Old 11-06-2012, 01:26 PM   #295
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Originally Posted by jadewbj View Post
That makes this kit very interesting to me.
Me too... that's awesome.
Jeff86 is offline
Old 11-06-2012, 02:02 PM   #296
MattF
MattF's Avatar
Drives: s13<EP3<s14<RSX TYPE-S<WRX<GTI<FR-S
Originally Posted by gmookher View Post
okay I see it now. I didnt realize that it was water to air. That takes this off my list easily.
why? Ait to air is what I prefer for heavy duty use. Its whats on my other two turbo cars.
Pro’s of a water cooled intercooler system
1.Really good efficiency, so the size of the intercooler can be smaller.
2.Efficiency can be exaggerated by using ice, or other chemicals to produce normally un-realistic temperatures for short amounts of time.
3.Can be mounted anywhere along the charge piping route.
Con’s
1.Requires a lot of other accessories to work right.
2.Because it is more complex, it naturally causes more opportunity for problems, like leaks.
3.Can become heat soaked when used for long periods of hard driving and become terribly in-efficient and stop working completely.
Something that sized can be had for much less than an air to air that covers the whole front grille
Thats not to say air to air doesnt have its give an take either:
Pro’s
1.Requires no power to work and therefore is easy to set up.
2.Requires no liquids to work and therefore no chances for leaks .
3.Doesn’t suffer from heat-soak as long as the intercooler is seeing good airflow.
Con’s
1.Efficiency is only as good as the ambient air temperature.
2.Efficiency is only as good as the amount of airflow the intercooler see’s.
3.Cannot be mounted anywhere, since it must be mounted in a location to see airflow.
dont take my word for it, read where I got this from here, the conclusion is at the bottom of the page of the article linked below, you can form your own decisions, price to performance choices can be critical with these components. This is a nice kit, prolly fine for DD in northern latitudes. Just not for me where I drive it hard when its triple digits outside. Thanks for letting me learn about it.
http://www.enginebasics.com/Advanced...tercooler.html
Air to air can leak just not in the same way. With the additional pipping required it makes a hard to troubleshoot boost leak more possible.
Also to consider is the additional pipping can cause unwanted lag in a small displacement engine. Since a lot of the turbo kits have lots of pipping and hard bends it should be something factored in your decision. Subaru used top mount intercoolers for a reason.
Sent from my Galaxy Nexus using Tapatalk 2
MattF is offline
Old 11-06-2012, 02:04 PM   #297
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That pricing is right where I want it to be. I just need to know when and where I can order one. After my buddy got a Terminator a month ago, I have been loving the idea of this kit. Now to see if I can get a Killer Chiller to work with it.
King Tut is offline
Old 11-06-2012, 02:16 PM   #298
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Looks good, all the discussion is making me dizzy. Ill just wait for someone(SHOP) to install it and run it. Lets see how much power it makes, how cool it sounds and what kind or wtq curve it gives us, as well as how reliably it behaves. In for updates.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline
Old 11-06-2012, 02:26 PM   #299
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Me too! Impressive. That's an $850 to $1000 value on its own! Liking the sound of this more and more!
pixel67 is offline
Old 11-06-2012, 02:28 PM   #300
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
Is there going to be an option for those that already have an ECUtek cable and license and simply would just need the tune?
TomR
ABQautoxer is offline
The Following User Says Thank You to ABQautoxer For This Useful Post:
draggin_az (11-06-2012)
Old 11-06-2012, 02:44 PM   #301
Pete
Pete's Avatar
Drives: 22 BRZ
Originally Posted by mines13 View Post
Both versions of the complete kits include the physical ECUTEK cable and re-flash. You will not need to borrow or purchase a cable on your own. The "tuner" version of the kits however will not include the cable.
That is a significant point in your favor. If I already have a cable/license can that be discounted from the price?
Pete is offline
Old 11-06-2012, 03:12 PM   #302
Innovate Motorsports
Drives: Scion FRS, Subaru BRZ, Supercharged
You will be able to purchase a version of each kit without the ECUTEK cable if you already have your own, and wish to obtain a custom tune through a local shop yourself. They will be cheaper then the complete kits, but I do not have final pricing on them quite yet.
Innovate Motorsports is offline
Old 11-06-2012, 03:16 PM   #303
ABQautoxer
ABQautoxer's Avatar
Thanks. I'm hoping you'll still supply a tune, just not the cable/license which is typically a $600 cost that some of us have already spent to use other ECUtek tunes.
TomR
Old 11-06-2012, 03:18 PM   #304
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
EDIT- Innovative beat me to it.
I'm sure they'd be willing to work something out for those people who already own the ECUTek cable.
SubieNate is offline
Old 11-06-2012, 03:24 PM   #305
ABQautoxer
ABQautoxer's Avatar
I think there is some confusion to how ECUtek does this:
1. Cable $250 does nothing by itself, but if you have 2&3 you can install/datalog tunes
2. License for your ECU. One per ECU, $350. required to do everything including datalogging.
3. Tune - supplied by a ECUtek professional tuner. Vary from $50-300.
You must have 2 and 3 to have ANY ECUtek tune. So if I bought this SC kit, I would only need #3. So saying you don't need the cable doesn't cover the important aspect of wanting the OE developed tune by then vendor rather than a start from scratch one done by a 3rd party. Another vendor offers their kit with just #3, the tune. I'm hoping Innovate would perhaps offer the same model as for some (and maybe its just few) of us it would work nicely.
EDIT: I wanted to add I'm a huge fan of this product. I'm trying not to be a pest, I promise you I say this honestly as a possible customer and perhaps part of a customer base of early adopters of tunes that might go this route.
TomR
Old 11-06-2012, 03:27 PM   #306
Pete
Pete's Avatar
Drives: 22 BRZ
Awesome. I'm looking forward to the stage 2 kit dynos. :happy0180:
Pete is offline
Old 11-06-2012, 03:42 PM   #307
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
subscribed
has the s/c been installed and tested or am i too early to ask?
draggin_az is offline
Old 11-06-2012, 03:44 PM   #308
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Are you guys going to submit this for CARB EO?
uspspro is offline
***Recaro / Racetech / OMP / STATUS / Defi / Apexi / HKS / Innovate / AEM / Cobb***** Touge Factory Interior Parts (Incl. Lighting) 9 11-29-2012 02:13 PM
lost screw for sensor intake Mr.Jay Engine, Exhaust, Transmission 5 10-21-2012 09:26 PM
Lowest Prices on all Gauges and Electronics! Defi|STRI|AEM|INNOVATE+More Rev Works Audio/Visual, Electronics, Infotainment, NAV 28 10-09-2012 05:04 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
Missing rubber piece for intake screw ngabdala Engine, Exhaust, Transmission 1 08-31-2012 06:10 AM
