Old 10-23-2012, 02:05 PM   #3179
Visconti
Drives: 05 STi
Originally Posted by Subforever View Post
It was a little ambiguous in my head when filling the form. i was thinking that the "Fuel Economy Display" thing was part of the "Customized to my vehicle" . I should have used the "other" Issues field instead.
Sorry for the inconvenience John
I know its not very clear, and I know people aren't doing it on purpose.
It's just really hard to keep up with all this stuff so anyway you can make my life easier would be awesome for me.
-John
Visconti is offline
Old 10-23-2012, 02:20 PM   #3180
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
Alrighty - I'd like to start a discussion with all of those who have Canadian Cars and are having a RaceRom Gauge problem.
Seems to be a problem from more than one of you so
If you have a Canadian Cluster you should have a tune file like this -
"RR-10895-ZA1J700C-STG1 STOCK INTAKE v1.07 FED-M"
Must have "FED-M" in it.
Basically - what problems are you noticing?
If you dont have the correct tune file I dont' need your input, just need you to fill out the form so i can send you a correct tune file.
Let me know
Thanks
John
My fuel gauge was wonkey after initial flash, but after first fill up its been fine for 300klms, Mine regardless of what map does not show A/F ratio or Fuel%.
I have not experienced any malfunctions of any sort with the tune.
Cheers
Bu-Tang is offline
Old 10-23-2012, 02:20 PM   #3181
Visconti
Drives: 05 STi
Cheers
Can you make a video of what the cluster shows?
Visconti is offline
Old 10-23-2012, 02:49 PM   #3182
Subynewbie
Subynewbie's Avatar
Drives: 2013 swp brz
Cheers
Mine is similiar to this John. l/100 km sometimes stays at 50.0. I believe mine does not show a/f ratio or fuel % either. Gas tank readings were a little off as well but may appear to be stabilizing. After driving approximately 100 miles after filling up, tank was reading less than 1/4 tank. I do have the "M" in the tune as well. Car runs great though!
Subynewbie is offline
Old 10-23-2012, 02:52 PM   #3183
Visconti
Drives: 05 STi
What does your show when on the A/F Map?
Visconti is offline
Old 10-23-2012, 03:11 PM   #3184
Opposed
Drives: 2013 Asphalt FR-S
Im now on 200 miles, and the guauge is only between 3/4 and 1/2. Its almost like the guage thinks a half a tank is empty, and 3/4 is a half tank if that makes sense. My avg MPG's on map 1 still reads about 68-72 mpg at all times.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline
Old 10-23-2012, 03:13 PM   #3185
Visconti
Drives: 05 STi
Whats ur first name?
Visconti is offline
Old 10-23-2012, 03:19 PM   #3186
jpit
Drives: Subaru BRZ
Gas Gauge Correction
This worked for me.
Originally Posted by brichard0625 View Post
for those that are having the bugs with the tune try resetting the ecu...My tank was on E yesterday and i was reading 36%..i unplugged the battery and waited a few minutes and then plugged it back in and the fuel tank adjusted itself. i filled up and drove about 70 miles after the guage is now accurate
jpit is offline
The Following User Says Thank You to jpit For This Useful Post:
brichard0625 (10-23-2012)
Old 10-23-2012, 03:42 PM   #3187
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Originally Posted by jpit View Post
This worked for me.
Is the gas guage reading properly now?
brichard0625 is offline
Old 10-23-2012, 04:11 PM   #3188
jpit
Drives: Subaru BRZ
Yes. But I haven't switched to the gas percentage function on map 4 yet. Don't know if that will throw it off again.
jpit is offline
Old 10-23-2012, 05:07 PM   #3189
Opposed
Ian, sorry, I have not filled out the form yet, just been extremely busy... Heres a picture of my ave MPG after about 150 miles.
Opposed is offline
Old 10-23-2012, 05:51 PM   #3190
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
Yeah, that happened to me, too. It just sticks at 76.2 and doesn't move. I have no idea what that's supposed to indicate.
Symbiont is offline
Old 10-23-2012, 05:52 PM   #3191
Symbiont
Tall guys fit, too.
Symbiont's Avatar
I really want to use the autoblip, though.
Symbiont is offline
Old 10-23-2012, 06:33 PM   #3192
bluecollarfrs
Drives: Ultramarine FR-S
OK guys, I need some help here. When trying to flash, I selected the ROM that John emailed me, but it gives me an Error that says "A compatible ROM file must be chosen before the ECU can be programmed."It says I have an unknown ECU version
bluecollarfrs is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
