Old 10-29-2012, 04:11 PM   #29
SenMan
SenMan
Drives: Toyota GT86 - hot lava
Winter in Central Europe
I am facing similar dilemma in Central Europe... My car is arriving end of November, and winter setup is must (actually its a law).
After lot of thinking, I ended up with 16 inch wheels and 205/55/R16 94V tires (91 V are simply not available).
In the end round are following candidates:
As for tires, I am between these two:
  • Continental TS850 205/55 R16 94V
  • Pirelli WINTER 240 SOTTOZERO SERIE II 205/55 R16 94V
(I was looking through the forums, but most of the presented brands are simply not easily available here. So I would like to share the local research, which in my opinion is also applicable for Germany, Austria, Czech Republic, etc.)
SenMan is offline   Reply With Quote
Old 10-30-2012, 07:51 PM   #30
whtchocla7e
Drives: 2013 FR-S Hot Lava
So, 205/55/R16 will be as close to stock geometry as possible?
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 10-30-2012, 08:48 PM   #31
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
2 words. Bridgestone Blizzak.
DanoFA20 is offline   Reply With Quote
Old 10-31-2012, 07:45 AM   #32
Ingen
Drives: Ultramarine FR-S 6MT
I don't mean to hijack this thread, but I have a question about tire rack!
If I order a winter package from them with 16" steel wheels, how can I be sure the offset and everything will actually fit on my FR-S? I don't want to end up with wheels that don't actually work Any thoughts guys? I don't know anything about it, and have never bought any aftermarket wheels...
Thank you.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 10-31-2012, 09:58 AM   #33
bakerr6
Drives: 2013 raven black fr-s
there are a couple guys running 16in. winter packages from tire rack on the site. I'd do a search and see if you can find their setups.
I personally am going to run 16x6.5 +55 legacy gt wheels from a 99 legacy as winter wheels, running the same spec tires. I don't care how flush they are, as long as they still fit and there's no rubbing.
bakerr6 is offline   Reply With Quote
Old 10-31-2012, 01:21 PM   #34
whtchocla7e
I, too, am interested in the tire rack 16" winter package.
Never had a car with aftermarket wheels so I don't quite understand how a narrower wheel/tire is going to fit on the car..
Starting to think it might be better to just get a set of winter tires in stock size and throw em on the stock wheels...
Old 10-31-2012, 02:23 PM   #35
dsgerbc
Drives: BRZ(sold), STI
I'm having my 16" tires mounted today. If I'm not too lazy, I might do a test-fit tonight and see if I can program my TPMS sensors too.
Old 10-31-2012, 03:02 PM   #36
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i'm planning on putting on 15X6 subaru stelies with a 205 tire
65 aspect ratio will put me at same diameter as OEM, a 60 aspect ratio will make my wheels a bit smaller.
if it was snowing more i'd even go down to a 195 but i predict i'll see heavy snow for a small portion of this coming winter.
to the dudes putting on 225s with low aspect ratio for winter, you're crazy and might as well stay with your allseasons.
you'll retain your dry weather stability but for such a light car you'll get less traction starting and stopping if there is snow on the road.
two words: contact patch
Old 10-31-2012, 03:39 PM   #37
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Thank you.
Because the tirerack guys are SMART. When I placed my order they said they had a BRZ or two in the shop they were test fitting on and already knew the steelies would work well with the car.
Just followed up with them about torque spec info and the gentleman (Luke) rattled off the torque spec range and stud size and told me all about why our 1.25 thread pitch is sensitive to over tightening. All off the top of his head. Tirerack doesn't hire idiots.
Here's my hurricane/winter rescue vehicle
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 10-31-2012, 03:46 PM   #38
whtchocla7e
So Laika, did you wheels fit without any modifications (as in straight swap)?
Sorry for the questions guys, I'm a colossal noob..
Old 10-31-2012, 05:07 PM   #39
dsgerbc
You'd need offset of ~40 for them not to rub on tie-rod ball joint.
Old 10-31-2012, 05:16 PM   #40
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Yup just put them on the way they arrived at my door (1 day shipping time thanks to their multitude of distributors). I replaced my OEM lug nuts with the nickle plated ones tirerack gave me and that was it. If there's a chance things won't fit, tirerack will contact you first. Like I said, they're brilliant with this stuff, it's all they do. The perks of going to a specialist instead of pep boys...
Old 10-31-2012, 05:25 PM   #41
whtchocla7e
Very nice.
Did you get yours with the sensors?
Old 10-31-2012, 05:29 PM   #42
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Very nice.
Yes of course, must comply to the law.
(Or save ~$300 and yell profanities at the law)
Winter tires jesseps CANADA 83 12-13-2016 05:06 PM
Winter Tires? joergasm Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 10-03-2012 11:02 PM
Winter tires...? baadshah Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 08-28-2012 01:29 PM
Winter tires si CANADA 30 08-26-2012 12:07 PM
Winter tires, what? Rossman CANADA 12 07-12-2012 04:48 PM
