Old 10-25-2012, 04:09 AM   #43
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
OEM mudguards look the best on black (;
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
Old 10-25-2012, 01:25 PM   #44
jgbruno
I agree! Does the Raven color in FRS match the crystal black silica?
jgbruno is offline   Reply With Quote
Old 10-25-2012, 01:28 PM   #45
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
raven is crystal black silica (D4S)
86_ZN6 is offline   Reply With Quote
Old 10-25-2012, 04:55 PM   #46
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
i just picked up a set in ebay
GT86drifter is offline   Reply With Quote
Old 10-25-2012, 07:25 PM   #47
TheSt|G
TheSt|G's Avatar
Drives: BRZ L 6MT, 128i 6MT, E39 M5, E36 M3
Originally Posted by #87 View Post
How close are the OEM and rally armor to the ground? Rally armor looks pretty low, what happens when you lower and hit bumps? scrape?
Also, is there an easy way to erase the rally armor logo?
They flex easily. You can reverse the logo or get it in dark gray.
TheSt|G is offline   Reply With Quote
Old 10-26-2012, 06:32 PM   #48
JayeM86
Drives: Whiteout, Stock DD
Anyone know if the OEM FR-S mudflaps will fit with the factory bodykit?
JayeM86 is offline   Reply With Quote
Old 10-26-2012, 06:47 PM   #49
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
There's factory bodykits now?... You mean Dealer bodykits?... lol
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 10-29-2012, 07:29 PM   #50
JayeM86
Does OEM body kit sound better?
Old 10-29-2012, 07:45 PM   #51
DaJo
FT86Club Vancouver
DaJo's Avatar
As far as I am concerned; these cars in North America do not come with bodykits from the plant...Unless your dealer installed them themselves... in which case; no, they will not fit on the rear bumper lip and sideskirt bodykits.
2000 MR-S 5MT
2010-2012
Old 10-31-2012, 09:42 PM   #52
86BRZ
86BRZ's Avatar
Drives: BRZ Limited arrived on 9/1/2012
Installed mine OEM over the weekend. Take most of the time to understand and read the instructions, so unclear... The actual install is quick. Like 5 mins each after install the first one. I did not drill holes and they seems secure enough. I am still waiting for the lower body kit that I like then I will take down these mud guards.
86BRZ is offline   Reply With Quote
Old 11-09-2012, 12:12 PM   #53
iBRZ
fanboy
iBRZ's Avatar
Drives: SWP Limited BRZ AT
Smile
Finally installed OEM Mudflaps and Exhaust Tips woot!
Looks awesome. Where did you order those mudflaps?
iBRZ is offline   Reply With Quote
Old 11-09-2012, 12:23 PM   #54
jgbruno
Check with your dealership should be $59 at most. They'll give you instructions to install, you will need to take out the 2 back wheels to get the back mudflaps on. If you buy it from the dealership you got your car from you can ask them to install it, but I did my own so that I can be meticulous. I know someone says they found it in ebay for $49 so you can check there also.
Old 11-09-2012, 07:26 PM   #55
Jakeedaman21
Drives: Ultramarine FR-S M/T
A dealer installed mine for free, so I cant complain. It wasn't even the dealer I bought the vehicle from either.
Jakeedaman21 is offline   Reply With Quote
Old 12-28-2012, 12:01 AM   #56
mangostick
Drives: whiteout FRS
pics of mine installed, took about a hour for all four including removing the rear wheels and drilling the 5/16 holes that each flap requires. I imagine you could get away without any drilling but I didn't want to cut corners and risk any movement/wiggling around.
They dont cover like the RallyArmor flaps do, but they do fit exactly to the contour of the car where the RA flaps just .. well they flap around lol. The oem ones dont move at all if you follow the directions and use all the fasteners. I have a 17x8 wheel w 53 offset, 235 tire.. and you can see from the downward angle pics that the factory mudgaurds cover just about perfectly. If I had any wider/lower offset wheel on the car I'd seriously think about the RA flaps simply because they're adjustable and with a wide wheel/tire wouldn't look stupid. If you're still running the factory wheels or like I do, have a set of winters on the factory wheels.. the oem guards will work just fine.
I figure for $60 shipped these will work perfect for me. I even managed to drive the car through a massive puddle today.. the pics were taken after I got home. Sure there's some water spotting, but no actual mud or debris on the car like the last time it rained. I'm pretty satisfied. If you get these do make sure you clean the installation area really well before you put them on. As mentioned on the first page, trapping grit in there will not do your paint any good. They dont move once in place but a quick cleaning is cheap insurance.
mangostick is offline   Reply With Quote
*GROUP BUY: JUST IN RALLY ARMOR MUDFLAPS!* genometuning Groupbuys 585 01-15-2015 06:08 PM
fr-s mudflaps sydande Exterior Parts (Aero, Lighting, Etc.) 5 08-28-2012 07:10 PM
mudflaps FIRECAR Cosmetic Modification (Interior/Exterior/Lighting) 7 05-18-2012 09:46 AM
