Old 11-02-2012, 03:11 AM   #225
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
super interesting!
guys having experience driving with twinscrew chargers - do they whine loud every time you revv higher than idle or it just becomes audible from say 3-4 RPM+?
i know this sound is addicting, but i've never driven one... could you drive silently though?
MSTiFK8R is offline
Old 11-02-2012, 08:28 AM   #226
jadewbj
jadewbj's Avatar
You can see the MSRP in this pic. $3,495 to $4,695. Not bad.
It says it includes ECUTEK, I wonder if that mean the cable too. Stage 2 has the integrated IC with injectors and a fuel pump. Sounds pretty well priced.
jadewbj is offline
Old 11-02-2012, 08:52 AM   #227
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Originally Posted by FreshFRS View Post
VE isnt all of it. come down to airflow. 12.5:1 offers great VE but the head doesn't flow like a honda design so it compromises power output.
VE is not affected by compression ratio.
The head may not flow 290cfm like the k20 head, but it probably flows around 270cfm. Head flow is great, but velocity is more important. The K has great port velocity throughout the rev range.
Coheed is offline
Old 11-02-2012, 09:16 AM   #228
RedRocket
RedRocket's Avatar
Drives: Firestorm Red FR-S
Originally Posted by MSTiFK8R View Post
super interesting!
The ONLY one I've ever heard you could hear a higher pitch whine to it, but it wasn't offensive.. You could definitly tell there was something going on under the hood... If you knew what twin screws sound like you could tell it was there, but it didnt give the "Scream" that their known for untill around 2k RPMS..
RedRocket is offline
The Following User Says Thank You to RedRocket For This Useful Post:
MSTiFK8R (11-02-2012)
Old 11-02-2012, 09:26 AM   #229
RedRocket
RedRocket's Avatar
This unit looks really good.. The Vortex Gossip is expecting bigger numbers.
Old 11-02-2012, 09:46 AM   #230
TheRipler
Reap the BReeZe
Drives: 04 LandShark STi
super interesting!
Since this works with the OEM airbox, it should be more quiet than a SC with it's own intake / open filter. The only way we'll really know how much noise it will make is listening once it's released.
TheRipler is offline
The Following User Says Thank You to TheRipler For This Useful Post:
Old 11-02-2012, 09:55 AM   #231
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Curious on how well the intake runners flow compared to stock
I am sure it will cost more as well, but only time will tell.
Ricepuddin is offline
Old 11-02-2012, 09:58 AM   #232
wcbjr
Drives: 2006 Subaru LGT
I wonder how the hood clearance is with the intercooler underneath the unit.
wcbjr is offline
Old 11-02-2012, 10:13 AM   #233
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
why exactly do you care if it fits "by inch or a mile? )
MSTiFK8R is offline
Old 11-02-2012, 10:18 AM   #234
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
It actually says an ECUTEK calibration. A cal is just the tune... you'll have to buy or borrow a cable I'm sure.
Jeff86 is offline
Old 11-02-2012, 10:52 AM   #235
wcbjr
Because I don't think there is room for one at all.
wcbjr is offline
Old 11-02-2012, 11:26 AM   #236
gmookher
theres PLENTY of room...
gmookher is offline
The Following User Says Thank You to gmookher For This Useful Post:
FreshFRS (11-02-2012)
Old 11-02-2012, 11:32 AM   #237
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
yeah back in the Bullet thread they said that hood clearance was a non-issue
Jeff86 is offline
Old 11-02-2012, 11:42 AM   #238
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
yah flow is not bad thats for sure, 100hp/l is pretty hard to attain if your head flow is shitty. someone should put our head on a flow bench and check it out!
FreshFRS is offline
***Recaro / Racetech / OMP / STATUS / Defi / Apexi / HKS / Innovate / AEM / Cobb***** Touge Factory Interior Parts (Incl. Lighting) 9 11-29-2012 02:13 PM
lost screw for sensor intake Mr.Jay Engine, Exhaust, Transmission 5 10-21-2012 09:26 PM
Lowest Prices on all Gauges and Electronics! Defi|STRI|AEM|INNOVATE+More Rev Works Audio/Visual, Electronics, Infotainment, NAV 28 10-09-2012 05:04 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
Missing rubber piece for intake screw ngabdala Engine, Exhaust, Transmission 1 08-31-2012 06:10 AM
