Old 11-06-2012, 03:13 PM   #1
ft86-UAE
turbo FT-86
ft86-UAE's Avatar
Drives: ft-86
turbo missfire
any one faced misfire problem with force induction?
the car misfire @ 4500 @ stand still
miss fire full throttle @ 5000 and no power
we think its the spark plugs? but any idea
ft86-UAE is offline   Reply With Quote
Old 11-06-2012, 03:20 PM   #2
empower-auto
Kouki-Monster
empower-auto's Avatar
hopefully you're running something with a cooler heat range
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 11-06-2012, 03:34 PM   #3
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
I agree... try fresh plugs properly gapped two steps cooler. How fresh are yours? Have you taken them out and looked at them?
http://www.ngksparkplugs.com/tech_su...qs/faqread.asp
Jeff86 is offline   Reply With Quote
Old 11-06-2012, 05:59 PM   #4
ANTI_LAG
ANTI_LAG's Avatar
Drives: Ones with Big Turbos
2 steps colder plugs? Those are going to foul out real quick.
To the op you need to make sure your tune is 100% before thinking its something else, if it is in fact, gap the plugs down to .022. Also if you were tuning it and ran very rich for a while then you might have fouled out the plug. Any vacuum/boost leaks after the maf will also make the car misfire.
Are you tuning on e85, pump or racegas? What boost level are you at?
ANTI_LAG is offline   Reply With Quote
Old 11-06-2012, 06:20 PM   #5
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Two steps colder from the NA plug on a turbo application has worked perfectly for me for many years.
Old 11-06-2012, 06:35 PM   #6
ANTI_LAG
ANTI_LAG's Avatar
You know the FRS already has a 9 in it right?
Also heat range will depend on Amount of boost and power you plan on running. If you just throw too cold of a plug in it you will just foul them out all the time.
The Following User Says Thank You to ANTI_LAG For This Useful Post:
Jeff86 (11-06-2012)
Old 11-06-2012, 06:38 PM   #7
Dustin@Dynosty
this.
check your logs/tune depending on ecu of choice and pull the spark plugs and inspect then correct the issue causing the problem. if you have fouled your plugs we can hook you up with a step colder plug that we have been using in our turbo setup
Dustin@Dynosty is offline   Reply With Quote
Old 11-06-2012, 07:26 PM   #8
coyote
coyote's Avatar
Drives: Slowly
What brand of plug are you using?
Going from an 8 to a 7 generally means a HOTTER plug.
coyote is offline   Reply With Quote
The Following User Says Thank You to coyote For This Useful Post:
Jeff86 (11-06-2012)
Old 11-06-2012, 08:20 PM   #9
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
That was really bone headed on my part. You are absolutely right. I am two steps colder on the K, but it was from a 7 *facepalm*. Had to check when I got home. Apologies.
Old 11-06-2012, 09:23 PM   #10
ANTI_LAG
ANTI_LAG's Avatar
If your running 93 on this car your probaley not even going to be running enough boost to need to change the plug to a colder unit. If your running a different fuel and higher boost then yeah you should. Just my 2 cents.
Old 11-06-2012, 09:52 PM   #11
coyote
coyote's Avatar
Drives: Slowly
Unless it's E85, then you don't need (nor want) colder plugs.
Old 11-07-2012, 12:16 AM   #12
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
In the 45 degree celcius heat that you may be trying to tune/operate in, you should be a couple of heat ranges colder
Also, how much boost pressure are you making?
And, what is current AFR in the rpm ranges you mention?
A miss like that doesnt sound great to me, especially on a neutral throttle, I would be having kittens if I was you.
Toyota 86 test driver
Tradewind is offline   Reply With Quote
Old 11-07-2012, 12:29 AM   #13
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I hardly see these plugs missing. they are a good heat range for turbo, and they come gapped at around .032. That gap is good for quite a bit of boost with a proper high power ignition system and iridium plugs.
On a GT30r type setup I could only see spark blow out after 18psi or so... perhaps running too rich?
Coheed is offline   Reply With Quote
Old 11-07-2012, 12:56 AM   #14
Blue86
Drives: Sonic Blue 86GT Manual
but isn't checking the plugs a 4 day arctic expedition on these things?
Blue86 is offline   Reply With Quote
AVO Turbo Kit for Oz 86drift Australia Classifieds 52 04-14-2013 02:25 AM
turbo jmaryt BRZ First-Gen (2012+) — General Topics 7 10-24-2012 01:20 PM
Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? HitTheGas BRZ First-Gen (2012+) — General Topics 12 02-21-2012 02:24 PM
Turbo FR-S Mino Engine, Exhaust, Transmission 24 12-16-2011 09:42 AM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 07:20 PM
