Old 10-31-2012, 05:39 PM   #43
bakerr6
Drives: 2013 raven black fr-s
those steelies look nice. This is what I'm going to be running:
don't mind the white socks, I've had them for a couple years (never wear white socks) and figured if I was going to ruin some when painting, I'd rather it be the white ones haha
bakerr6 is offline   Reply With Quote
Old 10-31-2012, 05:53 PM   #44
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
I'm using OEM VW Avus 15x6 (+38 offset) wheels with lug adaptors and 195/60-15s - Wheels were $100 (used) and tires were $270 shipped after a rebate. They clear the brakes and are fine.
http://www.ft86club.com/forums/showthread.php?t=19403 and http://www.ft86club.com/forums/showthread.php?t=18858 for more info
seven is offline   Reply With Quote
Old 11-01-2012, 01:14 AM   #45
VietnamPhenom
Drives: 2013 FR-S WHITEOUT
Here is my setup. 16x6.5 +55 offset Subaru Legacy rims running 205/60 R16. The reason I went with the 205/60 R16 instead of the 205/55 R16 was I wanted a taller profile tire for better ride comfort, I don't have to worry about pot holes destroying the rims/tires, and it was cheaper then the 55s by $30 a tire. The tires I'm running are Bridgestone Blizzaks WS-70.
VietnamPhenom is offline   Reply With Quote
The Following User Says Thank You to VietnamPhenom For This Useful Post:
hmong337 (09-20-2013)
Old 11-01-2012, 01:30 AM   #46
BRZranger
^Almost bought Scion TC wheels for this purpose, but it wasn't much more to buy new wheels. Looks pretty good for winter setup, 16" is the way to go to save money on tires.
BRZranger is offline   Reply With Quote
Old 11-01-2012, 02:26 AM   #47
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
Originally Posted by Laika View Post
Because the tirerack guys are SMART. When I placed my order they said they had a BRZ or two in the shop they were test fitting on and already knew the steelies would work well with the car.
Just followed up with them about torque spec info and the gentleman (Luke) rattled off the torque spec range and stud size and told me all about why our 1.25 thread pitch is sensitive to over tightening. All off the top of his head. Tirerack doesn't hire idiots.
Here's my hurricane/winter rescue vehicle
Are the wheels hubcentric? What was the dimension of the bore?
smbrm is offline   Reply With Quote
Old 11-01-2012, 09:17 AM   #48
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
I just ordered mine. 215/45R17 Dunlop Winter Sport M3s. They'll go on the OEM wheels, which will be my winter wheels - summer tires will go on my Gram Lights 57Xtreme when they arrive.
MVJ1975 is offline   Reply With Quote
Old 11-01-2012, 09:18 AM   #49
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
the vast majority of light vehicle wheels are hub centric since 19-whatever
Old 11-01-2012, 10:01 AM   #50
dsgerbc
Drives: BRZ(sold), STI
Originally Posted by seven View Post
VW wheels with lug adaptors
Did you end-up finding proper lug adaptors?
Drove my winter set-up today. 16x6.5 '04 Forester rims, painted with the cheapest paint local painting place had. Flashed TPMS ID yesterday with ATEQ Quickset (which now has a BRZ profile). The light flashed on start-up for several seconds then went off, so I presume it's good. Drove for ~20 this morning, no light. That's probably not enough to tell for sure though, will drive some more tonight before swapping back to stockers, no freezing temps forecast during in my commute in the next 10 days and no snow at night either.
P.S. gotta find some proper center caps, STI ones are the only ones I had in black, got the wheels w/o caps.
Old 11-01-2012, 11:14 AM   #51
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
You know, I was surprised by this but they are indeed hub centric
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 11-01-2012, 02:05 PM   #52
seven
Tells it like it is
seven's Avatar
Yessir
They're adaptors but the lugs thread in far enough for sure
Old 11-01-2012, 02:16 PM   #53
dsgerbc
Yessir
Last I remember reading - you were talking of R12 ball to conical spacers. Did you find R13 version?
Old 11-01-2012, 04:09 PM   #54
seven
Tells it like it is
seven's Avatar
Using the ball to conical adaptors.
Old 11-01-2012, 04:46 PM   #55
dsgerbc
So is there an R13 one?
I'd appreciate a link, so that I'm ready in case another set of VW BBS pops up for sale locally.
Old 11-01-2012, 05:05 PM   #56
seven
Tells it like it is
seven's Avatar
it's on page 2-3 of the first link I posted in this thread
Don't have it off hand - can't look as I'm at work now.
Winter tires jesseps CANADA 83 12-13-2016 05:06 PM
Winter Tires? joergasm Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 10-03-2012 11:02 PM
Winter tires...? baadshah Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 08-28-2012 01:29 PM
Winter tires si CANADA 30 08-26-2012 12:07 PM
Winter tires, what? Rossman CANADA 12 07-12-2012 04:48 PM
