Old 11-06-2012, 02:14 AM   #99
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
The 86
@post_break
20121103-November2012CarsAndCoffee-3 by VictorN07, on Flickr
20121103-November2012CarsAndCoffee-20 by VictorN07, on Flickr
20121103-November2012CarsAndCoffee-24-Edit by VictorN07, on Flickr
20121103-November2012CarsAndCoffee-37-Edit by VictorN07, on Flickr
20121103-November2012CarsAndCoffee-40-2 by VictorN07, on Flickr
20121103-November2012CarsAndCoffee-52 by VictorN07, on Flickr
@Chris@Phastek's FR-S. Love the White headlights and halo
20121103-November2012CarsAndCoffee-123-2 by VictorN07, on Flickr
20121103-November2012CarsAndCoffee-125-2 by VictorN07, on Flickr
20121103-November2012CarsAndCoffee-126 by VictorN07, on Flickr
Cover Craft. Thanks @dcamco for showing us
20121103-November2012CarsAndCoffee-182 by VictorN07, on Flickr
20121103-November2012CarsAndCoffee-185 by VictorN07, on Flickr
20121103-November2012CarsAndCoffee-183 by VictorN07, on Flickr
The others
Here are a few more
20121103-November2012CarsAndCoffee-69 by VictorN07, on Flickr
20121103-November2012CarsAndCoffee-89 by VictorN07, on Flickr
20121103-November2012CarsAndCoffee-73 by VictorN07, on Flickr
20121103-November2012CarsAndCoffee-66 by VictorN07, on Flickr
20121103-November2012CarsAndCoffee-155 by VictorN07, on Flickr
Full set on my flickr
http://www.flickr.com/photos/victorn...7631940133265/
F1point4 is offline   Reply With Quote
The Following User Says Thank You to F1point4 For This Useful Post:
SkAsphalt (11-06-2012)
Old 11-06-2012, 11:56 AM   #100
Turbowned
Turbowned's Avatar
The LF-A has a hood prop rod?? A $375,000 car has a prop rod??
The Following User Says Thank You to Turbowned For This Useful Post:
gt8613 (08-31-2013)
Old 11-06-2012, 01:20 PM   #101
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
lighter then 2 struts for sure
Silverdub is offline   Reply With Quote
Old 11-06-2012, 01:27 PM   #102
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Gulfstream aqua/orange...drroooool...
I have that Cobra shirt!
Dude, awesome pics. Of course, great subjects too.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 11-06-2012, 02:23 PM   #103
NJA
Drives: Supercharged Saturn ION
Nice journal, very detailed
NJA is offline   Reply With Quote
Old 11-06-2012, 02:28 PM   #104
ModBargains.com
ModBargains.com's Avatar
Great thread! Thanks for sharing!
ModBargains.com is offline   Reply With Quote
Old 11-06-2012, 02:49 PM   #105
F1point4
Photo Specialist
F1point4's Avatar
I'm a statwhore. Here are my fuel economy graphs, complete with distance travelled, fuel consumed, and price since I purchased the car June 9th. I also overlayed my mods on these charts.
I believe only the tires made a noticeable difference in fuel economy. Also note my driving habits have not been constant. I've been a wee bit more aggressive after the exhaust got put on
Probably not groundbreaking news, but I like the way the fuel price is trending. I was out of the country in July. Right now I have 5263 mi on the odometer
Trip Computer Lifetime Average: 28.2 mpg
20121106-LolaFuelConsumption-01 by VictorN07, on Flickr
20121106-LolaFuelConsumption-02 by VictorN07, on Flickr
Old 11-06-2012, 02:50 PM   #106
pr086
Drives: fast
is the LFA one of the few cars with a lower center of gravities than us? that engine looks like it's sitting pretty high
pr086 is offline   Reply With Quote
Old 11-06-2012, 02:55 PM   #107
F1point4
Photo Specialist
F1point4's Avatar
It does look pretty high
20121103-November2012CarsAndCoffee-70 by VictorN07, on Flickr
Old 11-06-2012, 04:53 PM   #108
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
It is a v10, it is all tucked away UNDER that light carbon/plastic intake tubing
Old 11-06-2012, 05:02 PM   #109
zaptorque
zaptorque's Avatar
Drives: 2013 Asphalt FR-S
Love the car, with the exception of the A&M license plate holder....
zaptorque is offline   Reply With Quote
Old 11-10-2012, 09:06 PM   #110
F1point4
Photo Specialist
F1point4's Avatar
Installed the Radium catch can today.
Fabbed a bracket that wedges under the battery tray. Here are some quick observations after pulling the battery. Note I pulled it a few times
+Unplugging the battery resets your lifetime average MPG.
+It does not change the odo or both trip meters
+your gear display switches back to default which is off
+the rev indicator resets back to redline 7400 rpm
+bespoke does not lose it's settings, Bluetooth pairings, phone book, etc
+ the time resets to 1:00
+each time I did it, the drive by wire gas pedal felt much less responsive. Like i had to press hard to register throttle. Almost stalled it the very first time I drove after pullin the battery. I think the ECU is affected by the battery pull. Took a few miles for it to feel more normal.
+you have to try to start the car twice. The first time the car acts as if you didn't press the clutch. Try the 2nd time and it works
+you need to roll the windows down and up for the car to crack the windows when you open the door
+locks, trunks don't work without power
Old 11-11-2012, 02:08 AM   #111
2point0
2point0's Avatar
What is this you speak of?
The ECU gest reset with no power and needs to relearn. There was a shortcut on the WRX/STi that required holding a certain amount of boost at a certain RPM for a few seconds to make the ECU catch up right away. Otherwise, you have to drive a bit for it to go through some necessary cycles.
It's good to reset the ECU after installing performance mods so it can adapt to them better. If you really hate losing radio presets and all that stuff, you can also just unplug the ECU for a bit and plug it back in. Bit of a PITA to get just for this, though.
Old 11-11-2012, 08:30 AM   #112
F1point4
Photo Specialist
F1point4's Avatar
This is the setting where the car will tell you what gear you are in for manual gearbox cars. I find it useful because from time to time I forget what gear im in. It's one of those things you can set using the gauge cluster switches when the car is not on.
Asphalt Scion FR-S aznsensazian FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 21 03-17-2014 02:13 PM
Asphalt FR-S pics Rob_g CANADA 24 09-03-2012 06:01 AM
Asphalt in the snow Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 06-10-2012 02:56 PM
Asphalt 6MT FR-S Symbiont Southern California 22 06-06-2012 08:47 AM
ant08 Asphalt MT ant08 Member's Car Journals 3 06-04-2012 05:16 PM
