Old 10-31-2012, 09:22 PM   #1
Slartibartfast
Klaatu barada nikto
Slartibartfast's Avatar
Drives: Raven FR-S MT
Wilwood BBK
Been waiting for these guys to put out a BBK?
Yup... me too!
FOR IMMEDIATE RELEASE:
Wilwood Disc Brakes introduces new Big Brake front and rear upgrade kits for the Scion FR-S and Subaru BRZ
Camarillo, CA • October, 2012
Wilwood Disc Brakes has recently introduced front (P/N 140-12870) and rear (P/N 140-12871) high performance brake kits for the Scion FR-S and Subaru BRZ that features the latest in disc brake technology. These track-tested brake kits not only provides better performance, but also huge improvements over the original brakes on the track where consistency counts.
Big brake clamping power for the front is delivered by Forged Narrow Superlite 6R (FNSL6R) radial mount six piston calipers. FNSL6R calipers incorporate a proven differential piston bore configuration that provides balanced pad loading for even wear and maximized clamping power. For the rear are large Forged Narrow Superlite 4R (FNSL4R) four piston symmetrical bore calipers. The calipers are available with either black or red high-gloss, high-temp, brake fluid resistant sealed powder coat and feature Wilwood’s signature logo. Wilwood’s new Quick-Silver series coated calipers are also available as an option by special order.
Both front and rear brake kits come with 12.88" diameter GT competition series, or SRP drilled and slotted rotors to maximize braking capacity and match style with your wheel size and design. GT rotors are fully detail machined from premium grade carbon iron castings, face slotted, and individually dynamic balanced to provide true and precise running at all speeds. SRP performance rotors feature Wilwood’s signature directional drill and slot design with a protective E-coat finish. The drill and slot pattern adds race-tech styling and the venting qualities that preserve pad performance. The heat resistant E-coat finish protects the rotors from rust on all areas that are not swept clean by the brake pads.
Stopping power is provided by BP-10 compound Wilwood "Smart Pads". BP-10 is a unique metallic composite formula that provides quiet engagement and low dusting, but with the added temperature range and higher friction values of a semi-metallic compound pad. BP-10 runs clean and quiet on the street, with improved stopping power and fade resistance for tough roads and lighter duty use during those fun days at the track. Optional high-temp and race only pad compounds are also available.
All of Wilwood’s performance brake kits are loaded with cutting edge technology built on decades of domination in world motorsports, and proven reliable through Zero PPM defect supply to OEM’s. These kits will not only exceed your braking demands, on and off the track, but also enhance the appearance of your Scion or Subaru.
For more information contact: Wilwood Engineering at (805) 388-1188 and request to speak with Erika Gordillo for marketing issues, or Andy Fritts for technical questions. Also, Wilwood’s website is accessible at www.wilwood.com or e-mail customerreply@wilwood.com
File Type: pdf wilwood_scion_subaru_front_and_rear_brake_kits[1].pdf (126.5 KB, 551 views)
I vow to do no harm.
2013 Raven FR-S Manual "Lenore"
1985 Silver RX-7 GSL-SE (Gone and missed)
Slartibartfast is offline   Reply With Quote
The Following User Says Thank You to Slartibartfast For This Useful Post:
R2RO (10-31-2012)
Old 10-31-2012, 09:37 PM   #2
JWMotoring
JWMotoring's Avatar
Drives: FR-S baby!
They make some of the best big brake kits for sure.
JWMotoring is offline   Reply With Quote
Old 10-31-2012, 10:47 PM   #3
gmookher
hell yeah
Old 10-31-2012, 11:02 PM   #4
RL_BRZ
Drives: BRZ WRB Pearl Limited Manual
This Brake kits does fit in our stock wheel?
RL_BRZ is offline   Reply With Quote
Old 10-31-2012, 11:12 PM   #5
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Any idea on pricing?
kmbkk is offline   Reply With Quote
Old 10-31-2012, 11:16 PM   #6
Slartibartfast
Klaatu barada nikto
Yes, but there is a bigger rotor option for the front (so I've been told by a Wilwood rep) that will NOT fit the stock rims. But the standard BBK is designed for use with the stock rims.
I would still like to confirm this before purchasing though.
Old 10-31-2012, 11:21 PM   #7
Slartibartfast
Klaatu barada nikto
Not released yet, but I was told it would be very similar in price to the Nissan 350 kit.
Wilwoods have always been resonabily priced.
Old 10-31-2012, 11:47 PM   #8
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
Yes!!!!!! I cannot wait for these to become available and have pricing.
FR-Shadow is offline   Reply With Quote
Old 11-01-2012, 12:06 AM   #9
RYU
RYU's Avatar
Drives: really slow...
I like that they're local to me
What will be their rear e-brake solution be?
RYU is offline   Reply With Quote
Old 11-01-2012, 03:27 AM   #10
2fast4you
2fast4you's Avatar
Drives: 2006 Scion tC RS 2.0
^^ I'm a big fan of Wilwood.
Brake. Turn. Accelerate. Repeat as necessary.
2fast4you is offline   Reply With Quote
Old 11-01-2012, 04:38 AM   #11
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
love Wilwood
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 11-01-2012, 12:51 PM   #12
gmookher
WHERE
CAN
I
PLACE
AN
ORDER
Old 11-01-2012, 01:02 PM   #13
Slartibartfast
Klaatu barada nikto
Originally Posted by gmookher View Post
WHERE
CAN
I
PLACE
AN
ORDER
I've been talking with this guy:
mjimenez@wilwood.com
Miguel Jimenez – Tech Consultant/Account Manager
Wilwood Engineering
4700 Calle Bolero
Camarillo, CA 93012
Phone: 805-384-2272
Fax: 805-987-5982
Tell him Steve in Guelph Canada sent you and maybe he'll give me a deal when I pull the trigger... LOL
Old 11-01-2012, 01:28 PM   #14
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
We'll have these soon.
The rear solution uses an Iron hat and as you can see in the pictures will be able to use the stock ebrake set-up. (black caliper photos is rear)
Some more Photos from SEMA:
FT-86 SpeedFactory is offline   Reply With Quote
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
Slartibartfast (11-02-2012)
help on Wilwood brakes brackets Turbo Den Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-01-2012 09:14 PM
