Old 10-31-2012, 11:31 PM   #183
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I would like to see a shop get a hold of one of these and see what its max output is. I don't expect 500hp, but I'd like see what it can do. I really want to see what the torque curve looks like.
My big worry is the strength of the rest of the drivetrain. The high power turbo builds are bringing the boost in late to ease the strain on the driveline. This will deliver power down low.
Draco-REX is offline
Old 10-31-2012, 11:59 PM   #184
sw20kosh
Drives: 2013 Black FR-S
This size of a twin screw positive displacement supercharger is not ideal for high boost and big horsepower numbers. You will get bigger numbers on any other type of FI kit as they are all more efficient than this type of FI.
And the turbo kits are not "bringing the boost in late to ease the strain on the driveline" on purpose. It is just the nature of a turbo. A certain amount of exhaust energy is needed to generate boost. On the kits you are talking about this point is not reached till X rpm.
sw20kosh is offline
The Following User Says Thank You to sw20kosh For This Useful Post:
ill86 (11-07-2012)
Old 11-01-2012, 12:29 AM   #185
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
this is true. high boost can be attained but with terrible efficiency. Eatons TVS would be over 70% efficient to about 12psi. therefore its pretty comparable to turbos and centrifugals. above that a centrifugal or turbo is going to be better but with less area under the curve and less transient response (respectively)
FreshFRS is offline
Old 11-01-2012, 01:06 AM   #186
serialk11r
Drives: '06 AM V8V Coupe
Well more accurately, low end boost from a turbo is extremely inefficient, but high end boost with a high A/R housing is quite a bit more efficient than any supercharger by virtue.
The problem with Roots superchargers is that their efficiency is somewhat speed dependent, and while you can hit 70% efficiency at higher boost levels sometimes, most of the time you can't. The TVS units seem happiest at the 0.6-0.7 bar boost level, rather modest. Centrifugal SC is also quite speed dependent but it's easy to land most of the operating zone into the high efficiency "islands" because boost goes up with speed.
Also worth mentioning is that positive displacement blowers are a bit bigger and heavier.
serialk11r is offline
Old 11-01-2012, 01:17 AM   #187
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
i would say the 70% margin goes up to 2.4 PR or about 1.4bar. highest efficiency for 3500-7400 RPM at .9 bar is ~74% using the performance map for the next generation prototype R1100. .9 bar 1500-3500 is above 68-72% as well. 1.2BAR would be 68% 3500-4500, 4500+ is still in the 70% range. huge advance over the current generation.
as for being heavier that is true, but with the tubing, BOV, Intercooler, and charger weight differences should be relatively small.
the maximum efficiency of 76% is reached at 6900rpm @ .9bar
FreshFRS is offline
Old 11-01-2012, 01:26 AM   #188
serialk11r
Where did you get R1100 information? Just curious.
It'll be interesting to see how Eaton's TVS line develops and how much adoption it sees, that's for sure.
Old 11-01-2012, 01:34 AM   #189
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Got it from a brochure they sent me called "downsizing" (i get these just to stay up to date.) the map looks pretty much like the current R1320, but a little less flow and a much bigger plateau that registers as 74%. starts at .5Bar-.8Bar 250CFM and stops at 650CFM .5BAR through 1.0bar. the widest section ~450CFM (if my calcs are correct gives ~6200RPM in our motor) goes to 1.2BAR at the upper limit. 76% is attained about ~6800-7400 at .9bar (520-550CFM)
I also Emailed eaton about dimensions of the prototype and whether i would be able to test it. (hopefully it will fit on Innovates manifold.
FreshFRS is offline
Old 11-01-2012, 08:55 AM   #190
Draco-REX
Corner Junkie
Draco-REX's Avatar
I'm more interested in the area under the torque curve. This should give a much fatter curve than a turbo. Great for AutoX and slow tracks.
It was specificly stated by Visconti in one of the Accelerated performance threads that they were not bringing the boost up as quickly as they could in order to limit stress on the transmission as much as possible. Doing the same with this supercharger would negate its main benefit, so the transmission will have to put up with a lot of low-end torque.
Old 11-01-2012, 08:58 AM   #191
Draco-REX
Corner Junkie
Draco-REX's Avatar
One of the drag racing guys on another forum managed to ID the core:
http://www.sprintex.com.au/sprintex/superchargers/
looks like the S5-210.
Old 11-01-2012, 09:56 AM   #192
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Man this thread Is entirely updated by board members and not innovative.... Whats up with that guys?
TouchMyHonda is offline
Old 11-01-2012, 10:01 AM   #193
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
I'd cut them some slack until at least a week or so after SEMA. Not a whole lot of vendors posting right now due to it.
TomR
ABQautoxer is offline
Old 11-01-2012, 11:04 AM   #194
Dipstik-sportech
Dipstik-sportech's Avatar
Did I not say days ago that its just a powdercoated sprintex kit?
Dipstik-sportech is offline
Old 11-01-2012, 11:21 AM   #195
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Im exited, this is the edge that would let me take the gt-3's at the track. I own them in the corner entry and exit but get eaten in the straightaway.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline
Old 11-01-2012, 11:23 AM   #196
RYU
RYU's Avatar
Drives: really slow...
I hope someone post pics of the Laminova setup. From this angle you can't see much by way of an aftercooler.
RYU is offline
***Recaro / Racetech / OMP / STATUS / Defi / Apexi / HKS / Innovate / AEM / Cobb***** Touge Factory Interior Parts (Incl. Lighting) 9 11-29-2012 02:13 PM
lost screw for sensor intake Mr.Jay Engine, Exhaust, Transmission 5 10-21-2012 09:26 PM
Lowest Prices on all Gauges and Electronics! Defi|STRI|AEM|INNOVATE+More Rev Works Audio/Visual, Electronics, Infotainment, NAV 28 10-09-2012 05:04 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
Missing rubber piece for intake screw ngabdala Engine, Exhaust, Transmission 1 08-31-2012 06:10 AM
