Old 11-05-2012, 08:07 AM   #1
brn12345
brn12345's Avatar
Parts interchange with other Aisin AZ6 transmissions
Would be very useful if we can figure out if any of the other AZ6 Aisin transmissions share parts with our transmission. The cars that i know have this tranny are: S2000, Miata, Silvia S15, RX8
Sixth gear on the Miata looks like a good short ratio replacement at 0.843 vs 0.767 if it would fit.
brn12345 is offline   Reply With Quote
Old 11-05-2012, 08:53 AM   #2
UncleFester
Why would you want a shorter sixth? :confused:
UncleFester is offline   Reply With Quote
Old 11-05-2012, 08:56 AM   #3
brn12345
brn12345's Avatar
For circuit racing. From experience with the Honda I used to race, the stock brz 6th is long.
The Following User Says Thank You to brn12345 For This Useful Post:
jcw99 (08-13-2019)
Old 11-05-2012, 11:53 AM   #4
gmookher
Youre trying to fix a power problem with a gear swap?
Old 11-05-2012, 11:58 AM   #5
canu_50
canu_50's Avatar
Drives: Scion fr-s
Which is usually what we do in road racing, yes.
canu_50 is offline   Reply With Quote
The Following User Says Thank You to canu_50 For This Useful Post:
SkullWorks (11-05-2012)
Old 11-05-2012, 12:06 PM   #6
gmookher
just wondering, it sounds, reading in between the lines, that you want a shorter 6th or more top end power (I'm usually only in 6th AFTER i have wound out 5th)
sadly the tracks by me dont let me use 5th or 6th much, but I could see in a circuit that being possible
any reason you wouldnt consider FI as a way to add power instead? not trolling, just askin seriously
if tranny mods and interchangeability can be found, that would be very neat
Old 11-05-2012, 12:32 PM   #7
xwd
Yeah I'm wondering which tracks you are driving on where you are in need of a marginally shorter 6th gear?
There are a number of final drive kits to raise the overal final drive ratio. At least one company (Monster sport I think) has also made a kit with a longer 1st and 2nd gear.
Old 11-05-2012, 01:39 PM   #8
canu_50
canu_50's Avatar
Drives: Scion fr-s
For me i would say that in the area where i live, i know there would be more racing class open if i am staying N/A compare to F/I.
Old 11-05-2012, 04:15 PM   #9
SkullWorks
Drives: SSM LT MT BRZ
honestly in N/A form you don't need a 6th gear in this car unless you have already put a shorter gear out back.
Old 11-05-2012, 04:39 PM   #10
donutfilling
donutfilling's Avatar
Drives: frs
just change the final gear
donutfilling is offline   Reply With Quote
Old 11-05-2012, 04:50 PM   #11
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
What exactly is the name of the Manual Transmission? If its the same one in the s2000 then we have a very strong transmission to work with. S2k run 600hp without touching the tranny or rear
Tansey86 is offline   Reply With Quote
Old 11-05-2012, 05:03 PM   #12
canu_50
canu_50's Avatar
Drives: Scion fr-s
anybody know what is our final drive i haven't seen it.
Old 11-05-2012, 05:04 PM   #13
UncleFester
4.10
Old 11-05-2012, 05:20 PM   #14
serialk11r
Drives: '06 AM V8V Coupe
You could use shorter 6th + higher final drive to get the 6th close to the old 5th, giving you an extra gear. A 0.83 6th would be "effective" for reaching top speed (might need a few aero tweaks to hit high 150s) but sorta useless on the track due to lack of power, but with a slightly higher final drive bumping it up to effectively 0.9 or so could make it useful.
But then, after you've put a higher final drive in, 6th will automatically become "more useful" and so whether or not the effort it takes to change 6th gear out becomes more questionable, since it'll only gain you very little speed for the short amount of time you can spend above 140mph, and make your car less practical for the highway. Additionally, considering the powerband of this motor (plateaus pretty hard at the top end), a shorter 6th only gives you marginally more power (look at any dyno chart and keep in mind that shifting out of 5th lands you at 5700rpm-6000rpm if the rev limit has been increased).
For example with 10% higher final drive, your 6th is effectively a 0.8437, and 6th would top out at about 162mph, power peak with tune arrives at perhaps 155mph or so. It should take somewhere around 200hp (ecomodder calculator says 170hp, but I just punched in 2 square meters and 0.27 Cd, I don't know what the actual CdA is) to go 160mph, so you should be able to just top out 6th gear. Assuming the engine has a tune, you have about 50-80hp "reserve power" after topping out 5th gear for accelerating after drag is accounted for. Shortening 6th would reduce the top speed, but let you reach the top speed faster.
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 11:30 AM
What other engines fit our transmissions 1strwdcar Engine, Exhaust, Transmission 36 08-02-2012 05:45 PM
The BRZ / FR-S / GT 86 transmissions and driveline: what we know so far jruhi4 Engine, Exhaust, Transmission 25 02-17-2012 04:33 PM
AU gets TRD parts PuGZoR AUSTRALIA 17 02-08-2012 07:57 PM
