| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#43 |
Drives: 86' Toyota Corolla GTSR5, 15' FRS
#44 | |
Señor Member
Drives: white BRZ 6MT
I think I figured out why people aren't liking these wheels as shown: offsets too tame and no lip
#45 | |
We have fit 18x9.5 +28 without any issues in the rear with 245/35/18 We have also fit 18x9.5 +28 with 225/40/18 up front. with still about 3-5mm clearance from the fender. Camber was only at approximately 1.75 degrees. 16x8 +0 wheels would sit approximately 5-7mm further out then the 18x9.5 +28, but with the given clearance between the tire and fender, it should clear with slight tweak of camber. The rears with the 16x8 +0 should be easy. Now if he wanted to run 255's or something on the 16x8 - would run into fender clearance issues up front for sure. |
#46 |
USMC Veteran Semper Fi
Drives: 2010 WR Blue STi
Those are 15 x 6.5 with 205/65-15 and they look studable for ice I found my snows LoL
![]() translated from Watanabe site Vehicle model year Toyota GAZOO RACING 86: DBA-ZN6: Model 2012 Wheel Size For Tarmac F / R F8F 17-70 +40 100/5 Black For gravel F / R F8F 15-65 +35 100/5 Black Tire Size For Tarmac YOKOHAMA ADVAN NEOVA AD08 225/45-17 For gravel YOKOHAMA ADVAN A035 205/65-15 Andong Sadatoshi: Co-driver Car Sho Aikawa 1 2 driver name Yu Suzuki: co-driver canon audition Kobashi Driver Car 2 Class participation JN-3 class Sho Aikawa JN-3 class canon Kobashi 【Specifications】 competing vehicle
#47 |
Aside from those issues, this will be the look that is emulated when the 2013 is vintage.
#48 |
ft86club resident b-boy
Drives: Yamaha R3, moonslate 2018 GT Black
not lowered, but much better fitment and MAGNESIUM! 12.8 pounds!!!!
F8 type 17x8 +35 matte black ![]() |
| The Following 2 Users Say Thank You to cyde01 For This Useful Post: | chris x sway (01-08-2014), DAEMANO (03-18-2015) |
#49 |
Drives: DGMBRZ
#50 | |
mag F8 eight spoke 5.8kg they started making mag 17in in 2011. link to those pics, even if you can't read japanese it clearly says mg in red. http://www.rs-watanabe.co.jp/userspage/fujimoto-zn6.htm |
#51 | |
Drives: DGMBRZ
#52 |
Drives: 86 GTS
17x8 unknown offset
#53 |
Drives: 2014 FR-S in Mayonnaise
I would love these in a negative offset please.
#54 |
Drives: Rocket Bunny'd GT86
| The Following User Says Thank You to Yamajee For This Useful Post: | chris x sway (01-20-2014) |
#55 |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
All these pics of narrow width and/or high offset watanabes on the 86 are frustrating. These are one of the most perfect wheels to go with the gt86. These desperately need to be at least 17x9 with at least a et35 or et30 offset (or, a much lower offset for a narrower 7-8" width - like et0-et20).
Does anyone have pics and/or know if a 17x9 watanabe in an et30 or et35 offset would have a noticeably bigger lip and look much nicer (compared to all these pics of unattractive high-offset 7-8" et40-et50 wheels)? 17X9 et30-35 isn't that crazy (it's not like a et0 or negative offset); so it's relatively still a little mild/conservative and very realistic. I'm wondering why no one has at least mounted a 9" et30-35 yet?! ...17x9 et30-et35 would be puuuurfect ![]() btw: Rota makes(has molds and is listed in their website) RKR replicas in 17x8 and 17x8.5 with 5x100 in nice low offsets of et0, et5, et10 and even available in the negatives. I can see an 8"+5 or 8.5"+10 easily fitting the 86 without any major problems nor modifications (except coilovers). These would be a fantastic alternative to real(and expensive) Watanabes and would weigh similar to the Watanabe non-magnesium versions anyways (not to mention you make a fuss and cry if you damage one at the track). http://www.rotawheels.com/wheel.php?id=100 Wheeldude says he only needs 3-4 confirmed preorders, for Rota to fire up the kiln and press some new wheels for a special order
| The Following User Says Thank You to fooddude For This Useful Post: | chris x sway (01-09-2014) |
#56 | |
Drives: accord
how much per wheel will that rota cost? |
