#113 |
Grip>Slip
| The Following User Says Thank You to xjohnx For This Useful Post: | Bahraini86 (10-24-2012) |
#114 |
Drives: BRZ WRB
waiting for the NUMBERS!
| The Following User Says Thank You to MSTiFK8R For This Useful Post: | Subaruwrxfan (10-24-2012) |
#115 | |
Drives: 2006 Subaru LGT
have you ever seen a dogbone mount on an ej engine? the engine moves more than radially. |
#116 |
Drives: Black 2013 FRS
Getting back to the larger MAF housing topic, ECUTek should be able to recalibrate the MAF sensor to read accurately. This is something that should really be done anytime you change your intake at all. In theory whatever is before or after the MAF shouldn't matter because it's a calibrated instrument with a specific opening size to read airflow. However, in the real world a MAF isn't a perfect instrument and variations upstream or downstream can affect its accuracy. See the Injen intake for an example of this. With this intake the MAF readings are off and this makes the engine run leaner.
#117 |
Reverse Burnouts
Drives: 2013 Argento FRS
When the engine revs it moves counter clockwise, pulling the intake tubing away from the supercharger.
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#118 |
EJ blocks are typically mated to AWD transmissions, which internally house the frond diff. As the case tries to twist the front axles, it creates the fore/aft torsional load you are referring to. RWD platforms (such as the 86) don't have front axles. It may twist fore/aft very very slightly from some off-center loading from the propeller shaft relative to the engine mounts, but it will be minimal, especially considering the FA engine mounts so low, it is more inline with the shaft.
#119 | |
If the engine block wants to move toward the passenger side under acceleration, I wonder how much movement there is under high RPM deceleration (or jerky/sloppy downshifts)? |
#120 | |
Reverse Burnouts
#121 | |
The statement I made regarding botched downshifts (or hard upshifts, possibly) is it would deflect the engine to an extreme. I'm not saying this is an imminent problem, just curious. Either way, stiffer engine mounts would certainly fix it. |
#122 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
Vortech cars needs to be in this thread: http://www.ft86club.com/forums/showthread.php?t=20991
Along with FULL ENGINE BAY PICS AND POWER INFO Last edited by ATL BRZ; 10-30-2012 at 01:30 PM. |
#123 | |
From related thread: http://www.ft86club.com/forums/showthread.php?t=21048
STILL holding out on numbers!?!?! Last edited by ATL BRZ; 10-30-2012 at 04:37 PM. |
#124 |
Drives: the girls crazy
Dawn that thing looks stock. WoW
#125 |
Drives: '13 SWP BRZ-L
Does look OEM.... legit!
#126 |
Drives: Mazda3 2013 / Scion FR-S 2015
it look so clean. great job!
| Supercharger or Turbo ? | #87 | Forced Induction | 192 | 01-25-2013 10:20 AM |
| HKS Supercharger getting closer | gtauto | AUSTRALIA | 166 | 09-03-2012 07:11 PM |
| TRD Supercharger anyone?? | poormans_LFA | Engine, Exhaust, Transmission | 48 | 04-27-2012 11:42 PM |
| Supercharger for Infiniti G25 | Lottta | Other Vehicles & General Automotive Discussions | 2 | 02-12-2012 09:10 PM |
