Old 11-10-2012, 04:01 PM   #1
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Replaced my OEM foglights with 3000k HIDs
Well I've been thinking about replacing my oem foglights which are a dissappointment really. To be honest, the 25W bulb is useless, you can't even tell if they are on or not. I've read here that the HID would melt the housing because of the heat, and some say HID is not that hot. There's only one way to find out, and I'll take one for the team to find out. So here goes.
Took the housing out by taking the clips out in the front fenderwells. You can access the foglight housing by pushing the fenderliner out of the way. It's pretty easy to take out with 4 screws. Sorry wasn't able to take pics of these, but you guys can wing it.
I then took out the bulb from the housing by pressing on the tabs on top and below. Pretty straightforward. As you can see, the bulb is nothing but a glorified corner lamp.
Here's the HID set I used. I opted to get the slim ballast. More on that later.
Here's pic of the replacement HID bulb. It's a lot longer than the stock one. It's not a drop in replacement, but the H1 bulb would fit the diameter of the stock hole.
Here's the bulb seated on the stock mounting point.
Since the bulb won't lock in, I just used some heavy duty sealant to keep it in place. The bulb is pretty much tight, but to make sure no moisture would get in, I used the sealant.
Here's the slim ballast I used. I positioned it below the windshield washer and radiator on the other side.
Connected everything and bolted everything up. Tested the bulbs. I used 3000k bulbs to keep that JDM look and all-weather usage.
Here's a nightshot with just the 3000k fogs on.
Here's a shot of the 4300k headlamps with the fogs.
Here's a front shot.
A little bit to the side shot.
Big improvement from stock as the output is far stronger than the stock fogs. Sadly, the HID makes a lot of heat and I noticed that there's a slight deformation in the middle of the plastic lens. It's barely noticeable, and using it for a few days now, it has not worsened. I'll update you guys if there's more deformation or if I straight melt my lens covers.
Tye300 is offline   Reply With Quote
Old 11-10-2012, 04:19 PM   #2
Mari0
Car Enthusiast
Mari0's Avatar
Drives: tC 05 & 07, Rav4
let's hope you don't blind oncoming traffic (:
Mari0 is offline   Reply With Quote
Old 11-10-2012, 04:25 PM   #3
Tye300
Tye300's Avatar
No angry oncoming drivers yet! =)
Old 11-10-2012, 05:25 PM   #4
Gir
Gir's Avatar
Drives: 86 GT Manual - Sonic Blue
Let's hope you're not a jerk who drives around with them on when it's not foggy.
Gir is offline   Reply With Quote
Old 11-10-2012, 05:44 PM   #5
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
You are already melting the plastic... do you think this is a smart idea?
That sealing job screams ghetto and that beam doesnt look to great.
chulooz is offline   Reply With Quote
Old 11-10-2012, 05:52 PM   #6
gmookher
1-defeats purpose of fog lamps
2-how will you replace bulbs
fail..
Old 11-10-2012, 06:29 PM   #7
RidetheTran
Drives: Toyota
I hope you know you are blinding on coming traffic...theres a reason why manufacturers don't use HID's in fogs. If you want a better output for your fog lights, my honest advice would be to replace those HID's with LED's. They're bright but not nearly as blinding.
RidetheTran is offline   Reply With Quote
Old 11-10-2012, 11:05 PM   #8
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
LED's will not work; they look brighter than stock, but they do not have enough light output for the job.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 11-10-2012, 11:17 PM   #9
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
looks like the 86 shares the same foglights of the BRZ. therefore you can upgrade them to the subaru outback's foglight that uses H11 bulbs
pare let me know if you want a set and ill try to find one at the junkyards here
PM me
86_ZN6 is offline   Reply With Quote
Old 11-11-2012, 02:45 PM   #10
Tye300
Tye300's Avatar
That is why I specifically stated that I would take one for the team and try it out. No sense in arguing about it if it would work or not. To me, I'd rather try than just sit around thinking about it. Could have done it better, but the stock housing does not have a direct replacement. Anyway, I'm glad to say that the stock lens has not melted in any way.
Old 11-11-2012, 02:47 PM   #11
Tye300
Tye300's Avatar
PM me
Thanks pare! I'll let you know. Looks like the plastic lens is holding steady now. My front bumper has not gone up in flames yet haha! Waiting for the price of your JDM headlights as they don't have stock of them yet here.
Old 11-11-2012, 02:50 PM   #12
Tye300
Tye300's Avatar
fail..
What is the purpose of the stock ones if they don't do anything?
The sealant is easy to take off if I want to replace the bulbs.
Old 11-11-2012, 03:07 PM   #13
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I have yet to see fog lights on a stock vehicle that are bright. They arent meant to light up the road that far away, they are pretty much there as a cosmetic option. And yes, these will blind incoming traffic. Did you take a pic of the light pattern against a wall ?
Rayme is offline   Reply With Quote
Old 11-11-2012, 03:28 PM   #14
robotvoice
Drives: 07 STI
This is a car fire waiting to happen. HIDs do not belong in halogen housings, ESPECIALLY fog light housings for that matter.
There's a reason that cars do not come with HID fog light systems from the factory.
robotvoice is offline   Reply With Quote
Does anyone in the US with an FR-S have Foglights??? pituala Cosmetic Modification (Interior/Exterior/Lighting) 42 01-30-2014 11:15 AM
GT86 foglights installed but no switch? derka-derka Electronics | Audio | NAV | Infotainment 8 08-16-2013 03:13 PM
Can this part be replaced? czar07 Cosmetic Modification (Interior/Exterior/Lighting) 17 11-07-2012 01:46 PM
FOGLIGHTS/HEADLIGHTS on 86, CANBUS or normal? WTF AUSTRALIA 3 06-21-2012 03:55 AM
I may have had the first ever manufacturer-replaced FR-S VZ86 Scion FR-S / Toyota 86 GT86 General Forum 12 05-13-2012 12:39 AM
