Old 11-07-2012, 08:41 PM   #1
DIM
Tamiya Scion FR-S RC
Hey FT86club,
Does anyone have experience with RC's or has this model?
How hard is it to paint?
Can I add LED's to the headlight's/tail light's?
Where can I buy the battery, charger, radio gear, servo, receiver at?
I've tried searching online and a little new to this. I'm gonna buy the on on eBay since it's a little cheaper there. But I've seen a few options where you can upgrade the suspension, is it worth it?
And any recommendations?
Sorry for all these questions.
Here's the one on eBay:
http://www.ebay.com/itm/Tamiya-58529...item1e73b431bc
The Toyota 86 has been a highly anticipated sports car since the 2009 Tokyo Motor Show. In 2012 the vehicle was finally released to markets around the world. In Japan it is known as the Toyota 86. In Europe it is known as the GT-86 and in the USA and North America it is known as the Scion FR-S. The new Toyota 86 R/C body is mounted on Tamiya's proven entry level assembly kit, the TT-01E.
Specs
Scale: 1/10 scale
Construction type: assembly kit
Terrain use: on-road
Drive-train: 4WD
Drive type: shaft
Drive line: dog bone
Differential type: gear
Suspension: fully independent double wishbone
Steering mechanism: bell-crank
Shock damper: friction damper
Shock damper material: plastic
Tire type: rubber
Tire tread: radial
Body material: ABS Plastic
ESC: included
ESC type: TEU-105BK
LED Light buckets: no
LED lights: no
Motor type: 540-brushed type
Bearings: plastic bushing
Chassis material: plastic
Sticker material: vinyl
Internal gear ratio:
Adjustable camber: fixed
Adjustable toe angles: fixed
Adjustable ride height: yes
Adjustable gear ratio: yes
Adjustable wheelbase: yes
Adjustable track width: fixed
Adjustable shock angle: yes
Anti-squat adjustment: n/a
Droop adjustment: n/a
Special features: Extra plated wheels included
Requires: 7.2 battery, charger
Requires: polycarbonate paint
Requires: radio gear, servo, receiver
I found a picture of one done online, looks pretty goood!
Thanks in advance!
DIM is offline   Reply With Quote
The Following User Says Thank You to DIM For This Useful Post:
bestwheelbase (11-08-2012)
Old 11-07-2012, 09:06 PM   #2
SubarooMike
SubarooMike's Avatar
Drives: Subaroooo
I have all the answers to your questions BUT i'm in a rush. If you have all these very basic questions (nothing wrong with that!), you need to join this forum! http://www.rctech.net/forum/ It is an absolutely fantastic forum. I hope this helps:happy0180: Oh, this is another great forum as well http://www.rcuniverse.com/index.cfm
SubarooMike is offline   Reply With Quote
The Following User Says Thank You to SubarooMike For This Useful Post:
DIM (11-07-2012)
Old 11-07-2012, 10:41 PM   #3
DIM
Thanks, I just signed up and posted the same thread!
Old 11-08-2012, 02:18 PM   #4
bestwheelbase
Drives: 1985 P-Type
Originally Posted by DIM View Post
Hey FT86club,
Thanks in advance!
We posted our build here: bestwheelbase Tamiya racer. We've done lots of Tamiya stuff over the years. It's a great hobby! To answer your questions:
1) This is a new body but an existing platform. Very fun and easy to run/race/repair/etc.
2) Painting is not hard but it pays to take your time masking things off and focusing on details like shut lines and livery. Scale realism is fun!
3) Yep, there are LED kits for headlights, taillights, even little lights that make it look like your tailpipe is shooting a flame.
4) Your local hobby shop will have radio & electronics. Or an online store like TowerHobbies.com.
5) Just like a full size car... it's best to get it running and see how you like it then worry about modifications to the suspension.
6) Best recommendation: Jump right in and learn as you go. Have fun!
Also check out the TamiyaUSA.com website and forum for clearance deals & photos of other peoples' projects.
The Following User Says Thank You to bestwheelbase For This Useful Post:
DIM (11-08-2012)
Old 11-08-2012, 04:47 PM   #5
DIM
Thanks for answering all my question's! The only thing I'm really nervous about is the painting part. Is there a site where you can already buy it painted or a place where you can get it painted?
Old 11-08-2012, 04:54 PM   #6
SubarooMike
Drives: Subaroooo
You have to use special paint so it does not chip and will flex. Use pactra spray paint for lexan bodys. You always paint from the inside of the body and the body it self contains an exterior mask so you don't have to worry about overs pray. And you normally back your color with silver, black, or white.
This should help you: http://www.hpiracing.com/hpibodies/tips/
Edit: Some bodies come painted. You can also have someone paint it on RCtec.net -- but it can be VERY expensive.
I wont lie. To do the body well and scale take A LOT of time. It is harder then it looks -- but if you take your time, you should be happy with the result
bestwheelbase (11-09-2012)
Old 11-09-2012, 02:08 AM   #7
bestwheelbase
Drives: 1985 P-Type
@SubarooMike nailed it.
Painting the body is really straightforward. The kit will include stickers to mask the parts you don't want to paint (like windows). You simply cover up those areas, spray the inside, let it dry, then peel off everything and go race. You can worry about decals and livery and other stuff later.
Pre-built stuff is an option but, honestly, the beauty of this hobby is customizing your car. Hit this link at TamiyaUSA to see all the great colors they offer!
Old 11-09-2012, 02:23 AM   #8
travace
travace's Avatar
Drives: Scion FR-S
if you want to do a single color its pretty basic and NP to do. you use a special paint and just go slow doing layers and drying it with a hair dryer so you dont have runs.
getting into designs and multiple colors can be tricky... ive done a couple slash x bodys using special trimming tape and i always got runs in corners here or there. i hear you can use a liquid tape then cut out the design you want but havent tried that method yet. nothing crazy cool but here is a couple pics...
travace is offline   Reply With Quote
The Following User Says Thank You to travace For This Useful Post:
bestwheelbase (11-13-2012)
Old 11-12-2012, 06:06 PM   #9
DIM
Thanks for the tips, I'll most likely be using a solid color design. It'll be easier and looks better IMO.
And this guy over at RC tech answered most of my questions as well and suggested/where to buy them.
Originally Posted by cdwilliams1 View Post
This car is based on the TT-01E platform. An entry level 4wd touring car. You will have a great time with it! Do you plan to race? If so, that would change the gear recommendations slightly... with the Scion body you'd run in touring car, or maybe TCS. You could easily run this car in the vintage trans am class too by swapping out the body and tires.
You can learn a lot by hanging out in the forum dedicated to that car here:
http://www.rctech.net/forum/electric...-01-forum.html
Check out amainhobbies.com or towerhobbies.com for gear. I like Tower better myself because they are so close to me, that I get the stuff the next day - even if I pick standard shipping!
For entry level gear, I'd suggest:
Radio
Just for fun: http://www3.towerhobbies.com/cgi-bin...I=LXASX2**&P=7
Beginner Racing: http://www3.towerhobbies.com/cgi-bin...?&I=LXAVSY&P=7
Speed Control and motor
Fun: http://www3.towerhobbies.com/cgi-bin...&I=LXCATW&P=ML
Beginner Racing: http://www3.towerhobbies.com/cgi-bin...?&I=LXCFBM&P=7
Steering Servo
Just for fun: http://www3.towerhobbies.com/cgi-bin...&I=LXVW07&P=ML
Beginner Racing: http://www3.towerhobbies.com/cgi-bin...&I=LXRWS9&P=ML
Charger
Fun (NiMH Batts): http://www3.towerhobbies.com/cgi-bin...&I=LXTCJ8&P=ML
Beginner Racing (LiPo Batts): http://www.teamassociated.com/lrp/pa...ails/LRP41281/
Batteries
Fun: NiMH http://www3.towerhobbies.com/cgi-bin...&I=LXAAGG&P=ML
Beginner Racing: LiPo/NiMh http://www3.towerhobbies.com/cgi-bin...&I=LXBAKN&P=ML
Light Kits
http://www3.towerhobbies.com/cgi-bin...93p?&C=CHZ&P=7
Old 11-13-2012, 01:17 AM   #10
bestwheelbase
Drives: 1985 P-Type
Do not waste your time with NiMH batteries. LiPo are faster, lighter, more consistent, and they're no longer cost prohibitive. Here's the best deal going right now 5000mah. This is one thing you can't get at TowerHobbies. The exclusive distributor is HobbyPartz / Nitroplanes.
DIM (11-14-2012)
Old 11-14-2012, 02:35 PM   #11
DIM
Yeah, I was recommended by my friend to use LiPo. And you think the other parts are good to use for my RC?
Or could you recommend me the same parts your using?
And I'll be adding lights, so a 4 channel remote I'll be looking for.
Thanks, Dim.
Old 11-14-2012, 02:47 PM   #12
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
LiPo, Brushless motors, etc. RC-Tech is a great forum, so is Ultimate-RC.com (smaller, more responsive crowd).
I ran electric 1/8th scale buggies back in the day (converted from gas BEFORE there were kits). It started to get a bit expensive for a full-time student. Now the FR-S is destine to be my money pit.
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport
13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook |
Re~Mix is offline   Reply With Quote
Old 11-17-2012, 02:02 AM   #13
DIM
Which LiPo battery & charger should I get?
Looking for a good 4 channel radio, gonna add LED's in the future. And when you buy a radio, does it include the receiver?
Thanks, Dim.
Old 11-17-2012, 10:53 AM   #14
travace
travace's Avatar
Drives: Scion FR-S
lipo's are awesome but they die easily. they take more care to keep running correctly. also if you do get lipo's please BUY A FIRE BATTERY BAG. those things cause tons of house fires a year so be safe with em.
bestwheelbase collaborative - help us choose a livery for our Tamiya racer bestwheelbase Off-Topic Lounge [WARNING: NO POLITICS] 84 03-03-2014 05:04 AM
1/24 86/BRZ Plamodel from Tamiya yajin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 38 11-05-2013 10:42 PM
1/10 Scale Tamiya Subaru BRZ + Subaru BRZ R&D Sport GT300 soulstice BRZ First-Gen (2012+) — General Topics 31 01-21-2013 10:30 PM
Tamiya releasing RC 1/10 GT86 adam Off-Topic Lounge [WARNING: NO POLITICS] 4 04-19-2012 06:58 AM
Scion FR-S Behind the Scenes with Scion VP Jack Hollis scion UriarteMD FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 19 06-14-2011 07:13 PM
