Old 10-30-2012, 05:08 PM   #673
xjohnx
Grip>Slip
xjohnx's Avatar
In Australia removing any emission control equipment is a no no so a 2 cat system is required here to stay legal.
only illegal if you get caught. unless you've got a sniffer test in addition to the visual, i don't see why removing the primary and keeping a secondary is a huge risk law-wise. how many general inspection stations know these cars come with 2 cats? of those, how many are going to go through the trouble of remove the 16 or so bolts/clips to remove the under-tray and actually check when they can already see one cat in clear view about 18 inches downstream on the exhaust?
chanomatik (10-30-2012)
Old 10-30-2012, 05:19 PM   #674
OrbitalEllipses
Drives: Attitude
Originally Posted by Zadkiel View Post
And you know 100% that it will pass an emissions test with only 1 of the 2 OEM required cats? Can you show me that on your inspection papers that show it passing with just 1?
You should have a tune with headers. Tuner will disable CEL. Where I live all that's needed for emissions is an ODBII check, which will fail only if there's a CEL or readiness problem.
Old 10-30-2012, 08:39 PM   #675
Zadkiel
Drives: CBS BRZ Limited 6MT
PA does the sniffer test. Just because you can pass your version doesn't mean it's the same everywhere else. I know the FT86Speedfactory guys say they don't have any emissions testing where they're from. So again I say, Eagerly waiting info for the high flow cat.
Back in (Crystal) Black.
Zadkiel is offline   Reply With Quote
Old 10-30-2012, 11:38 PM   #676
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I for one do not want to run even a remote chance of making my insurance null and void. Hence all my modifications, including exhaust, will be have Engineer's Certificate where necessary and be seen by the local Motor Vehicle (government) crowd.
I appreciate the probability of getting caught is small but it is not worth the potential trouble. No one plans on having accidents or getting caught but in my view it is better to have everything right and not get caught than to have something f**k you financially if you do.
This is just my view.
Old 10-30-2012, 11:56 PM   #677
matsayswhat
Drives: '13 SWP BRZ LTD
I forget his screen name, but the guy that worked with Nameless on their first setup is only running one high flow cat and still has never had a CEL. I think I recall seeing somewhere that he had well over 1000 miles on it too.
So if you live somewhere that only tests OBDII ports, you'll be good to go. I'm not sure if it'll pass the sniffer though, it's possible you're screwed.
Lucky for me that my state only tests the port
matsayswhat is offline   Reply With Quote
Old 10-31-2012, 01:45 AM   #678
OrbitalEllipses
Drives: Attitude
In true American - and Internet forum - fashion...that's too bad for you, but I want a catless header and don't care about your emissions.
@Tainen would be the guy you're talking about.
Old 10-31-2012, 04:31 AM   #679
Zadkiel
Well good for you. My wanting a catted one doesn't impact you, so if you dont mind, stuff it.
The Following User Says Thank You to Zadkiel For This Useful Post:
Captain Snooze (10-31-2012)
Old 10-31-2012, 09:11 AM   #680
Neziah
Drives: 2013 HotLava FRS, 2005 Legacy
Gentlemen, I am sure that there will be headers for all, with and without cats, when they get done testing. :P
HotLava FRS MT
Neziah is offline   Reply With Quote
The Following 4 Users Say Thank You to Neziah For This Useful Post:
chanomatik (10-31-2012), Ricepuddin (10-31-2012), Sportsguy83 (10-31-2012), xjohnx (10-31-2012)
Old 10-31-2012, 09:46 AM   #681
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
But what's the point of the internet if not to be ****s to each other over something as frivolous as a car part?
Also, I am pretty sure they will change things around on individual orders to better fit the customer's needs. Nameless is kind of awesome like that
Ricepuddin is offline   Reply With Quote
The Following 2 Users Say Thank You to Ricepuddin For This Useful Post:
Old 10-31-2012, 12:09 PM   #682
ProjectD
ProjectD's Avatar
Drives: '04 350Z/ 2013 LR BRZ (LM)
ProjectD is offline   Reply With Quote
Old 10-31-2012, 12:42 PM   #683
OrbitalEllipses
Drives: Attitude
And you'd be well within your rights to do so
Old 10-31-2012, 07:23 PM   #684
Tainen
Drives: First SWP BRZ-L
It's true, over 3k miles on it with the catless header, zero CELs, and I have a high flow cat in the downpipe. Zero smell at all when warmed up, too- I bet it'd pass a sniffer without issue.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
The Following User Says Thank You to Tainen For This Useful Post:
Old 10-31-2012, 07:38 PM   #685
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Aren't sniffer tests going away 1/2013 anyway? (USA, that is).
My understanding is that the visual will get more detailed (we'll see) and they'll go off of the OBDII readiness check.
I believe disabling codes can generate a non-ready state. At least, that's what I recall reading about in my RomRaider research back in the day.
Feel free to correct me if I'm wrong.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 11-01-2012, 08:07 AM   #686
wparsons
wparsons's Avatar
^^ Ontario (Canada, not Cali) is dropping the sniffer test for 2012 as well for all OBDII cars. No CEL or stored codes and you're good to go. Anything older still gets the same old sniffer test.
I'm not sure about in the US, but for me I'm emissions exempt until the car is 7 years old. I'm not sure how old it has to be before it requires a test for re-sale though.
flickr
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
