Old 11-08-2012, 04:38 AM   #1
Crossover Auto
Drives: FR-S, BR-Z, 86
E-85 users thread
If you have been tuned on E85 please post for how long and how many miles.
This will be a good reference if in a few months, we start seeing failures in the cam driven high pressure fuel pump (CD HPFP).
Crossover Auto is offline   Reply With Quote
Old 11-08-2012, 07:45 AM   #2
xjohnx
Grip>Slip
xjohnx's Avatar
any evidence to support this theory, or is this just speculation?
Old 11-08-2012, 04:03 PM   #3
Crossover Auto
Yes, just look at Mazdaspeed3/6 direct injection pumps. If you have ever used E85, you know it causes some build up. Even running a regular tank of pump gas doesn't prevent it from happening.
http://www.mazdaspeedforums.org/foru...-issues-79030/
Old 11-08-2012, 04:35 PM   #4
Opposed
Drives: 2013 Asphalt FR-S
Subscribed for this. You guys seem adamant that this will happen. I know early on people have asked this question and most of the tuners on here simply say "nope, it will cause no problems." I would like to run it come spring but I am waiting for more research.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 11-08-2012, 05:21 PM   #5
SkullWorks
Drives: SSM LT MT BRZ
I am using E85 and have no problems, and expect none.
Anyone comparing a mazda and a BMW pump (reference the link) has not been exposed to both types of pumps, and has no idea how high the rate of Pump failure is on BMW's regardless of fuel, mileage, or driving style.
I manufacture aftermarket fuel pumps for the Mazda/Audi pumps, I have considered the BMW pumps but the design is literally horrible, and way way way too complex for the task...thankfully our HPFP's are more akin to the mazda and audi pumps but have an issue with the side-loading of the pump shaft.
It's hard to say what the factory uses for a coating in the pumps themselves, but I use a combo of coatings and hard enough material to prevent galling should there be a potential
The fact that the guy had "rebuilt" his pump recently, tells me why it failed. nick anything, scratch anything, get a speck of dirt in there, anything and that thing will die quickly....the average clearance in those pumps is .0002" (yes really less than 1/10th the thickness of your hair) the clearance there is closer than the tolerance on your average factory crank bearings.
The Following 2 Users Say Thank You to SkullWorks For This Useful Post:
FT-86 SpeedFactory (11-08-2012), xjohnx (11-08-2012)
Old 11-08-2012, 05:32 PM   #6
Kochinopride
Kochinopride's Avatar
Drives: 13 FR-S, 12 CLS AMG, 05 Lotus Elise
I've been running E85 for about 300 miles now. Since fuel was on Scarce mode for a while here, I'll be doing more driving in the next few days. I'll report anything odd if it occurs. I'm also going to be dropping a turbo in soon...
2005 Lotus Elise
2012 Mercedes Benz CLS AMG 6.3
2013 Scion FR-S
2011 Land Rover LR4
2013 Lamborghini Gallardo LP570-4 Superleggera
Kochinopride is offline   Reply With Quote
Old 11-08-2012, 06:42 PM   #7
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
How much did fuel economy decrease when switching to E85?
Dustin is offline   Reply With Quote
Old 11-08-2012, 07:07 PM   #8
Kochinopride
To be honest, I haven't noticed a decrease. At least not yet. I hear it burns faster at higher RPMs and I don't pound the pedal (just snowed here). I've driven it about 300 miles and I've used up about 1/6 of a full tank.
2005 Lotus Elise
2013 Scion FR-S
2011 Land Rover LR4
Old 11-08-2012, 07:18 PM   #9
SupraLove
Drives: 2007 Toyota Camry LE, 5AT i4
I'm glad we're switching to E85. Once we run out of fossil fuels, we'll still be able to drive our cars!
SupraLove is offline   Reply With Quote
Old 11-08-2012, 08:04 PM   #10
SkullWorks
you sir are either a troll or you can't count, you realize you just proclaimed something north of 100 miles per gallon right?
there is a basic requirement due to the chemical composition of Ethanol (the E in E85) VS gasoline that says you need ~25-30% more fuel not 1/3 the fuel as you are claiming.
I get about 140 miles to the tank or about 14 miles per gallon, but i drive...enthusiastically. and my tune is still slightly rough
(im not on a stock ECU we are running AEM series 2 on mine)
Old 11-08-2012, 08:07 PM   #11
Mitch
form follows function
Drives: RIP '13 BRZ
Your gas gauge is frozen. People have been having this problem with the latest rounds of tunes.
Mitch is offline   Reply With Quote
Old 11-08-2012, 08:08 PM   #12
Kochinopride
believe me I'm not troll and most likely miscounted, badly. my fault.
I don't drive spiritedly - haven't gotten a chance to... I haven't sat down in my car and crunched actual mileage and numbers and all - just did some quick calculations in my head and came up with 300... pretty sure it's less now that I think about it... Thanks for doing the thorough calculation!
2005 Lotus Elise
2013 Scion FR-S
2011 Land Rover LR4
Old 11-08-2012, 08:09 PM   #13
Kochinopride
That COULD be a possibility, but it has moved... slightly... is there a way I can verify this? Or can it be fixed quickly if that's the case?
2005 Lotus Elise
2013 Scion FR-S
2011 Land Rover LR4
Old 11-08-2012, 08:21 PM   #14
xjohnx
Grip>Slip
xjohnx's Avatar
I know Visconti's E85 rom replaces the MPG gauge with a number indicating what percentage of fuel is in the tank.
Kochinopride (11-08-2012)
Bluetooth fix for Android/Samsung users inimitable Electronics | Audio | NAV | Infotainment 27 05-10-2013 07:52 AM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 01:24 PM
AZ bs thread sfwg Southwest 185 09-11-2012 04:11 AM
The "if you wanna kiss the backside of white musicians make a thread about it" Thread aliphian Off-Topic Lounge [WARNING: NO POLITICS] 8 12-19-2011 08:59 PM
Rwd toyota users here? aphxero Other Vehicles & General Automotive Discussions 14 12-23-2009 10:34 PM
