Old 11-01-2012, 11:09 AM   #15
choi0706
Drives: t
anyone have these?
http://www.saikoumichi.com/index.html
choi0706 is offline   Reply With Quote
Old 11-01-2012, 11:51 AM   #16
Dezoris
Dezoris's Avatar
Canning the breather tube is a waste IMO unless you spend all your time on the track.
You just wont see any oil in the intake tube. The PCV valve to intake manifold is where almost all blow by occurs. This all changes if you are running a turbo or supercharger, the increase internal pressure. Two cans would be needed to keep your
Old 11-05-2012, 11:54 AM   #17
Dezoris
Dezoris's Avatar
Originally Posted by choi0706 View Post
Those are also excellent cans.
Old 11-05-2012, 12:19 PM   #18
gmookher
I ran a moroso on the breather but didnt catch more than a few drops of condensate.
got rid of it and cant say I am finding lots of oil in the intake, just a little, and thats only after hardish drives.
are you catching much with this thing?
Old 11-05-2012, 06:12 PM   #19
Dezoris
Dezoris's Avatar
I will report back, on my previous car it was always half full at 2000 miles and full at 4500 miles on a DI motor.
Old 11-06-2012, 05:16 PM   #20
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
I have the can! just need to fab a bracket. I was thinking about using D3PE's design where we wedge a 90 degree steel/alu plate under the battery.
Detailed pictures to come when the install happens!
F1point4 is offline   Reply With Quote
Old 11-06-2012, 09:20 PM   #21
Dezoris
Dezoris's Avatar
Looking forward to it!!!
Old 11-07-2012, 07:43 PM   #22
Dezoris
Dezoris's Avatar
Here you go about 350 miles of moderate driving, no track days or autox.
29MPG the can is already doing it's job.
I can't imagine how much oil blow by it would see under hard driving.
So far looks like this is an important addition, namely with running 0w20 the oil mist is like water.
Better yet would you want this blow by oil back in the crank case like how Crawford does it?
Old 11-07-2012, 07:51 PM   #23
wootwoot
Drives: FRS
Dezoris- I am going to supercharge the car down the road. Would the can and plumbing you have work well for a supercharged application? Or would I want a different configuration for that application?
Old 11-07-2012, 11:55 PM   #24
Dezoris
Dezoris's Avatar
Well if you decide on the Radium, you can order one can now set it up per the DIY. If you decide to to go SC and Intercooler you would want a second can to make sure you are not coating the intercooler and pipes with oil. Blow by increases greatly under boost where you would see more oil being pushed through the breather tube.
Whether you choose the radium can or not you would definitely want two for SC or Turbo applications one for the PCV Valve to the manifold (per DIY) and one for breather tube from block to intake.
Per picture they would just sit side by side.
Old 11-08-2012, 12:12 AM   #25
wootwoot
Drives: FRS
Perfect. Thanks.
Old 11-13-2012, 10:44 PM   #26
Dezoris
Dezoris's Avatar
Updated: I switched the PCV to Inlet Barb to the 90 Degree 2 Piece Barb at 0.425"
See here:
Old 11-29-2012, 01:59 PM   #27
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
Does this com with an instruction manual? LOL! I interested in getting the dual catch can coz im thinking of slapping in an SC on january.
JackSmiley is offline   Reply With Quote
Old 11-29-2012, 02:08 PM   #28
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Technically I think they do. I just installed mine, never opened the little booklet with it though. Since they are universal it's not going to be step by step like this DIY is
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
2013 FR-S Product Technical Info and Specs (from Las Vegas press event) ichitaka05 Scion FR-S / Toyota 86 GT86 General Forum 53 07-19-2021 05:59 PM
Fifth Gear reviews the GT86 (Full Video) lazyluka Scion FR-S / Toyota 86 GT86 General Forum 20 10-10-2012 06:09 AM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
Full Specs and Info on GREDDY SCION FR-S vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 109 01-02-2012 11:11 PM
