Old 10-24-2012, 08:43 PM   #29
Fish
Fish's Avatar
Drives: 2015 Yuzu RS1.0 Scion FR-S #893
I used Royal Purple for my Evo before. Didn't seem to have any problems. That being said, I'm going to try out ENEOS now. I used it once before for my xB and liked it, but it was impossible to find at the time. I just found out a couple days ago NAPA Auto Parts just became an authorized dealer for ENEOS. I just picked up a case from my local store like 20 minutes ago. Pretty sweet to know I can get it easily now.
Fish is offline   Reply With Quote
Old 10-24-2012, 08:55 PM   #30
zoomzoomers
zoomzoomers's Avatar
I've been running RP 0w20 for the past 500 miles now. Guess what? I lost the crickets. Go figure. It's either the oil or the fact that LA is now running the winter reserve gas. Which has less oxygen in it, AFIK. Something to do with summer gas being less polluting with more oxygen in the gas.
It's my first time I've ever run RP in anything I've owned, but so far it's doing one helluva job. I've pretty much decided to try all sorts of different oils in my car just for the heck of it. Maybe if I'm not too lazy I'll send the stuff off to Blackrock and see what they say. IMHO, I think the oil companies have got us all under their jedi mind trick. If the oil meets the specs then it should do the job. Just because you got better oil, will it protect more for the same abuse??? Only time will tell I guess.
I might pick up some more RP with that Pepboy coupon, then again I might not. But I've deicded to to run Mobil 1 soon after.
Old 10-24-2012, 09:46 PM   #31
RedRocket
RedRocket's Avatar
Drives: Firestorm Red FR-S
Originally Posted by bluesubie View Post
I'm just trying to stop the myth that all Royal Purple is bad, or that all Mobil1 is bad.
-Dennis
p.s. - Your fuel dilution is killing the viscosity and Flashpoint of the RT6. It sheared to a 30 weight.
I've put Mobil 1 exclusively in both my Honda Ridgeline, and Toyota Camry, without a problem. My trucks at 160k, and still runs like the day I got it.. The Camry doesn't run as good, with 120k but its not running bad by any stretch...
I'm pretty confident I'll get 300k out of the Honda.
RedRocket is offline   Reply With Quote
Old 10-25-2012, 03:32 PM   #32
brillo
Drives: 2013 Firestorm FR-S
I'v run RP 5W-20 in my RX8 for 8 years with no issues what so ever and I have gotten better mileage than most 8 owners ~17 city/24 hwy. I've been to their manufacturing facility here in Houston and I was very impressed with what I saw. Their lead engineer use to race RX3's back in the day and is very familiar with Rotaries and racing in general. I intend to run RP in my FR-S and my CX-5 once its time to change the oil.
I have nothing against Redline or Amsoil, both are also fine products. I support RP cuz they are local and their racing heritage but you can't go wrong with either of the three.
brillo is offline   Reply With Quote
Old 10-26-2012, 12:24 PM   #33
White64Goat
I've got a 2001 Saturn SC1 that I got with 50K miles on it, it now has 280K miles on it and I've been running Wal-Mart full synthetic oil (Super Tech) since I got it and I have had zero problems. It meets current SN and ISLAC GF-5 requirements and SM, SN and ISLAC GF-4 as well.
I'm sure you can have labs analyze your oil and all that, but if the oil you use meets the manufacturers required specs. I certainly wouldn't worry myself to death about it or spend $10 bucks a quart (or more) for something else and that's just my opinion, nothing more.
Old 10-29-2012, 03:56 PM   #34
gonzo
Drives: frs
Originally Posted by seipherzero View Post
I've always heard mixed things about RP oil. I personally plan on going with the Subaru oil for my FR-S. I assume other popular oils aren't tailored for boxer engines, and in that case, Subaru oil should be the best.
what exactly is the subaru oil and where can I purchase it?
gonzo is offline   Reply With Quote
Old 10-30-2012, 03:25 AM   #35
showbe
Drives: A nice one
Originally Posted by Guillaume View Post
An inadequate oil, be it because of its grade or poor quality, would do damage in the long run. Heck you could run with olive oil for a few miles before the engine gives out...
It's a bit like saying you were just fine when running naked in the snow and caught that darn cold right when you sat by the fire. Not that I do that often.
Saying RP is an inadequate oil is taking it a bit far dont you think? Magazines have ran tests that have showed it scratching the least amount compared to other oils on a bearing test.
To say its not a good oil when their are far worse out there. You can say that about a lot of oils. RP will be fine for your car just dont expect too much out of it. Its just oil. In its class its fine but nothing compared to for example Motul.
showbe is offline   Reply With Quote
Old 10-30-2012, 07:24 AM   #36
000 Racing
000 Racing's Avatar
Drives: 2012 86GTS Race Car #86
Royal Purple ..
I race the LS2 6 litre on it.. after 2 years and many race kilometers I only rebuilt the heads .. all else was fine ... my new 86 race car will only ever run on it.. period
000 Racing Australia
000 Racing is offline   Reply With Quote
Old 10-30-2012, 10:55 AM   #37
seipherzero
Ken
seipherzero's Avatar
Drives: '90 FC3S, '95 FD3S, '13 YZF-R6
The Subaru OEM oil (which I believe Idemitsu makes). I'm sure you can purchase it from the Subaru dealerships.
seipherzero is offline   Reply With Quote
Old 10-30-2012, 03:30 PM   #38
gonzo
Drives: frs
thanks! looks like I'm better off just getting the oil and filter from the dealer. does anyone recommend getting the tranny and dif fluid from them also? or should I try another brand? i have a MT
Old 10-30-2012, 04:01 PM   #39
diirk
diirk's Avatar
Drives: 4Runner
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 10-30-2012, 06:57 PM   #40
PMok
Codename: Stitch
PMok's Avatar
I just did this yesterday. about $72 for a filter, gasket, and 6 qts of Subaru Synthetic 0W-20 oil.
The Following User Says Thank You to PMok For This Useful Post:
seipherzero (11-05-2012)
Old 10-30-2012, 07:50 PM   #41
zoomzoomers
Wait, so you're saying Napa autoparts carries Eneos oil? Is it rebranded? And how much do they run a quart?
Old 10-31-2012, 01:26 AM   #42
Fish
Fish's Avatar
Yeah, I found out they became an authorized dealer when I went on the ENEOS site to find one. Was 8.99 a quart. 1 case is 6 quarts. Not rebranded. Has ENEOS written all over it. even had that copyright for the bottle design by Yamaha.
The Following User Says Thank You to Fish For This Useful Post:
zoomzoomers (10-31-2012)
Royal Purple Synthetic Motor Oil 0w20 for the FR-S/BRZ at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 5 12-29-2012 04:25 PM
Saboteurs dumped up to 40 litres of oil on the road in the Royal National Park. st162celica AUSTRALIA 25 10-23-2012 07:29 AM
Purple/White DRL OjiGeorge Cosmetic Modification (Interior/Exterior/Lighting) 5 09-13-2012 10:16 PM
Royal Purple Synthetic Motor Oil 0w20 for the FR-S/BRZ at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 3 07-08-2012 01:04 PM
