#141 |
Boostin'
Drives: FRS-T
I hope Paul, I hope! I decided to use my 14" chop saw to cut the hoses and it went really well so i got the all done but the oil return, i need to drain the pan and weld a fitting.
First water line ![]() ![]() Oops forgot the heat shield... Better now although not looking as good ![]() Water feed and return ![]() All in place!
#142 |
Boostin'
Drives: FRS-T
This morning i modified the oil return flange that came with the turbo by cutting the pupe and tacking my AN8 fitting then i made my oil return hose. Below is all 4 hoses. The top 2 are water feeds and bottoms are oil.
![]() ![]() Now i just need to weld my other AN8 fitting to the pan and im all done for this part!
#143 |
86-er
Drives: BRZ tS
looks great man
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
| The Following User Says Thank You to *KID* For This Useful Post: | Silverdub (10-27-2012) |
#144 |
Boostin'
Drives: FRS-T
I just clocked the turbo, reinstalled an intercooler pipe and drilled the oil pan/tacked the AN8 fitting. Im now working on the o2 sensor bungs on the downpipe.
#145 |
"Fast Looking Slow Car"
Drives: 13' BRZ
Wow, Your craftsmanship and ingenuity is amazing! Can't wait to see the end result of all this work!
| The Following User Says Thank You to Luke.Cariveau For This Useful Post: | Silverdub (10-27-2012) |
#146 |
Drives: 400whp Scion tC
Looking good man. Was curious though, the fitting on the oil pan seems low. Is the oil level really lower than your mounting point?
#147 |
Boostin'
Drives: FRS-T
No but the fitting is sealed so it doesnt matter at all
#148 |
? What do you mean the fitting is sealed. I'm referring to the gravity feed setup you have. If the fitting is below the oil level when full, then it will cause an oil blockage and back up into the turbo and kill the turbo seals. |
#149 |
Boostin'
Drives: FRS-T
No it wont, that exactly how a vw oil return is built. Its bolted to the lowest point inthe oil pan.
Edit: Vw 1.8t oil pan with return at the bottom
| The Following User Says Thank You to Silverdub For This Useful Post: | 1strwdcar (12-03-2012) |
#150 |
rookie drifter
Drives: 1987 ae86, 1985 celica gts
Anyway, a good friend built a S2000 turbo a long time ago and the turbo's return was trough the drain plug and he never got any problem with it
#151 |
Not sure how that applies to this car, but good luck anyway. With my setups the return had to be above the oil level, cause oil would flow were least resistance (back up the friend line and out the seals). Look forward to seeing your numbers.
#152 |
[||•]=(86)=[•||]
Drives: 2017 Toyota 86
Nice job, can't wait to see it run !
| The Following User Says Thank You to trueno86power For This Useful Post: | Silverdub (10-29-2012) |
#153 |
Drives: Magnetic Gray tC, Silver FR-S
Dude I am so jealous of this car! Subscribed, make a video of it running!!!
| The Following User Says Thank You to ScionFamily For This Useful Post: | Silverdub (10-29-2012) |
#154 |
SorosMotorsports
Drives: Whiteout Pearl
Em... just read all 7 pages.... Awesome, awesome, awesome! Keep it up man!
| The Following User Says Thank You to soros151 For This Useful Post: | Silverdub (10-30-2012) |
| Silverdub firestorm 6mt | Silverdub | Member's Car Journals | 26 | 07-23-2012 06:13 PM |
| 86-X project | phenom86 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-11-2012 03:57 PM |
| Project continue | 4agze | Other Vehicles & General Automotive Discussions | 37 | 11-15-2011 03:55 AM |
| New Project x2 | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 9 | 10-25-2009 12:17 PM |
