Old 10-29-2012, 10:36 PM   #113
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
Originally Posted by DSOmegaX View Post
I have a catted front and over. No drone at all. Silent at cruising and opens up under heavy throttle only.
Me too! Im around the Irvine area
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
Old 10-29-2012, 10:42 PM   #114
zoomzoomers
zoomzoomers's Avatar
I'm in the downtown area and would love to check out other rides in person.
Old 10-29-2012, 10:43 PM   #115
Tylub
Tylub's Avatar
Perhaps a mini meet would be appropriate
instagram @Tylub
Old 10-29-2012, 10:53 PM   #116
Eric1855
Drives: LP DSP / CSP '13 BRZ
How long did you have it on your AT car before the shake developed?
I have the full header back on my BRZ which is also an AT for 3 days now, driven about a 100 or so miles with no shake or rattle.
Eric1855 is offline   Reply With Quote
Old 10-29-2012, 11:06 PM   #117
zoomzoomers
I've clocked around 800 total miles since initial install. From what I recall the rattle started about 300 miles ago. The problem is it seems its ever so slightly getting worse.
Old 10-30-2012, 12:01 AM   #118
DSOmegaX
DSOmegaX's Avatar
Mine's done it since day one.
@dsomegax.cars
Old 11-03-2012, 12:06 AM   #119
cnk
Drives: '13 DGM BRZ Limited
Wanted to provide an update after my test drive. Sorry for the late reply. . .haven't had power since Monday night due to the storm and just got it back earlier today. Took the car for a drive and didn't hear any more noises. My advice for anyone doing the install with a resonator is to try to move the resonator as far away from the side tunnel as possible. You can do this by playing with the exhaust hangers and rotating the rear pipe in the v-band clamps. It doesn't move a lot, but it's enough to give you the clearance you need.
Old 11-03-2012, 12:11 AM   #120
DSOmegaX
DSOmegaX's Avatar
You can also throw on a set of polyurethane hangars to help minimize movement
@dsomegax.cars
Old 11-03-2012, 04:33 PM   #121
zoomzoomers
Glad to hear you were able to remedy your problem. The thing is, I have an un-resonated CBE so the rattle isn't coming from under the car, or the drive shaft tunnel area. Mine is coming from the tip or the tail end of the exhaust/car.
So I have to spend more money to solve a problem that shouldn't be there in the first place? I really hope this isn't the case. From what I can see, without getting the car in the air, it seems the entire CBE is shaking and the tail end or the tip area is rattling since it has the least amount of bracing. If that makes any sense at all. BTW, I have an AT.
Old 11-03-2012, 06:14 PM   #122
TwinRz
Ok I read the whole thread. If what I read was correct we can avoid this issue if we use the hangars that Perrin sells also?
I was already going to purchase the hangars also so will we still need to worry about it hitting that spot if we get the resonated version? I plan to get headers also when Perrin releases them so I dont want the car to be too loud if I get the un resonated. I enjoy a quiet exhaust not one that people will scold at you for having. I am not a kid anymore and also do find loud exhausts to be annoying as hell.
TwinRz is offline   Reply With Quote
Old 11-03-2012, 06:16 PM   #123
DSOmegaX
DSOmegaX's Avatar
I meant to help ensure the resonator doesn't contact the transmission tunnel. In terms of the tip vibration, I put on the replacement that Perrin sent me, and it actually seemed to be worse. Like you said, it's the whole system that's vibrating. Having the full header back has decreased the amount of vibration by smoothing the engine idle more, but like what I thought before, it could just be the way the AT transmission idles. I have yet to hear an MT have the same problem.
@dsomegax.cars
Old 11-03-2012, 06:44 PM   #124
zoomzoomers
Are you using the Perrin poly hangers?
Old 11-03-2012, 07:04 PM   #125
DSOmegaX
DSOmegaX's Avatar
I am currently using one of the perrin poly hangars for the mid pipe. The rest are the oem rubber. I've tried both full poly and full rubber and it didn't make a difference in terms of vibrations
@dsomegax.cars
Old 11-03-2012, 07:46 PM   #126
zoomzoomers
Personally, I don't know what good poly hangers would do for an exhaust system. I mean most, if not all, CBE's are designed to use stock mounting points so why would stiffer hangers be beneficial? Maybe I don't know something someone else does, but that doesn't make any sense to me.
exhaust, headerback, perrin
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 09:47 PM
NEW! Perrin SS Catback Exhaust System Up to +9rwhp | In-Stock| FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 31 04-06-2013 09:05 AM
Brand New SRT Headerback Exhaust System prest1ge Southwest 5 10-16-2012 06:06 PM
