Old 10-16-2012, 08:01 PM   #1
Supermassive
Supermassive's Avatar
KW V3 Setup for Street use.
Just bought my KW V3 coilovers today and was hoping a few owners who have had them for a while could set me up with a good setting for street use/aggressive driving. I just want a good baseline to start with since i am installing/setting up the suspension myself.
Thanks in advance.
(Also if any of you guys running HPDE or Autocross have any setup tip that you can share I'd like that too!)
Supermassive is offline   Reply With Quote
Old 10-16-2012, 08:37 PM   #2
D1cker
Drives: B9 S4/ND2
Start with what's in the book, and then adjust it to your tastes!
D1cker is offline   Reply With Quote
Old 10-16-2012, 09:23 PM   #3
Luke.Cariveau
"Fast Looking Slow Car"
Luke.Cariveau's Avatar
Drives: 13' BRZ
I don't know how many setting are in the KW V-3 but i have comparable coil-overs with 30 levels of damping and I set mine to 18. It could go slightly softer but I am trying different settings for a week or so DD'ing to gauge if it's an improvement or not.
Luke.Cariveau is offline   Reply With Quote
Old 10-16-2012, 09:45 PM   #4
Racecomp Engineering
turn all settings to full stiff.
front compression- back off 7 clicks from full stiff.
front rebound-back off 10 clicks from full stiff
rear compression - back off 8 clicks from full stiff.
rear rebound- back off 7 clicks from full stiff.
from there I advise you to drive the car in many scenarios BEFORE you make any more changes.
NEVER, NEVER ,NEVER make more than one change at a time. ( you will never know what change made the difference you liked or disliked).
Rebound is on TOP and compression is on the bottom.
Remember as you upgrade your suspension things like rear control arms and rear subframe bushings that will effect these settings so dont be surprised if things feel different after certain changes.
Myles
RCE/ GTWORX
The Following 41 Users Say Thank You to Racecomp Engineering For This Useful Post:
8686 (07-14-2013), Anthonytpt (05-08-2013), autobrz (09-06-2013), brybot (11-07-2018), BRZranger (10-23-2012), chaotichoax (10-21-2012), dabocx (10-16-2012), deucethemoose (10-23-2012), djdnz (10-19-2012), FT-86 SpeedFactory (10-16-2012), GodDamage (11-27-2013), GregV (03-28-2013), Imrac (10-05-2014), J95 (03-25-2024), JoeBoxer (10-16-2012), JoeHK (06-01-2015), johnb831 (04-28-2013), kahox (07-13-2013), kidgogeta (10-16-2012), Lawnik (10-16-2012), low trq (10-24-2012), lp87 (08-15-2013), Mad1723 (10-19-2014), mike2100 (10-23-2012), n0thing (05-09-2016), Nardi330 (10-16-2012), nikitopo (11-26-2015), nquillen (10-23-2012), RedLeader (10-16-2012), RL_BRZ (11-27-2013), Ro_Ja (10-30-2012), stoked_on_spool (08-09-2016), Supermassive (10-16-2012), Surok (10-17-2012), tian105 (10-10-2017), troek (11-30-2013), try2findmark (10-17-2012), UncleFester (10-23-2012), whataboutbob (11-27-2013), wichiewichie (10-16-2012), xxBrun0xx (05-27-2016)
Old 10-16-2012, 10:22 PM   #5
Supermassive
Thanks Myles, thats exactly what i was looking for!!
I just got the KW's today but am waiting until my AP control arms come in, not to mention my wheels and tires.
Old 10-16-2012, 11:08 PM   #6
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
That's what i'm talking about, great post Myles! Where else are you going to get that kind of help?
Old 10-19-2012, 12:25 AM   #7
No worries man. While we carry most brands, we will be testing the following over the next 6 months:
RCE T2s
Bilstein
Ohlins
And a few others I cant mention yet.
We feel there are various options for various needs. I dont feel that brand X is necc better than brand Y etc. ( amongst the brands with actual "damping")
Myles
JoeBoxer (10-19-2012)
Old 10-22-2012, 11:41 PM   #8
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
Thanks in advance.
I have mine setup with stock rebound. Two clicks stiffer in the front on compression and 1 click less compression on rear. Works very well car doesn't have the traction issue as much and is a lot more mangeable on the street. This worked well for my track day too.
My car only has a minor drop so more compression valving may be need if your lower.
I am thinking of adding 1 click of rebound to the rear shocks too. This should help settle the rear a little more. Front feels perfect to me.
jdzumwalt is offline   Reply With Quote
Old 10-23-2012, 03:20 AM   #9
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
Myles
RCE/ GTWORX
Sorry, but I am confused....when you talk about "......rebound-back off 10 clicks from full stiff" do you mean stiff being full fast or full slow?
I've only ever thought about rebound being either fast or slow, never stiff, as rebound dictates the return speed of the damper from compression.
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 10-23-2012, 03:33 AM   #10
RYU
RYU's Avatar
Drives: really slow...
RCE T2s
Bilstein
Ohlins
Myles
Myles, I've come to value your opinion and I'm new to the subie world so here's a quick question for you. How come you don't test some of the other seemingly well regarded jdm brands like RS*R?
I'm not talking about the lower end offerings from BC racing, Tein, Fortune, and <insert random brand here>. For example I run DG-5s on my other vehicle and find them very competitive in the approx $2-3k price range.
RYU is offline   Reply With Quote
Old 10-23-2012, 04:22 AM   #11
Supermassive
Im gonna go out on a limb and say that full stiff = fully closing the valve, and then backing it out the desired number of clicks. I just installed them tonight on the stock wheels/tires and without the adjustable rear control arms (dont have them yet) and the suggested setup from Myles seem pretty spot on for street use, I may add another click stiffer in the rear as the car feels a little soft in the back.
Old 10-23-2012, 11:48 AM   #12
When we say stiff we mean slow return.
Not Myles....but....
A long time ago, WAY back in 2004 when most of us were running around in diapers....we did sell some "higher end" JDM brands. Some of them are pretty good, many have some hassles (rebuilds only in japan for example), and some we felt just were overrated. We did have a few less than stellar experiences that soured us a bit and when started going to the euro brands we didn't really feel the need to look back. Really good valving, lots of travel, good support even stateside. We aren't "anti-JDM" by any means (see Myles' STI JDM v-limited lip and stacks of best motoring DVDs and Japan only Impreza magazines) and we do have an open mind. It's just that at the moment we feel there is a lot of really good stuff that happens to come from Europe.
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
BRZranger (10-23-2012), Metabrz (10-23-2012), Surok (10-29-2012)
Old 10-23-2012, 11:54 AM   #13
ModBargains.com
ModBargains.com's Avatar
Bingo... Exactly what I did... Had them dialed in within the first week, haven't changed them since.
ModBargains.com is offline   Reply With Quote
Old 10-23-2012, 12:08 PM   #14
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
This is what I have mine set to and they feel only slightly more firm than stock. Perfect for DD'ing.
Myles
RCE/ GTWORX
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Let's see your computer setup! Hanakuso Off-Topic Lounge [WARNING: NO POLITICS] 79 11-06-2022 11:43 AM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
Cusco Street Zero-A & Street Spec A Coilovers - In Stock And Ready To Ship Enjuku Racing Brakes, Suspension, Chassis 0 09-12-2012 05:12 PM
Brz Drag Setup Tansey86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 09-12-2012 11:24 AM
Audio setup 315FR-S Electronics | Audio | NAV | Infotainment 20 05-17-2012 06:23 PM
