is there a code listed on the delivery papers? My BRZ is coming in this week!!)
#2172 | |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
At least Subaru/Toyota are aware of this issue and are looking into it though... Also, you wouldn't be able to tell which ECU model you have unless you look under the dash for the serial number.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
#2173 |
Drives: 86
UPDATE: So After having my ECM replaced, it has been running great. I've driven for about 600 miles so far and it has had a strong idle with no weird dips. I even took it to an auto cross type event where it has had no issues. I would safely assume that this is the "true" fix. I hope this helps those of you waiting, this fix has truly made me forget the "down" time and have been enjoying the car.
#2174 |
Drives: GT86
If it is the true fix then why the hell is Toyota still replacing VVTi gears here in Sweden?
#2175 | |
FT86Club Vancouver
![]() Also, results could be from case-to-case, some issues lead to more major problems than others... Some is just an easy fix with the replacement of the new ECU; some has blown engines...
#2176 | |
Drives: GT 86, black
They specifically said that there would be NO firmware update or ECM swap in France this year, because it is only a temporary fix for a hardware problem. He did tell me that they where getting specially checked new parts, I guess ones made to the correct specs ? Also, I'm not sure about it, but when I asked him why the hell other EU countries got a new firmware (like the UK) and not us, and joked about his face when he'd have to call me back to tell me that there was indeed an ECM recall campaign, he laughed and kind of hinted that there was going to be a new ECM firmware early next year anyway for unrelated things. That would explain why they would not bother going though a certification process in November if they were already going to certify a new one in a few month ? ![]() Maybe the guy misunderstood something, maybe he is BSing me, or maybe that is all a global conspiracy, who knows? Tune in for the next episode in two weeks where some noob guy takes apart my engine and tries to put it back in one day !
#2177 |
uosɹǝdʎɐl ʇɹǝdxǝ
Drives: Asphalt AVO FR-S w/a Slushbox! :P
In on page 100...
Wow, 100 pages?
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn |
#2178 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Almost 200 on our list ^__^
Sent from my PC36100 using Tapatalk 2
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#2179 |
Drives: Subaru BRZ
Received my car back 11/9. My invoice says that a field service engineer came to inspect the vehicle and they replaced the ecm with updated program/software. No details as to what the updates were, but probably the updated ecm that everyone is talking about. This is my third and hopefully final ecm.
#2180 |
Drives: black frs
My car was stuggling with the idle issue and I changed my fuel to gasoline without ethanol to get rid of the cricket sound it was making, the idle issue went away also.
#2181 | |
From what I understand from my dealer, standard procedure is to check the performance of the VVTi unit. If it is functioning properly, then all that is needed is an ECU flash (or replacement). But if VVTi is not functioning properly, it needs to be replaced along with the ECU update. |
#2182 | |
FT86Club Vancouver
(Knock on wood it doesn't...) :happy0180:Yeah... amazing isn't it?... You can almost write a chapter book about our "awesome" characteristic of the twins just using this thread alone...
#2183 |
Drives: t
I'm sorry guys.. I have bad news..
#2184 | |
Drives: '13 White FR-S, 09 Triumph St.3 R
| NW Owner List & Event Archive | DarrenDriven | Northwest | 1643 | 08-05-2016 07:48 PM |
| Idle issue? | yayforaddison | Issues | Warranty | Recalls / TSB | 891 | 07-14-2016 11:42 AM |
| Idle issue | scioneric | CANADA | 23 | 08-24-2012 02:40 AM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 01:00 PM |
| An unofficial message from TMCA | Courtz1074 | AUSTRALIA | 25 | 05-17-2012 11:00 AM |
