Old 08-08-2011, 11:09 AM   #309
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'll likely be waiting for the Subaru version in Spring assuming the Scion doesn't have better parts/suspension/etc. At least then I'll be able to work on the price of the car with my contacts at the local subie dealer.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-08-2011, 12:31 PM   #310
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
IMO, if this car is simply a RWD version with a more powerful engine than the celica GTS it should be priced at $22,999-23,999. I think thats reasonable since that's about 1-1.5k more than a civic Si. And unlike the civic which has other counterparts this car will only have one under a different brand.
SUB-FT86 is offline   Reply With Quote
Old 08-08-2011, 12:35 PM   #311
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
That's the thing. We're not sure if it's better engine than Celica engine. Official's haven't release the final spec yet...
Old 08-08-2011, 12:39 PM   #312
bofa
Drives: Ms. Daisy
If limited supply and timing is of any concern, just visit one of the bigger dealerships in your area. They will likely let you place a deposit for a spot in line to pick from their first shipment. I did this with the tC, was second in line (behind one of the employees) and put my name down for black or flint mica. They couldn't guarantee that they would be able to get my colors on the first truck but they ended up getting 2 black, 1 flint mica, and 2 others (I think white). They called me once the boat was unloaded. I went with the flint mica, walked in, test drove, signed and left without any issue. I think the deposit was only $200, but I think up to $500 is reasonable. It was refundable as well (and should be since the supply will allow them to just move it to the next person if you cancel).
BRZ before hoes
bofa is offline   Reply With Quote
Old 08-08-2011, 05:14 PM   #313
Fly Guy
Fly Guy's Avatar
Drives: '91 MR2
Thank you!
Fly Guy is offline   Reply With Quote
Old 08-08-2011, 05:27 PM   #314
Allch Chcar
Drives: N/A
Except it's not a Toyota so the MSRP should be less due to branding .
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 08-08-2011, 08:35 PM   #315
SUB-FT86
86 Member
It's still a Toyota just branded under there lower division for N.America.
Old 08-08-2011, 09:18 PM   #316
82mm 4g63
4G63 & Rotary
82mm 4g63's Avatar
Drives: 92TalonAWD, 93RX7, 11F150EcoBoost
Send a message via AIM to 82mm 4g63
Of course it's still a Toyota, but it isn't a Toyota. When you buy a Lexus you're buying a Toyota, but does it cost the same as a Toyota? No. Same idea only reversed. When you buy a Scion you're still buying a Toyota, but it won't (and shouldn't) draw the same price tag that the exact same car with a Toyota emblem would.
82mm 4g63 is offline   Reply With Quote
Old 08-09-2011, 01:14 AM   #317
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
^That's the perception but xB and tC prices have crept up. The tC costs more than the base price of the Yaris, Corolla, Matrix, and Tacoma. A certain Nissan sports car costs way more than any vehicle coming from the premium Infiniti division.
I just hope Scion follows through with that buzzword they use over and over in their PR: "affordable."
Old 08-09-2011, 01:36 AM   #318
Allch Chcar
Drives: N/A
You have to compare the tC to the last gen Celica. Compare chassis codes between the two, not completely certain of the lineage. But the MSRP for the base Celica was more than the base tC, I believe it was a $1500 difference and the tC has a bigger engine, etc.
-Allch Chcar
Old 08-09-2011, 02:42 AM   #319
MiguelAE86
Drives: NB Miata
tC = toyota Celica?
*mind explodes*
MiguelAE86 is offline   Reply With Quote
Old 08-09-2011, 02:44 AM   #320
impulse
Just a random
impulse's Avatar
Drives: 2009 Toyota Corolla
Thought it was supposed to stand for touring coupe or something boring like that.
impulse is offline   Reply With Quote
Old 08-09-2011, 02:47 AM   #321
Dimman
Kuruma Otaku
Dimman's Avatar
With the way they spammed the import scene at the time, I would bet it was for Tuner Coupe.
Because titanium.
Old 08-09-2011, 05:35 AM   #322
switchlanez
The Celica was built on a new chassis designed and manufactured exclusively for itself and new engines (1ZZ-FE and a 2ZZ-GE higher compression engine with Lift technology, tuned by Yamaha). Its launch price in '99 reflected those costs which stuck for its entire production. The tC was built on a pre-existing chassis used by the Avensis and powered by a pre-existing 2AZ-FE Camry engine (and I believe the current gen still "borrows" major components from Toyotas). Its launch price in '04 reflected those savings. Also, you can't compare their pricing since the tC was the generational successor to the Celica. It's like comparing MkIII to MkIV Supra prices. Or the '05 MkI tC $16,545 price to the '11 MkII tC $18,275 price.
The FR-S is a special case. It is splitting costs of chassis and powertrain with Subaru. But globally, the FR-S will be a Toyota. An FT-86 sold in Japan equipped with X options should cost the same as a Scion FR-S with the same X equipment +/- things beyond their control like import fees, etc. So there should be a slight cost difference but not arbitrarily based on branding.
"Gran Turismo 5" E3 2010 Trailer Music Title Naming Campaign ichitaka05 Off-Topic Lounge [WARNING: NO POLITICS] 2 07-12-2010 10:35 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 04:58 AM
FT-86 to be "introduced" for early 2012! Press conference clip from Geneva Motorshow ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 32 03-05-2010 03:07 PM
