Old 10-23-2012, 05:50 PM   #113
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Bahraini86 View Post
What's the tuning solution for the kit? FMU with an R4 software?
ECUTek.
Any reason you guys are going with MAF vs Speed Density with ECUtek's racerom?
Bahraini86 (10-24-2012)
Old 10-24-2012, 01:46 AM   #114
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
waiting for the NUMBERS!
MSTiFK8R is offline   Reply With Quote
The Following User Says Thank You to MSTiFK8R For This Useful Post:
Subaruwrxfan (10-24-2012)
Old 10-24-2012, 01:50 PM   #115
wcbjr
Drives: 2006 Subaru LGT
Originally Posted by carbonBLUE View Post
The engine moves radially, the SC and the intercooler piping connected to the throttlebody will move around eachother kind of like a thermostat spring, the engine would have to twist 90 degrees before any contact is made
have you ever seen a dogbone mount on an ej engine? the engine moves more than radially.
wcbjr is offline   Reply With Quote
Old 10-25-2012, 09:20 AM   #116
d1ck
Drives: Black 2013 FRS
Getting back to the larger MAF housing topic, ECUTek should be able to recalibrate the MAF sensor to read accurately. This is something that should really be done anytime you change your intake at all. In theory whatever is before or after the MAF shouldn't matter because it's a calibrated instrument with a specific opening size to read airflow. However, in the real world a MAF isn't a perfect instrument and variations upstream or downstream can affect its accuracy. See the Injen intake for an example of this. With this intake the MAF readings are off and this makes the engine run leaner.
d1ck is offline   Reply With Quote
Old 10-26-2012, 05:59 PM   #117
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
When the engine revs it moves counter clockwise, pulling the intake tubing away from the supercharger.
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 10-26-2012, 06:41 PM   #118
wheelhaus
wheelhaus's Avatar
EJ blocks are typically mated to AWD transmissions, which internally house the frond diff. As the case tries to twist the front axles, it creates the fore/aft torsional load you are referring to. RWD platforms (such as the 86) don't have front axles. It may twist fore/aft very very slightly from some off-center loading from the propeller shaft relative to the engine mounts, but it will be minimal, especially considering the FA engine mounts so low, it is more inline with the shaft.
Old 10-26-2012, 06:46 PM   #119
wheelhaus
wheelhaus's Avatar
To clarify, looking into the engine bay standing at the front of the car, the engine internals spin clockwise, which in turn they try to spin the block counterclockwise, this is the movement you see. So when you rev, the block rolls toward the passenger side slightly.
If the engine block wants to move toward the passenger side under acceleration, I wonder how much movement there is under high RPM deceleration (or jerky/sloppy downshifts)?
Old 10-26-2012, 08:08 PM   #120
carbonBLUE
Reverse Burnouts
Curious, During correct down shifts there is very little movement. I'm curious on how the pulley for the supercharger is rigged... For their system to work out would have to be two pieces, supercharger mounted to the air box, and pulley on a swinging arm to compensate for engine movement so the air box doesn't get wiggled off the supercharger
(wont forget you)
2011 Infiniti G37x
Old 10-26-2012, 10:19 PM   #121
wheelhaus
wheelhaus's Avatar
From what I understand so far, the compressor and pulley is mounted to the engine like normal, but the short connection to the airbox is a flexible tube of sorts, (I imagine something similar to a flattened accordion) designed to allow lateral movement. The pictures don't show this coupling very well. THIS POST at least shows the difference in diameter between the airbox outlet and airbox inlet.
The statement I made regarding botched downshifts (or hard upshifts, possibly) is it would deflect the engine to an extreme. I'm not saying this is an imminent problem, just curious. Either way, stiffer engine mounts would certainly fix it.
Old 10-30-2012, 09:40 AM   #122
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Vortech cars needs to be in this thread: http://www.ft86club.com/forums/showthread.php?t=20991
Along with FULL ENGINE BAY PICS AND POWER INFO
Old 10-30-2012, 04:23 PM   #123
ATL BRZ
ATL BRZ's Avatar
From related thread: http://www.ft86club.com/forums/showthread.php?t=21048
What exactly is so mysterious about the Vortech Supercharged Scion FR-S? The power output of course.
Unveiled today at the SEMA Show aftermarket parts expo in Las Vegas, NV, the Vortech kit is certain to be a go-to addition for many FR-S drivers once the original thrill of their light weight, rear-drive sports car wears off.
Vortech hasn’t released any estimated numbers for the kit either and a representative we spoke with at the SEMA Show was hesitant to even guess – though something just shy of 300 hp (a 50% increase from the stock output) seems about right.
Other upgrades on the FR-S include a KW suspension, Borla exhaust, 19-inch Rotiform wheels.
http://www.autoguide.com/auto-news/2...sema-show.html
STILL holding out on numbers!?!?!
Old 10-30-2012, 04:31 PM   #124
WatchmaN
WatchmaN's Avatar
Drives: the girls crazy
Dawn that thing looks stock. WoW
WatchmaN is offline   Reply With Quote
Old 10-30-2012, 06:45 PM   #125
spitz
spitz's Avatar
Drives: '13 SWP BRZ-L
Does look OEM.... legit!
spitz is offline   Reply With Quote
Old 11-02-2012, 01:35 AM   #126
HyperTech
HyperTech's Avatar
Drives: Mazda3 2013 / Scion FR-S 2015
it look so clean. great job!
HyperTech is offline   Reply With Quote
Supercharger or Turbo ? #87 Forced Induction 192 01-25-2013 10:20 AM
HKS Supercharger getting closer gtauto AUSTRALIA 166 09-03-2012 07:11 PM
TRD Supercharger anyone?? poormans_LFA Engine, Exhaust, Transmission 48 04-27-2012 11:42 PM
Supercharger for Infiniti G25 Lottta Other Vehicles & General Automotive Discussions 2 02-12-2012 09:10 PM
